ProjeQtOr free project management software - PHP-IMAP Extension replacement/alternatives - Page 2 - ProjeQtOr
28 Apr 2024 20:15 #7 by babynus
This is not really in the scope.
But we plan to improve our imap model to allow oAuth2 authentification, so Webklex/php-imap may be an aternative
29 Apr 2024 12:51 #8 by g.jibrane@anfh.fr
I switched to php8.2 remi.
Unfortunately it's worst.
Sending SMTP doesn't work anymore:
2024-04-29 12:42:17.871 ***** ERROR ***** [V10.3.6] PHPMail error : SMTP connect() failed. github.com/PHPMailer/PHPMailer/wiki/Troubleshooting
2024-04-29 12:42:17.871 ***** ERROR ***** [V10.3.6] PHPMail debug :
Troubleshooting tells to not mix SMTPS or STARTTLS but there is no way to select one of these in Projeqtor 10.3.6.
29 Apr 2024 14:00 #9 by g.jibrane@anfh.fr
After switching to PHP 8.2, the first error was :
2024-04-29 10:58:25.811 ***** ERROR ***** [V10.3.6] cause = nl2br(): Passing null to parameter #1 ($string) of type string is deprecated
As the first null parameter was username, I set username/password and error became 'smtp failed to connect'.
I followed troubleshooting all was ok except missing sendmail (not neede in php 8.0).
But still error smtp.
I have deleted user/password and it WORKS. PHP8.2 need sendmail.
It seems when you set username/password in Projeqtor, it activates encryption but you cannot select STARTTLS against SMTPS. I don't know how Projeqtor select one.
I hope this is not based on port number because we use a custom port xx25, for internal mailing.
29 Apr 2024 14:11 - 29 Apr 2024 14:12 #10 by babynus
If you set smtp server  to localhost, yes sendmail is required.
If you sent it to another server, this server requires some smtp sending method (sendmail or else)
This is not specific to PHP8.2
You can, just specify protocole on server name : tls://yourserver or ssl://yourserver
Last edit: 29 Apr 2024 14:12 by babynus.
29 Apr 2024 14:17 #11 by g.jibrane@anfh.fr
I do not use localhost and I needed sendmail in 8.2 like in
www.projeqtor.org/fr/forum-fr/5-ask-ques...side-projeqtor#37354
29 Apr 2024 14:25 #12 by g.jibrane@anfh.fr
I tried tls:// to use STARTTLS but smtp failed
