ProjeQtOr free project management software - Installation troubles on Ubuntu 16.04-18.x with xampp - Page 2 - ProjeQtOr
20 Jan 2020 11:06 - 20 Jan 2020 11:08 #7 by fred12345
/files/config/parametersLocation.php contains:
$parametersLocation = '../files/config/parameters.php';
File: /files/config/parameters.php contains:
$logFile = '../files/logs/projeqtor_${date}.log';
$logLevel = '2';
But I see the file contains the same data twice including: TEST<?php
So, maybe this file was broken?
Last edit: 20 Jan 2020 11:08 by fred12345.
20 Jan 2020 11:27 #8 by fred12345
So, now I can proceed to the login page.
But the message is shown before authorization: Upgrade in progress. Only admin user can connect.
After trying to login I get two more errors:
1) an error: An error occurred on 2020-01-20 at 11.22.43
2) "max_input_vars=1000 is too small - value should be at least 2000, 4000 recommended - check your php configuration (php.ini)"
Although the /opt/lampp/etc/php/ini has parameter: max_input_vars=4000
20 Jan 2020 12:27 #9 by babynus
Possibly PHP user has possibility to update file, but not to delete it ?
20 Jan 2020 12:29 #10 by babynus
This is completely normal.
Please post error logged in log file
This should not be a blocking error, just a warning (ping message, not red one)
This may be due to not restarting PHP (must be restarted to take into account changes in php.ini)
20 Jan 2020 13:28 - 20 Jan 2020 13:29 #11 by fred12345
Appeared the log file. New error time: 2020-01-20 13:23:40
2020-01-20 13:23:34.511 ***** ERROR ***** [] Exception-[42S02] SQLSTATE[42S02]: Base table or view not found: 1146 Table 'projeqtor.parameter' doesn't exist
2020-01-20 13:23:34.512 ***** ERROR ***** [] For query : select * from parameter where (idUser is null and idProject is null)
2020-01-20 13:23:34.512 ***** ERROR ***** [] Strack trace :
2020-01-20 13:23:34.512 ***** ERROR ***** [] #0 Sql->query called at [/opt/lampp/htdocs/model/persistence/SqlElement.php:2485]
2020-01-20 13:23:34.512 ***** ERROR ***** [] #1 SqlElement->getSqlElementsFromCriteria called at [/opt/lampp/htdocs/model/Parameter.php:1173]
2020-01-20 13:23:34.512 ***** ERROR ***** [] #2 Parameter->getGlobalParameter called at [/opt/lampp/htdocs/model/SSO.php:25]
2020-01-20 13:23:34.512 ***** ERROR ***** [] #3 SSO->isEnabled called at [/opt/lampp/htdocs/view/index.php:56]
2020-01-20 13:23:34.831 ***** ERROR ***** [] Exception-[42S02] SQLSTATE[42S02]: Base table or view not found: 1146 Table 'projeqtor.parameter' doesn't exist
2020-01-20 13:23:34.831 ***** ERROR ***** [] For query : select * from parameter where (idUser is null and idProject is null)
2020-01-20 13:23:34.831 ***** ERROR ***** [] Strack trace :
2020-01-20 13:23:34.831 ***** ERROR ***** [] #0 Sql->query called at [/opt/lampp/htdocs/model/persistence/SqlElement.php:2485]
2020-01-20 13:23:34.831 ***** ERROR ***** [] #1 SqlElement->getSqlElementsFromCriteria called at [/opt/lampp/htdocs/model/Parameter.php:1173]
2020-01-20 13:23:34.831 ***** ERROR ***** [] #2 Parameter->getGlobalParameter called at [/opt/lampp/htdocs/model/SSO.php:25]
