ProjeQtOr free project management software - Cron stops - Page 2 - ProjeQtOr
Cron stops
26 Nov 2014 16:58 #7 by ndusch
Replied by ndusch on topic Cron stops
he script works fine and over 30 secondes when max_execution_time = 30 and over 300 secondes when max_execution_time = 300.
I also tested max_execution_time = 0 and your script works fine also.
We run Apache (within WAMPServer)
below the full description of error message of Apache lof file :
[Wed Nov 26 14:26:54.749764 2014] [:error] [pid 5208:tid 1688] [client 192.168.1.58:49600] PHP Fatal error: Maximum execution time of 300 seconds exceeded in C:\\wamp\\www\\projeqtor\\model\\Cron.php on line 302, referer: http://192.168.1.12/projeqtor/view/main.php
[Wed Nov 26 14:26:54.749764 2014] [:error] [pid 5208:tid 1688] [client 192.168.1.58:49600] PHP Stack trace:, referer: http://192.168.1.12/projeqtor/view/main.php
[Wed Nov 26 14:26:54.749764 2014] [:error] [pid 5208:tid 1688] [client 192.168.1.58:49600] PHP 1. {main}() C:\\wamp\\www\\projeqtor\\tool\\cronRun.php:0, referer: http://192.168.1.12/projeqtor/view/main.php
[Wed Nov 26 14:26:54.749764 2014] [:error] [pid 5208:tid 1688] [client 192.168.1.58:49600] PHP 2. Cron::run() C:\\wamp\\www\\projeqtor\\tool\\cronRun.php:6, referer: http://192.168.1.12/projeqtor/view/main.php
26 Nov 2014 18:28 #8 by babynus
Replied by babynus on topic Cron stops
Try and update your php.ini
safe_mode=off
27 Nov 2014 23:30 #9 by ndusch
it was set :
safe_mode=off
28 Nov 2014 10:44 #10 by babynus
Can you look for
disable_functions
in php.ini
You should not have something like
disable_functions = set_time_limit
Remove if you have it.
28 Nov 2014 12:24 #11 by ndusch
sorry to annoy you with this topic.
There is nothing with disable function!
28 Nov 2014 15:23 #12 by babynus
Sorry, no more idea.
What is sure, is that is comes from your PHP settings.
Maybe you can try another xAMP stack, at least for testing purpose.
