ProjeQtOr free project management software - [SOLVED] Installation does not continue and I do not know where it is stuck. No error mes - Page 2 - ProjeQtOr
05 Feb 2020 15:56 #7 by ReneW
:unsure:
main.php:1 Unchecked runtime.lastError: The message port closed before a response was received.
dojo.js?version=V8.3.1.0249:2 [Deprecation] Synchronous XMLHttpRequest on the main thread is deprecated because of its detrimental effects to the end user's experience. For more help, check xhr.spec.whatwg.org/.
req.getText @ dojo.js?version=V8.3.1.0249:2
/projeqtor/tool/configCheck.php?destinationWidth=1331&destinationHeight=65&isIE=&xhrPostDestination=configResultDiv&xhrPostIsResultMessage=false&xhrPostValidationType=&xhrPostTimestamp=1580914098821:1 Failed to load resource: the server responded with a status of 403 (Forbidden)
projeqtor.js?version=V8.3.1.0249:835 Error while calling xhrPost for loadContent()
warnLoadContentError @ projeqtor.js?version=V8.3.1.0249:835
projeqtor.js?version=V8.3.1.0249:836 => page='../tool/configCheck.php?destinationWidth=1331&destinationHeight=65&isIE=&xhrPostDestination=configResultDiv&xhrPostIsResultMessage=false&xhrPostValidationType=&xhrPostTimestamp=1580914098821'
warnLoadContentError @ projeqtor.js?version=V8.3.1.0249:836
projeqtor.js?version=V8.3.1.0249:837 => destination='configResultDiv'
warnLoadContentError @ projeqtor.js?version=V8.3.1.0249:837
projeqtor.js?version=V8.3.1.0249:838 => formName'configForm'
warnLoadContentError @ projeqtor.js?version=V8.3.1.0249:838
projeqtor.js?version=V8.3.1.0249:839 => isResultMessage='null'
warnLoadContentError @ projeqtor.js?version=V8.3.1.0249:839
projeqtor.js?version=V8.3.1.0249:840 => validationType='null'
warnLoadContentError @ projeqtor.js?version=V8.3.1.0249:840
projeqtor.js?version=V8.3.1.0249:841 => directAccess='null'
warnLoadContentError @ projeqtor.js?version=V8.3.1.0249:841
projeqtor.js?version=V8.3.1.0249:842 => silent='null'
warnLoadContentError @ projeqtor.js?version=V8.3.1.0249:842
projeqtor.js?version=V8.3.1.0249:843 => callBackFunction='?'
warnLoadContentError @ projeqtor.js?version=V8.3.1.0249:843
projeqtor.js?version=V8.3.1.0249:844 => noFading='undefined'
warnLoadContentError @ projeqtor.js?version=V8.3.1.0249:844
projeqtor.js?version=V8.3.1.0249:1220 _4b9message: "Unable to load ../tool/configCheck.php?destinationWidth=1331&destinationHeight=65&isIE=&xhrPostDestination=configResultDiv&xhrPostIsResultMessage=false&xhrPostValidationType=&xhrPostTimestamp=1580914098821 status: 403"response: {url: "../tool/configCheck.php?destinationWidth=1331&dest…ostValidationType=&xhrPostTimestamp=1580914098821", options: TMP, xhr: XMLHttpRequest, transferType: "download", getHeader: ƒ, …}status: 403responseText: "<HTML>↵<HEAD>↵<TITLE>403 Forbidden</TITLE>↵</HEAD>↵<BODY>↵<H1>Forbidden</H1>↵You do not have permission to access this document.↵<P>↵<HR>↵<ADDRESS>↵Web Server at .de↵</ADDRESS>↵</BODY>↵</HTML>↵↵<!--↵ - Unfortunately, Microsoft has added a clever new↵ - "feature" to Internet Explorer. If the text of↵ - an error's message is "too small", specifically↵ - less than 512 bytes, Internet Explorer returns↵ - its own error message. You can turn that off,↵ - but it's pretty tricky to find switch called↵ - "smart error messages". That means, of course,↵ - that short error messages are censored by default.