ProjeQtOr free project management software - Browser display issue ? - Page 3 - ProjeQtOr
13 Nov 2013 01:24 #13 by selina
13 Nov 2013 11:02 #14 by babynus
Replied by babynus on topic Browser display issue ?
I can only note the issue.
Whithout any error logged, it will be a mess to debug.
I tried standard V1.5.5 and could reproduce the issue.
I'm afraid Dojo version used on this version in not compatible with recent browsers.
That is why I always tried to include latest Dojo version in Project'Or RIA releases.
I also tried to include latest version of dojo in V1.5.5, but result is even worse.
I often had to update code to garanty the compatibility.
I advice you to consider migrating to ProjeQtOr V4.0 (or V3.4.4) and integrated your updates on this version.
Regards.
Babynus.
18 Nov 2013 08:19 #15 by selina
Replied by selina on topic Browser display issue ?
I tried to follow your suggestion, but when I put V4.0 and open the first page. It appears nothing and apache log said:
PHP Fatal error: Class 'Parameter' not found in /home/selina/projectorria_v4.0/tool/config.php on line 302, referer: http://192.168.1.1/projeqtor/
my php version:
php -v
PHP 5.1.6 (cli) (built: Jun 27 2012 12:21:16)
Copyright (c) 1997-2006 The PHP Group
Zend Engine v2.1.0, Copyright (c) 1998-2006 Zend Technologies
What might be wrong with the installation?
18 Nov 2013 11:13 #16 by babynus
PHP 5.2 or over is required.
(see techniqcal requirements in README file and Description / Techniqcal on this side).
What is strange is that you seem to face issue with spl_autoload_register function, which is valid since 5.1.2.
Lease try 5.2 (or over).
Regards.
25 Nov 2013 05:28 #17 by selina
I upgrade the dojo/dojox/dijit to the version of projector v4.0.2 and modified login.php and main.php
and then I can see the right side of the page.
But in "Activities" page, when I want to add resource to the "Assignment" table, I got error in javascript console:
this.store.query is not a function" and the resource dialog can't pop up.
Do you know where and how to modify the codes?
Thanks for help.
25 Nov 2013 09:57 #18 by babynus
I'm afraid it will be a mess to fix.
I did it long time ago, to adapt all stores to new Dojo format.
This can be found on Grid management, using stores,
and on all "refreshList" functions.
The easiest is to start from issue : you should have line of code where issue appears.
Then try to investigate on object in cause, with lot of console.log to trace what happens.
But it will be quite long and you'll not be sure to treat all possible issues.
I reiterate, once again my advise : try to migrate to latest community version and réintegrate your own changes.
I think it will be much more easy than trying to fix your own code frol old community version.
Best way :
- compare your existing code to standard version not updated (V1.5.5), and generate a SVN Patch.
- apply your patch to laster version (V4.0.3).
