ProjeQtOr free project management software - progress of an activity how to inform the progress of an activity I have read a - Page 2 - ProjeQtOr
13 Aug 2021 10:26 #7 by chaours
yes thank you that I found it, no actually I wanted to talk about the percentage of completion
oui merci ça je l'avais trouvé, non en fait je voulais parler des pourcentage d'avancement
13 Aug 2021 10:39 #8 by alainforma
it is donne automaticly depending on real work and left work (revisable)
DONE WORKLOAD / (DONE WORKLOAD + LEFT WORK ) = REAL PROGRESS
simple as ABC.
so this rate could be fluctuant.
13 Aug 2021 10:43 - 13 Aug 2021 10:45 #9 by chaours
I often see "left work" written, but what is it?
PS: where does the real work fit? at home the box is grayed out ... thank you
je vois souvent écris "travail de gauche" mais de quoi s'agit il ?
PS : où se rentre le travail réel ? chez moi la case est grisée...merci
Last edit: 13 Aug 2021 10:45 by chaours.
13 Aug 2021 11:26 #10 by alainforma
enter some real work on a line in timesheet.  leftwork will  especially decrease.
you can change manually this leftwork.
this left work will be planified each time you use the calculation
it is endless until the leftwork is zero
Always plan as the day.