2020-01-20 13:23:34.831 ***** ERROR ***** [] #3 SSO->isEnabled called at [/opt/lampp/htdocs/model/SSO.php:32]
2020-01-20 13:23:34.831 ***** ERROR ***** [] #4 SSO->isSamlEnabled called at [/opt/lampp/htdocs/tool/projeqtor.php:213]
2020-01-20 13:23:34.831 ***** ERROR ***** [] #5 require_once called at [/opt/lampp/htdocs/view/main.php:37]
2020-01-20 13:23:34.847 ***** ERROR ***** [] Exception-[42S02] SQLSTATE[42S02]: Base table or view not found: 1146 Table 'projeqtor.module' doesn't exist
2020-01-20 13:23:34.847 ***** ERROR ***** [] For query : select * from module where 1=1 order by module.sortOrder
2020-01-20 13:23:34.847 ***** ERROR ***** [] Strack trace :
2020-01-20 13:23:34.847 ***** ERROR ***** [] #0 Sql->query called at [/opt/lampp/htdocs/model/persistence/SqlElement.php:2485]
2020-01-20 13:23:34.847 ***** ERROR ***** [] #1 SqlElement->getSqlElementsFromCriteria called at [/opt/lampp/htdocs/model/Module.php:175]
2020-01-20 13:23:34.847 ***** ERROR ***** [] #2 Module->initializeModuleList called at [/opt/lampp/htdocs/model/Module.php:105]
2020-01-20 13:23:34.847 ***** ERROR ***** [] #3 Module->isModuleActive called at [/opt/lampp/htdocs/tool/projeqtor.php:4726]
2020-01-20 13:23:34.847 ***** ERROR ***** [] #4 isLeavesSystemActiv called at [/opt/lampp/htdocs/tool/projeqtor.php:4390]
2020-01-20 13:23:34.847 ***** ERROR ***** [] #5 formatIcon called at [/opt/lampp/htdocs/view/login.php:344]
2020-01-20 13:23:34.847 ***** ERROR ***** [] #6 include called at [/opt/lampp/htdocs/tool/projeqtor.php:285]
2020-01-20 13:23:34.847 ***** ERROR ***** [] #7 require_once called at [/opt/lampp/htdocs/view/main.php:37]
2020-01-20 13:23:35.782 ***** ERROR ***** [] Exception-[42S02] SQLSTATE[42S02]: Base table or view not found: 1146 Table 'projeqtor.parameter' doesn't exist
2020-01-20 13:23:35.783 ***** ERROR ***** [] For query : select * from parameter where (idUser is null and idProject is null)
2020-01-20 13:23:35.783 ***** ERROR ***** [] Strack trace :
2020-01-20 13:23:35.783 ***** ERROR ***** [] #0 Sql->query called at [/opt/lampp/htdocs/model/persistence/SqlElement.php:2485]
2020-01-20 13:23:35.783 ***** ERROR ***** [] #1 SqlElement->getSqlElementsFromCriteria called at [/opt/lampp/htdocs/model/Parameter.php:1173]
2020-01-20 13:23:35.783 ***** ERROR ***** [] #2 Parameter->getGlobalParameter called at [/opt/lampp/htdocs/model/SSO.php:25]
2020-01-20 13:23:35.783 ***** ERROR ***** [] #3 SSO->isEnabled called at [/opt/lampp/htdocs/model/SSO.php:32]
2020-01-20 13:23:35.783 ***** ERROR ***** [] #4 SSO->isSamlEnabled called at [/opt/lampp/htdocs/tool/projeqtor.php:213]
2020-01-20 13:23:35.783 ***** ERROR ***** [] #5 require_once called at [/opt/lampp/htdocs/tool/saveDataToSession.php:30]
2020-01-20 13:23:35.826 ***** ERROR ***** [] Exception-[42S02] SQLSTATE[42S02]: Base table or view not found: 1146 Table 'projeqtor.parameter' doesn't exist
2020-01-20 13:23:35.826 ***** ERROR ***** [] For query : select * from parameter where (idUser is null and idProject is null)
2020-01-20 13:23:35.826 ***** ERROR ***** [] Strack trace :
