ProjeQtOr free project management software - [SOLVED] Problem ldap search - Page 2 - ProjeQtOr
02 Sep 2015 11:36 #7 by samuelcochard
Replied by samuelcochard on topic Problem ldap search
The thing is that we are sure that the parameter is good, because we have another web-applications (named GRR) which is working very well with LDAP and with the same parameters..
02 Sep 2015 11:41 #8 by Coyote
Replied by Coyote on topic Problem ldap search
yes, we use other application that uses the ldap with the same parameters.
02 Sep 2015 12:09 #9 by babynus
Replied by babynus on topic Problem ldap search
@samuelcochard
Your issue is not the same.
Your message is "Filter error : filter retrieved admin user"
It is explicit : you cannot connect to the application with LDAP user that you defined in the global parameters (it is a security constraint).
LDAP connection will success if you try another user.
03 Sep 2015 12:23 #10 by samuelcochard
We try with another user and here is the error :
2015-09-02 15:44:26.326 ===== TRACE ===== Login error for user 'aire.lavage'
2015-09-02 15:44:43.009 ***** ERROR ***** ERROR *****
2015-09-02 15:44:43.009 ***** ERROR ***** on file '/var/www/projeqtor/model/User.php' at line (958)
2015-09-02 15:44:43.009 ***** ERROR ***** cause = ldap_bind(): Unable to bind to server: Invalid credentials
03 Sep 2015 12:24 #11 by babynus
Wrong user or password
03 Sep 2015 12:40 #12 by samuelcochard
What should i write on fields "LDAP base dn" and "LDAP user filter" ?
