ProjeQtOr free project management software - Browser display issue ? - ProjeQtOr
07 Nov 2013 09:52 #1 by selina
I used your project'Or RIA for almost 2 years and the version I used is V1.5.5.
Since I did some code modifications and I also don't need new features from new versions, I don't upgrade the versions for a long time.
Now I have a display problem. I found that after I upgrade the browser ( firefox from v13 to v25, chrome to v30), I can't see the pages of the right side.
Tickets, Activities, real work allocation...etc. are all invisible. It's too terrible that I can't no longer do my task assignment again.
I checked with your new version of projeQtOr demo site, it displays w/o problem. I'd like to know what codes/files might needs to be updated.
I only want to resolve the display issue.
Please kindly help. Thanks in advance.
07 Nov 2013 12:49 #2 by climb4fun
Replied by climb4fun on topic Browser display issue ?
Hi Selina,
may, could you post a screenshot with the issue you mentioned?
Klaus
07 Nov 2013 20:21 #3 by babynus
Replied by babynus on topic Browser display issue ?
Hi Selina,
There were so many fixes since V1.5.5 that I cannot tell you which one will solve your issue.
The easyest way I can advise is :
- retrieve the standard V1.5.5
- compare it to your own version to get identify all the changes you made
- report your changed to V4.0.0
Eclipse with SVN plugin (or other SVN tool) can help you :
- retrieve the standard V1.5.5 from SVN repository, branch 1.5 : svn://svn.code.sf.net/p/projectorria/code/
- paste your own code over retrieved one
- create patch
- retrieve the last version (branch 4.0) : svn checkout svn://svn.code.sf.net/p/projectorria/code/ projectorria-code
- apply your patch to your version
You may have to fix some parts, but I think it will be the easyest to do.
11 Nov 2013 07:24 #4 by selina
Replied by selina on topic Browser display issue ?
Please check the attached screenshot.
11 Nov 2013 07:30 #5 by selina
Hi babynus,
Do you think it's related to css or dojo version?
11 Nov 2013 07:32 #6 by selina
it seems that file can't be attached.
But you can imagine that there's left hand side tool bars but with every click on the link (Action, Activity, Ticket..), right hand side appears nothing, a totally blank page.
