ProjeQtOr free project management software - Same page as before for the intallation - Page 2 - ProjeQtOr
25 Nov 2019 14:04 #7 by babynus
Be very careful: the use of -R commands creates many problems in Debian/Ubuntu systems and I had some very big problems.
Of course a
chmod -R 777 *
at root lefet whith root rights (connected as root or with sudo) will "kill" your OS (won't work anymore)
Same think for a
chown -R www-data *
The most dangerous is to start location with a /
sudo chmod -R 755 /var/www/html/projeqtor
Because if you enter a space after the first / you'll aplly it at root and kill your system.
This is not linked to projeqtor, nor to admin rights, but basic of administration of Linux OS.
Do not try to install projectqtor if rights issues arise.
Rights issues are easy to solve in most cases.
Of course it requires minimum knowledge of linux system to enter correct line commands.
Or you should use Linux GUI to apply changes from visual interface.
25 Nov 2019 14:55 #8 by Uzel
I only did:
chown -R www-data: /var/ww/ww/html/projeqtor/files and chmod -R 755 /var/ww/html/projeqtor/files
as you had recommended and I had some problems.
I am not questioning the software, which is certainly very interesting.
I suggest that you provide details of safe installations on the main systems to avoid problems for those who want to test it.
25 Nov 2019 15:30 - 25 Nov 2019 15:33 #9 by babynus
If these command come from forum, there is a great issue : they should work on no system
Correct commands are
chown -R www-data: /var/www/html/projeqtor
But I would suggest to rather use
cd /var/www/html
chown -R www-data: projeqtor
chmod -R 755 projeqtor
This assumes that :
1) /var/www/html is the DocumentRoot defined on your apache configuration file
2) you installed projeqtor directly on this flder, without whanging name of top folrder (projeqtor)
Last edit: 25 Nov 2019 15:33 by babynus.
