ProjeQtOr free project management software - First startup of Projeqtor blocked - ProjeQtOr
08 May 2022 09:11 #1 by Nourouddini
I would like your help to start Projeqtor.
After configuration and connection with "admin". the startup process is blocked as shown in the image below. I have left it running for more than 6 hours.
Thank you
Nourouddini
09 May 2022 11:33 #2 by babynus
Can you please check for errors in projeqtor log file and in browser console ?
(and post here errors found)
09 May 2022 16:05 #3 by Nourouddini
2022-05-09 12:36:35.175 ===== TRACE ===== NEW CONNECTED USER 'admin'
2022-05-09 12:36:48.757 ***** ERROR ***** [V9.5.3] ERROR *****
2022-05-09 12:36:48.762 ***** ERROR ***** [V9.5.3] on file 'C:\xampp\htdocs\projeqtor\view\menuUserTop.php' at line (130)
2022-05-09 12:36:48.763 ***** ERROR ***** [V9.5.3] cause = ucfirst(): Passing null to parameter #1 ($string) of type string is deprecated
09 May 2022 16:38 #4 by babynus
Check prerequisites !
Projeqtor V9.5 is NOT compatible with PHP 8.1
03 Jun 2022 20:42 #5 by gauvain
I disagree with you @Babynus: the page "technical prerequisites" clearly states that Projeqtor v9.5+ supports PHP8.1.
URL: <www.projeqtor.org/fr/product-fr/technica...uct-prerequisites-fr>
But indeed, I had the same problem when I deployed Projeqtor on PHP 8.1...
03 Jun 2022 20:45 #6 by gauvain
I add a screenshot of the prerequisites page.