2020-01-20 13:23:35.826 ***** ERROR ***** [] #0 Sql->query called at [/opt/lampp/htdocs/model/persistence/SqlElement.php:2485]
2020-01-20 13:23:35.826 ***** ERROR ***** [] #1 SqlElement->getSqlElementsFromCriteria called at [/opt/lampp/htdocs/model/Parameter.php:1173]
2020-01-20 13:23:35.826 ***** ERROR ***** [] #2 Parameter->getGlobalParameter called at [/opt/lampp/htdocs/model/SSO.php:25]
2020-01-20 13:23:35.826 ***** ERROR ***** [] #3 SSO->isEnabled called at [/opt/lampp/htdocs/model/SSO.php:32]
2020-01-20 13:23:35.826 ***** ERROR ***** [] #4 SSO->isSamlEnabled called at [/opt/lampp/htdocs/tool/projeqtor.php:213]
2020-01-20 13:23:35.826 ***** ERROR ***** [] #5 require_once called at [/opt/lampp/htdocs/tool/saveDataToSession.php:30]
2020-01-20 13:23:35.862 ***** ERROR ***** [] Exception-[42S02] SQLSTATE[42S02]: Base table or view not found: 1146 Table 'projeqtor.parameter' doesn't exist
2020-01-20 13:23:35.862 ***** ERROR ***** [] For query : select * from parameter where (idUser is null and idProject is null)
2020-01-20 13:23:35.862 ***** ERROR ***** [] Strack trace :
2020-01-20 13:23:35.862 ***** ERROR ***** [] #0 Sql->query called at [/opt/lampp/htdocs/model/persistence/SqlElement.php:2485]
2020-01-20 13:23:35.862 ***** ERROR ***** [] #1 SqlElement->getSqlElementsFromCriteria called at [/opt/lampp/htdocs/model/Parameter.php:1173]
2020-01-20 13:23:35.862 ***** ERROR ***** [] #2 Parameter->getGlobalParameter called at [/opt/lampp/htdocs/model/SSO.php:25]
2020-01-20 13:23:35.862 ***** ERROR ***** [] #3 SSO->isEnabled called at [/opt/lampp/htdocs/model/SSO.php:32]
2020-01-20 13:23:35.862 ***** ERROR ***** [] #4 SSO->isSamlEnabled called at [/opt/lampp/htdocs/tool/projeqtor.php:213]
2020-01-20 13:23:35.862 ***** ERROR ***** [] #5 require_once called at [/opt/lampp/htdocs/tool/saveDataToSession.php:30]
2020-01-20 13:23:35.926 ***** ERROR ***** [] Exception-[42S02] SQLSTATE[42S02]: Base table or view not found: 1146 Table 'projeqtor.parameter' doesn't exist
2020-01-20 13:23:35.926 ***** ERROR ***** [] For query : select * from parameter where (idUser is null and idProject is null)
2020-01-20 13:23:35.926 ***** ERROR ***** [] Strack trace :
2020-01-20 13:23:35.926 ***** ERROR ***** [] #0 Sql->query called at [/opt/lampp/htdocs/model/persistence/SqlElement.php:2485]
2020-01-20 13:23:35.926 ***** ERROR ***** [] #1 SqlElement->getSqlElementsFromCriteria called at [/opt/lampp/htdocs/model/Parameter.php:1173]
2020-01-20 13:23:35.926 ***** ERROR ***** [] #2 Parameter->getGlobalParameter called at [/opt/lampp/htdocs/model/SSO.php:25]
2020-01-20 13:23:35.926 ***** ERROR ***** [] #3 SSO->isEnabled called at [/opt/lampp/htdocs/model/SSO.php:32]
2020-01-20 13:23:35.926 ***** ERROR ***** [] #4 SSO->isSamlEnabled called at [/opt/lampp/htdocs/tool/projeqtor.php:213]
2020-01-20 13:23:35.926 ***** ERROR ***** [] #5 require_once called at [/opt/lampp/htdocs/tool/saveDataToSession.php:30]
2020-01-20 13:23:35.958 ***** ERROR ***** [] Exception-[42S02] SQLSTATE[42S02]: Base table or view not found: 1146 Table 'projeqtor.parameter' doesn't exist
