ProjeQtOr free project management software - error WBS project-Periode Absence - ProjeQtOr
20 Dec 2022 15:01 #1 by pdecloedt
I've a problem with a wbs on ADM project, the Periode D'Absence project linked by 4 differents Activities.
you will see in attached files a screen shot oh search error result.
in fact, we discover this probleme because we cannot imput our on few different project.
20 Dec 2022 17:15 #2 by pdecloedt
20 Dec 2022 18:16 #3 by babynus
One way to fix this :
  • Change project type, so that your roject is not administrative any more
  • On gantt chart, move your project to change its WBS.
  • Move it back to expected place
  • Change back project type to administrative.
20 Dec 2022 18:36 #4 by pdecloedt
I could not change type project
It doesn't appears on project list and gantt chart...
It only appears on Imputation
22 Dec 2022 10:45 #5 by babynus
So it is you Leave Management Project...
This was fixed recently, as this project now gets WBS 0.
Which version are you using ?
23 Dec 2022 07:51 - 23 Dec 2022 07:54 #6 by pdecloedt
I try to change the WBS to 0 for the leave project, system don't want! so the leave project is on WBS 16 (the last)
I discovered another strange phenomenon: in the allocation sheet, all the projects that are under a project with a padlock are grayed out, impossible to enter time.
see attached screenshot, under BSEAxxxxx-Project Name all are grayed
Last edit: 23 Dec 2022 07:54 by pdecloedt.
Time to create page: 0.074 seconds
