ProjeQtOr free project management software - Installation troubles on Ubuntu 16.04-18.x with xampp - ProjeQtOr
17 Jan 2020 13:57 - 17 Jan 2020 13:59 #1 by fred12345
1. Installed clean Ubuntu 16.0.4
2. Downloaded and installed XAMPP 7.2.26
3. Checked http://localhost - works good. Apache, Mysql and ProFTPD started.
4. Downloaded projeqtor 8.2.4
5. Unzipped and moved to /opt/lampp/htdocs
6. Opened http://localhost in browser
7. On the Configuration page click "OK"
Got several errors:
1. SQLSTATE[HY000] [1045] Access denied for user 'root'@'localhost' (using password: YES) dsn = mysql:host=127.0.0.1;port=3306
How fixed: removed default DB rassword.
2. incorrect value for 'Log file name', cannot write to such a file : check access rig
How fixed: chmod 777 files/logs/
3. incorrect value for 'Parameter file name', cannot write to such a file : check access rights
How fixed: 1. created manually files/config/parameters.php 2. chmod 777 files/config/parameters.php
4. impossible to write \'../tool/parametersLocation.php\' file, cannot write to such a file : check access rights
How fixed: chmod 777 tool/
5. max_input_vars=1000 is too small - value should be at least 2000, 4000 recommended - check your php configuration (php.ini)
How fixed: added to /opt/lampp/etc/php.ini line: max_input_vars = 4000
All the erors are fixed. I see "On next page, log in as user "admin" with password "admin""
8. Click "Continue"
Now I have an error: SQL ERROR : Database type unknown
How to fix this?
Last edit: 17 Jan 2020 13:59 by fred12345.
20 Jan 2020 09:40 - 20 Jan 2020 09:40 #2 by babynus
Message tells that dbType is not 'mysql' nor 'pgsql'.
Look for error in log file and paste here logged error (exact copy as it may give us some hint)
Last edit: 20 Jan 2020 09:40 by babynus.
20 Jan 2020 09:45 - 20 Jan 2020 09:54 #3 by fred12345
Very strange because I see in XAMPP popup:
MySQL Database Running
ProFTPD Running
Apache Web Server Running
Where is the log-file located?
Last edit: 20 Jan 2020 09:54 by fred12345.
20 Jan 2020 10:06 #4 by babynus
Log file is where you opened rights ;)
20 Jan 2020 10:11 #5 by fred12345
/opt/lampp/htdocs/files/logs/ has index.php only. Double-checked, logs directory has 777.
20 Jan 2020 10:31 #6 by babynus
Check in parametersLocation.php where oyu storeed paramerters.php file
Look in parameters.php file where you store logs.