2020-01-20 13:23:35.958 ***** ERROR ***** [] For query : select * from parameter where (idUser is null and idProject is null)
2020-01-20 13:23:35.958 ***** ERROR ***** [] Strack trace :
2020-01-20 13:23:35.958 ***** ERROR ***** [] #0 Sql->query called at [/opt/lampp/htdocs/model/persistence/SqlElement.php:2485]
2020-01-20 13:23:35.958 ***** ERROR ***** [] #1 SqlElement->getSqlElementsFromCriteria called at [/opt/lampp/htdocs/model/Parameter.php:1173]
2020-01-20 13:23:35.958 ***** ERROR ***** [] #2 Parameter->getGlobalParameter called at [/opt/lampp/htdocs/model/SSO.php:25]
2020-01-20 13:23:35.958 ***** ERROR ***** [] #3 SSO->isEnabled called at [/opt/lampp/htdocs/model/SSO.php:32]
2020-01-20 13:23:35.958 ***** ERROR ***** [] #4 SSO->isSamlEnabled called at [/opt/lampp/htdocs/tool/projeqtor.php:213]
2020-01-20 13:23:35.958 ***** ERROR ***** [] #5 require_once called at [/opt/lampp/htdocs/tool/saveDataToSession.php:30]
2020-01-20 13:23:35.982 ***** ERROR ***** [] Exception-[42S02] SQLSTATE[42S02]: Base table or view not found: 1146 Table 'projeqtor.parameter' doesn't exist
2020-01-20 13:23:35.982 ***** ERROR ***** [] For query : select * from parameter where (idUser is null and idProject is null)
2020-01-20 13:23:35.982 ***** ERROR ***** [] Strack trace :
2020-01-20 13:23:35.982 ***** ERROR ***** [] #0 Sql->query called at [/opt/lampp/htdocs/model/persistence/SqlElement.php:2485]
2020-01-20 13:23:35.982 ***** ERROR ***** [] #1 SqlElement->getSqlElementsFromCriteria called at [/opt/lampp/htdocs/model/Parameter.php:1173]
2020-01-20 13:23:35.982 ***** ERROR ***** [] #2 Parameter->getGlobalParameter called at [/opt/lampp/htdocs/model/SSO.php:25]
2020-01-20 13:23:35.982 ***** ERROR ***** [] #3 SSO->isEnabled called at [/opt/lampp/htdocs/model/SSO.php:32]
2020-01-20 13:23:35.982 ***** ERROR ***** [] #4 SSO->isSamlEnabled called at [/opt/lampp/htdocs/tool/projeqtor.php:213]
2020-01-20 13:23:35.982 ***** ERROR ***** [] #5 require_once called at [/opt/lampp/htdocs/tool/saveDataToSession.php:30]
2020-01-20 13:23:40.378 ***** ERROR ***** [] Exception-[42S02] SQLSTATE[42S02]: Base table or view not found: 1146 Table 'projeqtor.parameter' doesn't exist
2020-01-20 13:23:40.378 ***** ERROR ***** [] For query : select * from parameter where (idUser is null and idProject is null)
2020-01-20 13:23:40.378 ***** ERROR ***** [] Strack trace :
2020-01-20 13:23:40.378 ***** ERROR ***** [] #0 Sql->query called at [/opt/lampp/htdocs/model/persistence/SqlElement.php:2485]
2020-01-20 13:23:40.378 ***** ERROR ***** [] #1 SqlElement->getSqlElementsFromCriteria called at [/opt/lampp/htdocs/model/Parameter.php:1173]
2020-01-20 13:23:40.378 ***** ERROR ***** [] #2 Parameter->getGlobalParameter called at [/opt/lampp/htdocs/model/SSO.php:25]
2020-01-20 13:23:40.378 ***** ERROR ***** [] #3 SSO->isEnabled called at [/opt/lampp/htdocs/model/SSO.php:32]
2020-01-20 13:23:40.378 ***** ERROR ***** [] #4 SSO->isSamlEnabled called at [/opt/lampp/htdocs/tool/projeqtor.php:213]
2020-01-20 13:23:40.379 ***** ERROR ***** [] #5 require_once called at [/opt/lampp/htdocs/tool/getHash.php:30]
