ProjeQtOr free project management software - [SOLVED] Installation does not continue and I do not know where it is stuck. No error mes - Page 3 - ProjeQtOr
06 Feb 2020 10:42 #13 by EricG-RC
Can you say me where is the logs files ?
Thank's for your help
06 Feb 2020 14:46 #14 by babynus
On ubuntu, you'll have logs in /var/log
You may have logs for PHP and/or for Apache.
06 Feb 2020 16:27 #15 by EricG-RC
Thank you
We are seeing authentication errors from our database user.
We have characters of the type; or \ in the password of this user
Is this type of character supported in a PHP form?
Thank you for your help
07 Feb 2020 15:37 #16 by babynus
If you have à \, I guess you have to double it on the definition string
replace $dbPassword="ok\notOk";
with $dbPassword="ok\\notOk";
Otherwise \ is considered as "protection" for next character.
The following user(s) said Thank You: EricG-RC
10 Feb 2020 08:02 - 11 Feb 2020 12:13 #17 by EricG-RC
Thank's it's OK for me
Problem with password and user's rights for the directory projeqtor
Thank you for your help, we continue our tests
Last edit: 11 Feb 2020 12:13 by EricG-RC.