↵ - IIS always returns error messages that are long↵ - enough to make Internet Explorer happy. The↵ - workaround is pretty simple: pad the error↵ - message with a big comment like this to push it↵ - over the five hundred and twelve bytes minimum.↵ - Of course, that's exactly what you're reading↵ - right now.↵ -->↵"xhr: XMLHttpRequestonreadystatechange: nullreadyState: 4timeout: 0withCredentials: falseupload: XMLHttpRequestUpload {onloadstart: null, onprogress: null, onabort: null, onerror: null, onload: null, …}responseURL: "https://.de/projeqtor/tool/configCheck.php?destinationWidth=1331&destinationHeight=65&isIE=&xhrPostDestination=configResultDiv&xhrPostIsResultMessage=false&xhrPostValidationType=&xhrPostTimestamp=1580914098821"status: 403statusText: "Forbidden"responseType: ""response: "↵↵403 Forbidden↵↵↵
Forbidden
↵Web Server at .de↵
↵↵↵↵↵"responseText: "↵↵403 Forbidden↵↵↵
Forbidden
↵Web Server at .de↵
↵↵↵↵↵"responseXML: nullonloadstart: nullonprogress: nullonabort: nullonerror: nullonload: nullontimeout: nullonloadend: null__proto__: XMLHttpRequeststack: "Error: Unable to load ../tool/configCheck.php?destinationWidth=1331&destinationHeight=65&isIE=&xhrPostDestination=configResultDiv&xhrPostIsResultMessage=false&xhrPostValidationType=&xhrPostTimestamp=1580914098821 status: 403↵ at new _4b9 (https://.de/projeqtor/external/dojo/dojo.js?version=V8.3.1.0249:2:127991)↵ at _3fa._31c [as handleResponse] (https://.de/projeqtor/external/dojo/dojo.js?version=V8.3.1.0249:2:85741)↵ at XMLHttpRequest._32a (https://.de/projeqtor/external/dojo/dojo.js?version=V8.3.1.0249:2:86177)"__proto__: Error
error @ projeqtor.js?version=V8.3.1.0249:1220
dojo.js?version=V8.3.1.0249:2 _4b9message: "Unable to load ../tool/configCheck.php?destinationWidth=1331&destinationHeight=65&isIE=&xhrPostDestination=configResultDiv&xhrPostIsResultMessage=false&xhrPostValidationType=&xhrPostTimestamp=1580914098821 status: 403"response: {url: "../tool/configCheck.php?destinationWidth=1331&dest…ostValidationType=&xhrPostTimestamp=1580914098821", options: TMP, xhr: XMLHttpRequest, transferType: "download", getHeader: ƒ, …}status: 403responseText: "<HTML>↵<HEAD>↵<TITLE>403 Forbidden</TITLE>↵</HEAD>↵<BODY>↵<H1>Forbidden</H1>↵You do not have permission to access this document.↵<P>↵<HR>↵<ADDRESS>↵Web Server at .de↵</ADDRESS>↵</BODY>↵</HTML>↵↵<!--↵ - Unfortunately, Microsoft has added a clever new↵ - "feature" to Internet Explorer. If the text of↵ - an error's message is "too small", specifically↵ - less than 512 bytes, Internet Explorer returns↵ - its own error message. You can turn that off,↵ - but it's pretty tricky to find switch called↵ - "smart error messages". That means, of course,↵ - that short error messages are censored by default.↵ - IIS always returns error messages that are long↵ - enough to make Internet Explorer happy. The↵ - workaround is pretty simple: pad the error↵ - message with a big comment like this to push it↵ - over the five hundred and twelve bytes minimum.↵ - Of course, that's exactly what you're reading↵ - right now.↵ -->↵"xhr: XMLHttpRequestonreadystatechange: nullreadyState: 4timeout: 0withCredentials: falseupload: XMLHttpRequestUploadonloadstart: nullonprogress: nullonabort: nullonerror: nullonload: nullontimeout: nullonloadend: null__proto__: XMLHttpRequestUploadonloadstart: (...)onprogress: (...)onabort: (...)onerror: (...)onload: (...)ontimeout: (...)onloadend: (...)constructor: ƒ XMLHttpRequestUpload()Symbol(Symbol.toStringTag): "XMLHttpRequestUpload"__proto__: XMLHttpRequestEventTargetresponseURL: "https://.de/projeqtor/tool/configCheck.php?destinationWidth=1331&destinationHeight=65&isIE=&xhrPostDestination=configResultDiv&xhrPostIsResultMessage=false&xhrPostValidationType=&xhrPostTimestamp=1580914098821"status: 403statusText: "Forbidden"responseType: ""response: "↵↵403 Forbidden↵↵↵