2020-01-20 13:23:40.382 ***** ERROR ***** [] Exception-[42S02] SQLSTATE[42S02]: Base table or view not found: 1146 Table 'projeqtor.resource' doesn't exist
2020-01-20 13:23:40.382 ***** ERROR ***** [] For query : desc resource
2020-01-20 13:23:40.382 ***** ERROR ***** [] Strack trace :
2020-01-20 13:23:40.382 ***** ERROR ***** [] #0 Sql->query called at [/opt/lampp/htdocs/model/persistence/SqlElement.php:3597]
2020-01-20 13:23:40.382 ***** ERROR ***** [] #1 SqlElement->getFormatList called at [/opt/lampp/htdocs/model/persistence/SqlElement.php:3147]
2020-01-20 13:23:40.382 ***** ERROR ***** [] #2 SqlElement->getDataType called at [/opt/lampp/htdocs/model/persistence/SqlElement.php:2448]
2020-01-20 13:23:40.382 ***** ERROR ***** [] #3 SqlElement->getSqlElementsFromCriteria called at [/opt/lampp/htdocs/model/persistence/SqlElement.php:2790]
2020-01-20 13:23:40.382 ***** ERROR ***** [] #4 SqlElement->getSingleSqlElementFromCriteria called at [/opt/lampp/htdocs/tool/getHash.php:48]
2020-01-20 13:23:40.382 ***** ERROR ***** [] For query : select * from resource where resource.name='admin' and resource.isUser = '1'
2020-01-20 13:23:40.382 ***** ERROR ***** [] #0 Sql->query called at [/opt/lampp/htdocs/model/persistence/SqlElement.php:2485]
2020-01-20 13:23:40.382 ***** ERROR ***** [] #1 SqlElement->getSqlElementsFromCriteria called at [/opt/lampp/htdocs/model/persistence/SqlElement.php:2790]
2020-01-20 13:23:40.382 ***** ERROR ***** [] #2 SqlElement->getSingleSqlElementFromCriteria called at [/opt/lampp/htdocs/tool/getHash.php:48]
2020-01-20 13:23:40.426 ***** ERROR ***** [] Exception-[42S02] SQLSTATE[42S02]: Base table or view not found: 1146 Table 'projeqtor.parameter' doesn't exist
2020-01-20 13:23:40.427 ***** ERROR ***** [] For query : select * from parameter where (idUser is null and idProject is null)
2020-01-20 13:23:40.427 ***** ERROR ***** [] Strack trace :
2020-01-20 13:23:40.427 ***** ERROR ***** [] #0 Sql->query called at [/opt/lampp/htdocs/model/persistence/SqlElement.php:2485]
2020-01-20 13:23:40.427 ***** ERROR ***** [] #1 SqlElement->getSqlElementsFromCriteria called at [/opt/lampp/htdocs/model/Parameter.php:1173]
2020-01-20 13:23:40.427 ***** ERROR ***** [] #2 Parameter->getGlobalParameter called at [/opt/lampp/htdocs/model/SSO.php:25]
2020-01-20 13:23:40.427 ***** ERROR ***** [] #3 SSO->isEnabled called at [/opt/lampp/htdocs/model/SSO.php:32]
2020-01-20 13:23:40.427 ***** ERROR ***** [] #4 SSO->isSamlEnabled called at [/opt/lampp/htdocs/tool/projeqtor.php:213]
2020-01-20 13:23:40.427 ***** ERROR ***** [] #5 require_once called at [/opt/lampp/htdocs/tool/loginCheck.php:30]
2020-01-20 13:23:40.432 ***** ERROR ***** [] ERROR *****
2020-01-20 13:23:40.432 ***** ERROR ***** [] on file '/opt/lampp/htdocs/db/maintenance.php' at line (81)
2020-01-20 13:23:40.432 ***** ERROR ***** [] cause = fopen(../files/cron/MIGRATION): failed to open stream: Permission denied
Last edit: 20 Jan 2020 13:29 by fred12345.
20 Jan 2020 14:19 #12 by babynus
PHP user don't have access to ../files/cron/
You sohuld give access 775 to whole files folder
chmod -R 775 files
