ProjeQtOr free project management software - Same page as before for the intallation - ProjeQtOr
20 Nov 2019 11:20 #1 by Uzel
I installed a php7.2/apache2/mysql (5.7.28) on Ubuntu 18.04 and "adminer.php" for management. I created a user and a database, everything works very well under adminer.php, the log and pw are well recognized etc. and the database is there accessible with the log and pw.
OK also for projeqtor ( with chown -R www-data: /var/ww/ww/html/projeqtor/files and chmod -R 755 /var/ww/html/projeqtor/files)
On the other hand, there is still the error:
impossible to write \'.../tool/parametersLocation.php\' file, cannot write to such a file : check access rights
Then on the second page I don't understand what still needs to be done: we go back to the same page as before (Configuration
This screen will help you configure ProjeQtOr at first run.)
Thank you for your help.
G. Uzel
20 Nov 2019 11:32 #2 by babynus
Clearly message tells PHP cannot write in folder projeqtor/tool
If rights are correctly set (as you decribe it) then possibly an external tool locks access (antivirus or selinus)
20 Nov 2019 13:30 - 20 Nov 2019 15:05 #3 by Uzel
Thank you for your answer, but in fact the parametersLocation.php file does not exist in projeqtor/tool
I just looked at it.
chmod chown I did it twice.
Last edit: 20 Nov 2019 15:05 by Uzel. Reason: language error, not yet used : -)
20 Nov 2019 14:32 #4 by babynus
PLEASE WRITE IN ENGLISH
Of course parametersLocation.php does not exist.
PRojeqtor tries and create it, and this is this write that fails.
20 Nov 2019 15:07 #5 by Uzel
All right, I'll see if there's a way to force it when I have time.
Thank you for your availability.
25 Nov 2019 13:25 #6 by Uzel
Be very careful: the use of -R commands creates many problems in Debian/Ubuntu systems and I had some very big problems. Do not try to install projectqtor if rights issues arise.
