ProjeQtOr free project management software - problem function calculates resource planning - ProjeQtOr
02 Oct 2019 09:05 #1 by gabriele.giovannelli
I have a somewhat complicated process management ... I have 186 projects and 315 subprojects. The activities are 1811 ....
When I click the button for programming the resource activities this does not work. Or rather ... if I select the individual projects from the drop-down menu it works and writes the records in the "plannedwork" table while if I select "all projects" it does not work (the scroll wheel turns to infinity) and deletes all the rows in the table " plannedwork ".
Is this normal?
Thanks a lot :-)
02 Oct 2019 09:48 #2 by babynus
Have a look at lof files : projeqtor log file or php log file or apache log file.
Sure you have a Timeout.
Change your max_execution_time in PHP config file.
02 Oct 2019 10:59 #3 by gabriele.giovannelli
I set the variable max_execution_time = 0, but the behavior is the same as above.
03 Oct 2019 09:37 #4 by gabriele.giovannelli
03 Oct 2019 09:52 #5 by babynus
di you restart PHP after update of php.ini ?
03 Oct 2019 09:53 #6 by gabriele.giovannelli
