ProjeQtOr free project management software - [SOLVED] How to Change Layout/Position of Predecessor, Successor and Linked Elements - Page 3 - ProjeQtOr
30 Jul 2015 12:45 #13 by babynus
Here is result on 3 columns :
30 Jul 2015 14:42 #14 by iconic
Yes, that is similar to what I have, and there is the issue I am having.
You see, I want Notes and Linked elements to be in the position of where Predecessor and Successor Elements are.
In essence, I want Notes in the first column where Predescessor is.
Is there anyway i can do this?
01 Aug 2015 12:12 #15 by iconic
Hi there,
Any further updates with this would be greatly appreciated
01 Aug 2015 17:13 - 01 Aug 2015 17:13 #16 by babynus
Field description should be (for instance)
 public $_sec_description;
  public $id;    // redefine $id to specify its visible place
  public $reference;
  public $name;
  public $idActivityType;
  public $idProject;
  public $externalReference;
  public $creationDate;
  public $idUser;
  public $idContact;
  public $Origin;
  public $description;
  public $_sec_treatment;
  public $idActivity;
  public $idStatus;
  public $idResource;
  public $handled;
  public $handledDate;
  public $done;
  public $doneDate;
  public $idle;
  public $idleDate;
  public $cancelled;
  public $_lib_cancelled;
  public $idTargetVersion;
  public $result;
  public $_sec_Progress;
  public $ActivityPlanningElement; // is an object
   public $_sec_Assignment;
  public $_Assignment=array();
  public $_Note=array();
  public $_sec_Link;
  public $_Link=array();
  public $_Attachment=array();
  public $_sec_predecessor;
  public $_Dependency_Predecessor=array();
  public $_sec_successor;
  public $_Dependency_Successor=array();
  public $_nbColMax=3;
and in /view/objectDetail.php, about line 1676 , values for $arrayPosition , correct
'note'=>          array('float'=>'left',  'clear'=>'left')
'link'=>          array('float'=>'left', 'clear'=>'none'),
Pay attention, these change will have to be reapplied after each upgrade of new version.
Last edit: 01 Aug 2015 17:13 by babynus.
03 Aug 2015 01:48 #17 by iconic
I made the changes, however there was no change. The notes are still showing on the left.
Here is the code to show you that I made the changes
$arrayPosition=array(
         'treatment'=>     array('clear'=>(($nbCol==2)?'right':'none')),
         'progress'=>      array('float'=>(($nbCol==2)?'right':'left'), 'clear'=>(($nbCol==2)?'right':'none')),
         'predecessor'=>   array('clear'=>(($nbCol==2)?'both':(($classObj=='Activity')?'left':'none'))),
         'successor'=>     array('float'=>(($nbCol==2 or $classObj!='Project')?'left':'right'),  'clear'=>'none'),
         //'subprojects'=>   array('float'=>(($nbCol==2)?'left':'left'),   'clear'=>(($nbCol==2)?'left':'none')),
         'versionproject_versions'=>array('float'=>(($nbCol==2)?'right':'left'),  'clear'=>'right'),
         'version'=>       array('float'=>(($nbCol==2)?'right':'left'),  'clear'=>'none'),
         'approver'=>      array('float'=>'right','clear'=>'right'),
         'lock'=>          array('float'=>(($nbCol==2)?'left':'right'),  'clear'=>(($nbCol==2)?'none':'right')),
         'assignment'=>    array('float'=>'left','clear'=>(($nbCol==2)?'left':'none')),
         'attendees'=>     array('float'=>'left','clear'=>(($nbCol==2)?'left':'none')),
        //'periodicity'=>    array('float'=>'left','clear'=>'left'),
        'internalalert'=>  array('float'=>'right'),
        'expensedetail'=>      array('clear'=>'left'),
         'billline'=>      array('clear'=>'left'),
         'attachment'=>    array('float'=>'left',  'clear'=>'none'),
05 Aug 2015 06:53 #18 by iconic
Hi there,
Are they are further updates with regards to this?
