ProjeQtOr free project management software - [8.6.0] SQLSTATE[42703]: Undefined column: 7 ERROR: column "taxamount" of relati - Page 2 - ProjeQtOr
23 Sep 2019 11:17 #7 by fathibn
Hello, here after is the log. Also, notice some errors could be triggered by the fact we use 3 digits after the digit symbol for tunisian currency TND but projeqtor seems to accept only 2.
2019-09-23 10:04:45.040 ===== TRACE ===== NEW CONNECTED USER 'some_valid_user'
2019-09-23 10:05:00.710 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'taxAmount' for Class 'Tender' : field 'taxAmount' not found in Database.
2019-09-23 10:05:00.710 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'fullAmount' for Class 'Tender' : field 'fullAmount' not found in Database.
2019-09-23 10:05:00.711 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'totalUntaxedAmount' for Class 'Tender' : field 'totalUntaxedAmount' not found in Database.
2019-09-23 10:05:00.711 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'totalTaxAmount' for Class 'Tender' : field 'totalTaxAmount' not found in Database.
2019-09-23 10:05:00.711 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'totalFullAmount' for Class 'Tender' : field 'totalFullAmount' not found in Database.
2019-09-23 10:05:00.810 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'taxAmount' for Class 'Tender' : field 'taxAmount' not found in Database.
2019-09-23 10:05:00.810 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'fullAmount' for Class 'Tender' : field 'fullAmount' not found in Database.
2019-09-23 10:05:00.811 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'totalUntaxedAmount' for Class 'Tender' : field 'totalUntaxedAmount' not found in Database.
2019-09-23 10:05:00.812 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'totalTaxAmount' for Class 'Tender' : field 'totalTaxAmount' not found in Database.
2019-09-23 10:05:00.812 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'totalFullAmount' for Class 'Tender' : field 'totalFullAmount' not found in Database.
2019-09-23 10:05:00.974 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'taxAmount' for Class 'Tender' : field 'taxAmount' not found in Database.
2019-09-23 10:05:00.975 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'fullAmount' for Class 'Tender' : field 'fullAmount' not found in Database.
2019-09-23 10:05:00.975 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'totalUntaxedAmount' for Class 'Tender' : field 'totalUntaxedAmount' not found in Database.
2019-09-23 10:05:00.975 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'totalTaxAmount' for Class 'Tender' : field 'totalTaxAmount' not found in Database.
2019-09-23 10:05:00.975 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'totalFullAmount' for Class 'Tender' : field 'totalFullAmount' not found in Database.
2019-09-23 10:05:41.020 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'taxAmount' for Class 'Tender' : field 'taxAmount' not found in Database.
2019-09-23 10:05:41.020 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'fullAmount' for Class 'Tender' : field 'fullAmount' not found in Database.
2019-09-23 10:05:41.021 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'totalUntaxedAmount' for Class 'Tender' : field 'totalUntaxedAmount' not found in Database.
2019-09-23 10:05:41.021 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'totalTaxAmount' for Class 'Tender' : field 'totalTaxAmount' not found in Database.
2019-09-23 10:05:41.021 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'totalFullAmount' for Class 'Tender' : field 'totalFullAmount' not found in Database.
2019-09-23 10:05:50.418 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'taxAmount' for Class 'Tender' : field 'taxAmount' not found in Database.
2019-09-23 10:05:50.419 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'fullAmount' for Class 'Tender' : field 'fullAmount' not found in Database.
2019-09-23 10:05:50.419 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'totalUntaxedAmount' for Class 'Tender' : field 'totalUntaxedAmount' not found in Database.
2019-09-23 10:05:50.419 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'totalTaxAmount' for Class 'Tender' : field 'totalTaxAmount' not found in Database.
2019-09-23 10:05:50.419 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'totalFullAmount' for Class 'Tender' : field 'totalFullAmount' not found in Database.
2019-09-23 10:06:07.185 ***** ERROR ***** [V8.2.0] Exception-[42703] SQLSTATE[42703]: Undefined column: 7 ERROR: column tender.totaluntaxedamount does not exist
LINE 1: ...COALESCE(T3.color,'') as "colorNameTenderStatus", tender.tot...
