ProjeQtOr free project management software - [SOLVED] How to Change Layout/Position of Predecessor, Successor and Linked Elements - ProjeQtOr
29 Jul 2015 11:16 #1 by iconic
Firstly I would just like to say, I loved version 5.0.3 It is so much easier to look at and use. I have the new buttons and feel of the program.
The only question I have is how could I change the position or Layout of the the Elements. At the moment the elements are displayed from left to right as ...
Predecessor element | Successor Element | Linked Elements
| Notes
This layout doesn't work for us at the moment. I am trying to find a way to make it display as
Notes | Attachments | Linked Elements
| Predecessor element
| Successor Element
29 Jul 2015 11:31 #2 by babynus
Just change order in object definition (for instance in /model/Activity.php for activities)
29 Jul 2015 11:35 #3 by iconic
Can you be a little more specific as to where I can change the order in object definition. I looked at /model/Activity.php and I can't seem to find anything I can change the order for.
29 Jul 2015 11:46 #4 by babynus
My mistake.
It is in ActivityMain.php.
class ActivityMain extends SqlElement {
  // List of fields that will be exposed in general user interface
  public $_sec_description;
  public $id;    // redefine $id to specify its visible place
  public $reference;
  public $name;
  public $idActivityType;
  public $idProject;
  public $externalReference;
  public $creationDate;
  public $idUser;
  public $idContact;
  public $Origin;
  public $description;
  public $_sec_treatment;
  public $idActivity;
  public $idStatus;
  public $idResource;
  public $handled;
  public $handledDate;
  public $done;
  public $doneDate;
  public $idle;
  public $idleDate;
  public $cancelled;
  public $_lib_cancelled;
  public $idTargetVersion;
  public $result;
  public $_sec_Assignment;
  public $_Assignment=array();
  public $_sec_Progress;
  public $ActivityPlanningElement; // is an object
  public $_sec_predecessor;
  public $_Dependency_Predecessor=array();
  public $_sec_successor;
  public $_Dependency_Successor=array();
  public $_sec_Link;
  public $_Link=array();
  public $_Attachment=array();
  public $_Note=array();
  public $_nbColMax=3;
But best way is :
-copy Activity.php in /model/custom
- copy fields description from /model/ActivityMain.php to /model/custom/Activity.php
- change order or fields in /model/custom/Activity.php
This should do the job and will not be overwritten by new versions.
29 Jul 2015 12:03 #5 by iconic
I think I made an error as I am now receiving the following error.
"Fatal error: Class 'Activity' not found in /home/iconicprod/public_html/Project-Management/view/objectList.php on line 42"
I did as you said and made a copy in of Activity.php in .../model/custom
Here is what I copied and is now showing in Activity.php in .../model/custom
require_once('_securityCheck.php');
  public $reference;
  public $name;
  public $idProject;
  public $idUser;
  public $idContact;
  public $Origin;
  public $idActivity;
  public $idStatus;
  public $idResource;
  public $handled;
  public $done;
  public $doneDate;
  public $idle;
  public $idleDate;
  public $cancelled;
  public $result;
  public $_sec_Link;
   * Constructor
   * @param $id the id of the object in the database (null if not stored yet)
   * @return void
  function __construct($id = NULL, $withoutDependentObjects=false) {
    parent::__construct($id,$withoutDependentObjects);
   * Destructor
   * @return void
  function __destruct() {
    parent::__destruct();
What have I done wrong?
29 Jul 2015 12:08 #6 by babynus
Issue is that you copied all what I showed.
You should just have copied fields (lines starting with public)
The most important is the class definition that must be :
class Activity extends ActivityMain {
