ProjeQtOr free project management software - problem function calculates resource planning - Page 4 - ProjeQtOr
03 Oct 2019 14:29 #19 by babynus
Please try again wth 8G and show error ...
03 Oct 2019 14:59 #20 by gabriele.giovannelli
Something is changed. Indeed there were errors of consistency that I set with the appropriate button. Now the errors are these:
[Thu Oct 03 14:56:36.728647 2019] [php7:error] [pid 2774] [client 192.168.12.1:62240] PHP Fatal error: Allowed memory size of 536870912 bytes exhausted (tried to allocate 36864 bytes) in /var/www/html/projeqtor/model/PlannedWork.php on line 665, referer: http://192.168.12.137/projeqtor/view/main.php
[Thu Oct 03 14:56:36.734946 2019] [php7:error] [pid 2774] [client 192.168.12.1:62240] PHP Fatal error: Allowed memory size of 536870912 bytes exhausted (tried to allocate 32768 bytes) in Unknown on line 0, referer: http://192.168.12.137/projeqtor/view/main.php
03 Oct 2019 15:09 #21 by babynus
Try and change Global Parameter "Memory for PDF generation" (on tab system).
I did not expect this parameter to be used for planning, but it"s worth a try.
03 Oct 2019 16:41 #22 by gabriele.giovannelli
I have set et 8000 the global variable and now appear this :
[Thu Oct 03 16:37:40.348001 2019] [php7:error] [pid 3463] [client 192.168.12.1:63100] PHP Fatal error: Allowed memory size of 536870912 bytes exhausted (tried to allocate 20480 bytes) in /var/www/html/projeqtor/model/persistence/SqlElement.php on line 3016, referer: http://192.168.12.137/projeqtor/view/main.php
[Thu Oct 03 16:37:40.354904 2019] [php7:error] [pid 3463] [client 192.168.12.1:63100] PHP Fatal error: Allowed memory size of 536870912 bytes exhausted (tried to allocate 20480 bytes) in Unknown on line 0, referer: http://192.168.12.137/projeqtor/view/main.php
thank you very much for your kindness and patience
04 Oct 2019 09:52 #23 by gabriele.giovannelli
where can the problem be in:
/var/www/html/projeqtor/model/persistence/SqlElement.php on line 3016 ???
14 Oct 2019 11:16 #24 by babynus
The line is not important as it is memory issue.
The issue occurs when memory is full.
If you change few things on projects, issue will occur at different location.
Your issue is that your parameters are not taken into account : memory limit is always 512M and you need more to plan all the projects in one shot.
