ProjeQtOr free project management software - error WBS project-Periode Absence - Page 2 - ProjeQtOr
25 Sep 2023 15:34 #7 by loicr
Dear Projeqtor Team,
we have same problem since last week ( same red errors ! ) with following logs error :
2023-09-25 13:52:09.121 ***** ERROR ***** [V11.0.0] Exception-[HY000] SQLSTATE[HY000]: General error: 3065 Expression #1 of ORDER BY clause is not in SELECT list, references column 'projeqtor.st.sortOrder' which is not in SELECT list; this is incompatible with DISTINCT
2023-09-25 13:52:09.121 ***** ERROR ***** [V11.0.0] For query : SELECT DISTINCT st.name from status as st
left JOIN workflow as wf on wf.isLeaveWorkflow = 1
left join workflowstatus as wfs on wfs.idWorkflow = wf.id
where st.id = wfs.idStatusFrom or st.id = wfs.idStatusTo ORDER by st.sortOrder;
2023-09-25 13:52:09.121 ***** ERROR ***** [V11.0.0] Strack trace :
2023-09-25 13:52:09.122 ***** ERROR ***** [V11.0.0] #0 Sql->query called at [/var/www/projeqtor/model/LeaveTypeMain.php:736]
2023-09-25 13:52:09.122 ***** ERROR ***** [V11.0.0] #1 LeaveTypeMain->drawSendInfo called at [/var/www/projeqtor/model/LeaveTypeMain.php:1080]
2023-09-25 13:52:09.122 ***** ERROR ***** [V11.0.0] #2 LeaveTypeMain->drawSpecificItem called at [/var/www/projeqtor/view/objectDetail.php:1184]
2023-09-25 13:52:09.122 ***** ERROR ***** [V11.0.0] #3 drawTableFromObject called at [/var/www/projeqtor/view/objectDetail.php:368]
2023-09-25 13:52:12.230 ***** ERROR ***** [V11.0.0] Exception-[HY000] SQLSTATE[HY000]: General error: 3065 Expression #1 of ORDER BY clause is not in SELECT list, references column 'projeqtor.st.sortOrder' which is not in SELECT list; this is incompatible with DISTINCT
2023-09-25 13:52:12.230 ***** ERROR ***** [V11.0.0] For query : SELECT DISTINCT st.name from status as st
2023-09-25 13:52:12.230 ***** ERROR ***** [V11.0.0] Strack trace :
2023-09-25 13:52:12.230 ***** ERROR ***** [V11.0.0] #0 Sql->query called at [/var/www/projeqtor/model/LeaveTypeMain.php:736]
2023-09-25 13:52:12.230 ***** ERROR ***** [V11.0.0] #1 LeaveTypeMain->drawSendInfo called at [/var/www/projeqtor/model/LeaveTypeMain.php:1080]
2023-09-25 13:52:12.231 ***** ERROR ***** [V11.0.0] #2 LeaveTypeMain->drawSpecificItem called at [/var/www/projeqtor/view/objectDetail.php:1184]
2023-09-25 13:52:12.231 ***** ERROR ***** [V11.0.0] #3 drawTableFromObject called at [/var/www/projeqtor/view/objectDetail.php:368]
2023-09-25 13:52:14.385 ***** ERROR ***** [V11.0.0] Exception-[HY000] SQLSTATE[HY000]: General error: 3065 Expression #1 of ORDER BY clause is not in SELECT list, references column 'projeqtor.st.sortOrder' which is not in SELECT list; this is incompatible with DISTINCT
2023-09-25 13:52:14.385 ***** ERROR ***** [V11.0.0] For query : SELECT DISTINCT st.name from status as st
Thanks for your support.
I'm not able to move project "leave" cause it is hiden ... and modification on WBS on database doesn't work. ( actualy NULL )
lr
28 Sep 2023 18:48 #8 by babynus
First, this is not the same issue.
Second, please do not post an issue on a SOLVED thread (you take the risk it is never read).
28 Sep 2023 19:03 #9 by babynus
The error logged concerns some code that has not change for long...
Moreover, the SQL query pointed out in error runs fine on MySql.
So I guess you are using PostgreSql.
Did you migrate DB recently ?
Please indicate used DB / Version.
29 Sep 2023 08:17 #10 by loicr
Dear Babynus,
we are under mysql , the only thing we've done is migrate last week to v11.0.0 and update our ressources ( expecialy end of contract for 2 of them )
mysql --version
mysql Ver 8.0.34-0ubuntu0.22.04.1 for Linux on x86_64 ((Ubuntu))
Sincerely
LR