Forbidden
↵Web Server at .de↵
Forbidden
↵Web Server at .de↵
↵↵↵↵↵"responseXML: nullonloadstart: nullonprogress: nullonabort: nullonerror: nullonload: nullontimeout: nullonloadend: null__proto__: XMLHttpRequestonreadystatechange: (...)readyState: (...)timeout: (...)withCredentials: (...)upload: (...)responseURL: (...)status: (...)statusText: (...)responseType: (...)response: (...)responseText: (...)responseXML: (...)onloadstart: (...)onprogress: (...)onabort: (...)onerror: (...)onload: (...)ontimeout: (...)onloadend: (...)UNSENT: 0OPENED: 1HEADERS_RECEIVED: 2LOADING: 3DONE: 4open: ƒ open()setRequestHeader: ƒ setRequestHeader()send: ƒ (t)abort: ƒ abort()getResponseHeader: ƒ getResponseHeader()getAllResponseHeaders: ƒ getAllResponseHeaders()overrideMimeType: ƒ overrideMimeType()constructor: ƒ XMLHttpRequest()Symbol(Symbol.toStringTag): "XMLHttpRequest"get onreadystatechange: ƒ onreadystatechange()set onreadystatechange: ƒ onreadystatechange()get readyState: ƒ readyState()get timeout: ƒ timeout()set timeout: ƒ timeout()get withCredentials: ƒ withCredentials()set withCredentials: ƒ withCredentials()get upload: ƒ upload()get responseURL: ƒ responseURL()get status: ƒ status()get statusText: ƒ statusText()get responseType: ƒ responseType()set responseType: ƒ responseType()get response: ƒ response()get responseText: ƒ responseText()get responseXML: ƒ responseXML()__proto__: XMLHttpRequestEventTargetstack: "Error: Unable to load ../tool/configCheck.php?destinationWidth=1331&destinationHeight=65&isIE=&xhrPostDestination=configResultDiv&xhrPostIsResultMessage=false&xhrPostValidationType=&xhrPostTimestamp=1580914098821 status: 403↵ at new _4b9 (https://.de/projeqtor/external/dojo/dojo.js?version=V8.3.1.0249:2:127991)↵ at _3fa._31c [as handleResponse] (https://.de/projeqtor/external/dojo/dojo.js?version=V8.3.1.0249:2:85741)↵ at XMLHttpRequest._32a (https://.de/projeqtor/external/dojo/dojo.js?version=V8.3.1.0249:2:86177)"__proto__: Errorname: "RequestError"constructor: ƒ (_4ba)__proto__: Object
_3d8 @ dojo.js?version=V8.3.1.0249:2
content.js:1 [Violation] 'setInterval' handler took 187ms
05 Feb 2020 16:11 #8 by babynus
Your web server is not configured to allow acces to whole projector structure.
Most common issue is that php user is not owner of files and access rights are too restrictive.
Exemple on ubuntu
chown www-data: -R /var/www/html/projeqtor
chmod 755: -R /var/www/html/projeqtor
05 Feb 2020 16:15 #9 by ReneW
Exemple on ubuntu
OK, thx.i check or later, i'm outsite from my Office.
05 Feb 2020 16:47 #10 by EricG-RC
Sorry
To clarify the nothing:
The completed form is displayed but nothing more when I do ok I return to the form and if I look on the database server no request has been transmitted.
05 Feb 2020 17:03 #11 by babynus
It is normal at this step.
Database updates are done at the next step.
If all is OK, you shoumd bget a button "continue".
Otherwise, you should get an error on the screen, or on log file (projeqtor or php) or on browser console.
06 Feb 2020 10:28 #12 by EricG-RC
OK but i don't have the button "Continue" and no error displayed
