ProjeQtOr free project management software - Cron stops - ProjeQtOr
Cron stops
21 Nov 2014 16:03 - 26 Nov 2014 08:47 #1 by ndusch
Cron stops was created by ndusch
Hello Babynus,
Cron stops with the following reason and doesn t restart anymore.
Fri Nov 21 14:26:14.222055 2014] [:error] [pid 4496:tid 1736] [client 192.168.1.58:58603] PHP Fatal error: Maximum execution time of 30 seconds exceeded in C:\\wamp\\www\\projeqtor\\model\\Cron.php on line 302, referer: http://192.168.1.12/projeqtor/view/main.php
We cannot define if this is caused by Apache or Projeqtor.
Do you have any idea for thus issue please?
Regards, ND
Last edit: 26 Nov 2014 08:47 by protion.
21 Nov 2014 20:23 #2 by babynus
Replied by babynus on topic Cron stops
Most possible your PHP is running in safe mode.
In this mode set_time_limit(0) has no effect.
23 Nov 2014 20:49 #3 by ndusch
Replied by ndusch on topic Cron stops
PHP is not running in safe mode.
Any other idea?
23 Nov 2014 23:29 #4 by babynus
Chech log file for warning.
Do you have message such as :
WARNING : try to extend time limit to 0 seconds forbidden by safe_mode. This may lead to unsuccessfull operation.
Try and test some php code to check that
set_time_limit(0);
works fine and extends php running time to unlimited.
24 Nov 2014 10:12 #5 by ndusch
Thanks for your quick reply.
I don t find the message warning in logs.
And I m not skilled enough to run test php code.
I don t find the string "set_time_limit" in any files of wamp folder!!! Is this strange or not?
24 Nov 2014 19:13 - 24 Nov 2014 19:19 #6 by babynus
Try the attached script (after unzipping and copying into your web directory)
Run it from a browser.
It should result in something like :
SET REPORTING LEVEL TO GET ALL ERRORS
SET TIME LIMIT TO UNLIMITED EXECUTION
OK, NEW TIME LIMIT ACCEPTED BY PHP
SCRIPT RUNNING FOR 0 S
SCRIPT RUNNING FOR 10 S
SCRIPT RUNNING FOR 20 S
SCRIPT RUNNING FOR 30 S
SCRIPT RUNNING FOR 40 S
SCRIPT RUNNING FOR 50 S
SCRIPT RUNNING FOR 60 S
SCRIPT RUNNING FOR 70 S
SCRIPT RUNNING FOR 80 S
SCRIPT RUNNING FOR 90 S
SCRIPT RUNNING FOR 100 S
SCRIPT RUNNING FOR 110 S
never ending
If it stops after 30 seconds, it means set_time_limit(0) failed. This is the case when PHP is in safe mode.
Try and change php.ini
max_execution_time = 300
but this is only for testing, as it is not good practice to keep it to zero in production mode.
You may also face some time limit defined in Apache or IIS.
Last edit: 24 Nov 2014 19:19 by babynus.
