ProjeQtOr free project management software - [SOLVED] Problem ldap search - ProjeQtOr
31 Aug 2015 14:10 #1 by Coyote
Problem ldap search was created by Coyote
I have a authentication problem with ldap.
2015-08-31 14:02:28.691 ***** ERROR ***** ERROR *****
2015-08-31 14:02:28.692 ***** ERROR ***** on file '/var/www/html/projeqtor/model /User.php' at line (933)
2015-08-31 14:02:28.692 ***** ERROR ***** cause = ldap_search(): Search: Bad search filter
My projeqtor is the latested version (V5.0.5).
Thanks you for your help,
Best regards.
01 Sep 2015 08:31 #2 by babynus
Replied by babynus on topic Problem ldap search
What did you enter in "LDAP user filter" (in global parameters)
02 Sep 2015 06:06 - 02 Sep 2015 06:51 #3 by samuelcochard
Replied by samuelcochard on topic Problem ldap search
Hi, I have the same problem :
2015-09-01 18:02:13.569 ===== TRACE ===== Login error for user 'my_ldap_id'
2015-09-01 18:06:18.849 ===== TRACE ===== authenticate - Filter error : filter retrieved admin user (LDAP user in global parameters)
Here is my LDAP user filter : sAMAccountName=%USERNAME%
Did the problem come from here ? :dry:
Edit : I use Projeqtor v. 5.0.5
Last edit: 02 Sep 2015 06:51 by samuelcochard.
02 Sep 2015 10:04 #4 by babynus
Your issue is not the same.
Your message is "Filter error : filter retrieved admin user"
It is explicit : you cannot connect to the application with LDAP user that you defined in the global parameters (it is a security constraint).
02 Sep 2015 10:21 #5 by Coyote
Replied by Coyote on topic Problem ldap search
hello,
ldap user filter parameters is "sAMAccountName=%USERNAME%"
02 Sep 2015 10:29 #6 by babynus
And do you have sAMAccountName in your LDAP ?
Try to browse your LDAP and search "sAMAccountName=youUser"
