ProjeQtOr free project management software - [SOLVED] Teams are not working at fully time on project - Page 3 - ProjeQtOr
26 Oct 2015 16:29 #13 by El Wallos
Hi Babynus
One question more, my team is working on "real projects" and "run projects" (activities from day to day), so if I want to plan some projects and my "run projects", what is your recommendation to plan it on ProjeQtOr? because "run projects" is a task that is cyclic but I don't know how to add it on ProjeQtOr (which planning uses ... etc)
PD: I know the % that my team is free for "real projects" and the other % to do only "run projects".
Martin
26 Oct 2015 16:47 #14 by babynus
Use the "regular between dates" planning mode. It's done for this.
You define start and end dates (for instance 01/01 => 31/12) and assign resource with expected work for the period. Planning will reserve work, reguliarly.
You can also opt for "in half days" or "in full days" if you don't work to book 0,1 day par day.
26 Oct 2015 16:52 #15 by babynus
NB : please open new post for new subject.
(posting on [SOLVED] thread, you take high risk that your question is never read)
26 Oct 2015 16:55 #16 by El Wallos
Yes, I will do it for next question.
