ProjeQtOr free project management software - PHP-IMAP Extension replacement/alternatives - ProjeQtOr
19 Jun 2021 09:36 #1 by VERNCon
It appears that PHP-IMAP Extension is finished, at least for Fedora branch, as of PHP 7.4. See bugzilla.redhat.com/show_bug.cgi?id=1956278
Is there any alternative package which is being considered for Projeqtor, from PHP 8.0 and beyond?
Cheers.
19 Jun 2021 11:57 #2 by babynus
We do not plan to replace php-imap.
It would be a great work on projeqtor, and php-imap is removed only from some distro (Fedora, OpenSuse) which are mostly used for desktops rather than for servers.
You can retreive php-imap from external sources (fedora.pkgs.org/34/remi-x86_64/php74-php...remi.x86_64.rpm.html)
17 Apr 2024 18:21 #3 by g.jibrane@anfh.fr
php-imap isn't available on servers too.
For example all Entreprise Linux based :
Red Hat, CentOS, Rocky... and in my case Oracle Linux.
There is security issue in the thread management.
Tried Remi but can't be installed because system doesn't match prerequistes by design.
Want to try PECL but need PHP 8.3.
Projeqtor compatibility matrix doesn't hnow PHP 8.3.
What do you suggest ?
19 Apr 2024 15:52 #4 by babynus
Projeqtor compatibility matrix doesn't snow PHP 8.3.
PHP8.3 compatibility comes with ProjeQtOr V11.2, which becomes stable today with ptch 11.2.2.
19 Apr 2024 15:57 #5 by babynus
PHP-IMAP shoumd not be required on PHP8.1 as it is included in the Core.
It will be moved to PECL in PHP8.4 (php.watch/versions/8.4/imap-unbundled)
26 Apr 2024 18:30 #6 by g.jibrane@anfh.fr
It is not in the core of php 8.1 for Entreprise Linux.
Do you intend to implement Webklex/php-imap ?
