ProjeQtOr free project management software - progress of an activity how to inform the progress of an activity I have read a - ProjeQtOr
12 Aug 2021 17:09 #1 by chaours
progress of an activity how to inform the progress of an activity I have read and reread the manual I can only find descriptions of the panels but I cannot understand how to inform in the steering section the percentage of progress ...? Thanks for your feedback.
progres d'une activité
comment faire pour renseigner le progres d'une activité j'ai lu et relu le manuel je ne trouve que des description des panneaux mais je n'arrive pas à comprendre comment renseigner dans la section pilotage les pourcentage d'avancement ... ? merci pour votre retour.
12 Aug 2021 17:36 #2 by babynus
Projeqtor is work driven (effort driven) : when you enter real work, progress is updated.
You can also activate "manual progress for fix duration activities" is global parameters if you don't want to manage real work
12 Aug 2021 17:51 - 12 Aug 2021 17:55 #3 by chaours
ok thanks but it's grayed out in the real box
ok merci mais c'est grisé dans la case réel
Last edit: 12 Aug 2021 17:55 by chaours.
12 Aug 2021 18:02 #4 by babynus
Real work must be entered through timesheet
12 Aug 2021 18:15 #5 by chaours
thank you for this feedback, and "manual progress for fix duration activities" where should we enter it?
merci pour ce retour, et "manual progress for fix duration activities" où doit on le rentrer ?
13 Aug 2021 09:10 #6 by alainforma
global parameters / activity / planning / The fourth line.
