ProjeQtOr free project management software - [8.6.0] SQLSTATE[42703]: Undefined column: 7 ERROR: column "taxamount" of relati - ProjeQtOr
19 Sep 2019 18:07 #1 by fathibn
When adding a new "Offre Fournisseur" on 8.6.0 I get the following error: SQLSTATE[42703]: Undefined column: 7 ERROR: column "taxamount" of relation "tender" does not exist LINE 1: ..., offerValidityEndDate , untaxedAmount , taxPct , taxAmount ... ^.
20 Sep 2019 11:55 #2 by babynus
I cannot reproduce on V8.1.6.
Notcie that V8.6.0 does not exist.
Please ensure you are on last stable release (V8.1.6) as we don't support older versions through the forum.
Also check for errors in log file of migration process.
Post here any error (full error please, not an extract).
21 Sep 2019 00:17 #3 by fathibn
Sorry I made a mistake, I am on 8.2.0 as you can see on ppm.sncft.com.tn/
The migration process went smoothly and I had no errors in the logs.
21 Sep 2019 11:43 - 21 Sep 2019 11:44 #4 by babynus
Can you please show full error message, as logged in projeqtor log file ?
Can you also confirm that you are using PostgreSql ?
Last edit: 21 Sep 2019 11:44 by babynus.
21 Sep 2019 12:00 #5 by babynus
OK inssue confirmed on PostgreSql (I had to entermaounts to generate issue)
Ticket #4216 recorded
The following user(s) said Thank You: fathibn
22 Sep 2019 09:22 #6 by fathibn
Sorry, I am out of office for the full logs. I will send them asap.
Yes, I am always using latest stable postgresql (also for php).