2019-09-23 10:06:07.185 ***** ERROR ***** [V8.2.0] For query : select tender.id as "id", T1.name as "nameProject", T2.name as "nameTenderType", tender.name as "name", T3.sortOrder || '#split#' ||T3.name || '#split#' ||COALESCE(T3.color,'') as "colorNameTenderStatus", tender.totalUntaxedAmount as "totalUntaxedAmount", T4.sortOrder || '#split#' ||T4.name || '#split#' ||COALESCE(T4.color,'') as "colorNameStatus", tender.idle as "idle",tender.idProject as idproject from tender left join project as T1 on tender.idProject = T1.id left join type as T2 on tender.idTenderType = T2.id left join tenderstatus as T3 on tender.idTenderStatus = T3.id left join status as T4 on tender.idStatus = T4.id where tender.idle=0 and tender.idProject <> 13 and ( ((tender.idProject not in (0) or tender.idProject is null ) and (tender.idProject not in (0) or tender.idProject is null or (tender.idResource='3') ) and (tender.idProject not in (0) or tender.idProject is null or (tender.idUser='3') )) ) order by tender.id desc
2019-09-23 10:06:07.185 ***** ERROR ***** [V8.2.0] Strack trace :
2019-09-23 10:06:07.185 ***** ERROR ***** [V8.2.0] #0 Sql->query called at [/var/www/....../htdocs/tool/jsonQuery.php:707]
2019-09-23 10:06:16.369 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'taxAmount' for Class 'Tender' : field 'taxAmount' not found in Database.
2019-09-23 10:06:16.369 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'fullAmount' for Class 'Tender' : field 'fullAmount' not found in Database.
2019-09-23 10:06:16.369 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'totalUntaxedAmount' for Class 'Tender' : field 'totalUntaxedAmount' not found in Database.
2019-09-23 10:06:16.370 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'totalTaxAmount' for Class 'Tender' : field 'totalTaxAmount' not found in Database.
2019-09-23 10:06:16.370 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'totalFullAmount' for Class 'Tender' : field 'totalFullAmount' not found in Database.
2019-09-23 10:06:29.910 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'taxAmount' for Class 'Tender' : field 'taxAmount' not found in Database.
2019-09-23 10:06:29.911 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'fullAmount' for Class 'Tender' : field 'fullAmount' not found in Database.
2019-09-23 10:06:29.911 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'totalUntaxedAmount' for Class 'Tender' : field 'totalUntaxedAmount' not found in Database.
2019-09-23 10:06:29.911 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'totalTaxAmount' for Class 'Tender' : field 'totalTaxAmount' not found in Database.
2019-09-23 10:06:29.911 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'totalFullAmount' for Class 'Tender' : field 'totalFullAmount' not found in Database.
2019-09-23 10:07:28.894 ***** ERROR ***** [V8.2.0] Exception-[42703] SQLSTATE[42703]: Undefined column: 7 ERROR: column tender.totaluntaxedamount does not exist
2019-09-23 10:07:28.895 ***** ERROR ***** [V8.2.0] For query : select tender.id as "id", T1.name as "nameProject", T2.name as "nameTenderType", tender.name as "name", T3.sortOrder || '#split#' ||T3.name || '#split#' ||COALESCE(T3.color,'') as "colorNameTenderStatus", tender.totalUntaxedAmount as "totalUntaxedAmount", T4.sortOrder || '#split#' ||T4.name || '#split#' ||COALESCE(T4.color,'') as "colorNameStatus", tender.idle as "idle",tender.idProject as idproject from tender left join project as T1 on tender.idProject = T1.id left join type as T2 on tender.idTenderType = T2.id left join tenderstatus as T3 on tender.idTenderStatus = T3.id left join status as T4 on tender.idStatus = T4.id where tender.idle=0 and tender.idProject <> 13 and ( ((tender.idProject not in (0) or tender.idProject is null ) and (tender.idProject not in (0) or tender.idProject is null or (tender.idResource='3') ) and (tender.idProject not in (0) or tender.idProject is null or (tender.idUser='3') )) ) order by tender.id desc
2019-09-23 10:07:28.895 ***** ERROR ***** [V8.2.0] Strack trace :
2019-09-23 10:07:28.895 ***** ERROR ***** [V8.2.0] #0 Sql->query called at [/var/www/....../htdocs/tool/jsonQuery.php:707]
2019-09-23 10:09:32.338 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'taxAmount' for Class 'Tender' : field 'taxAmount' not found in Database.
2019-09-23 10:09:32.338 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'fullAmount' for Class 'Tender' : field 'fullAmount' not found in Database.
2019-09-23 10:09:32.338 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'totalUntaxedAmount' for Class 'Tender' : field 'totalUntaxedAmount' not found in Database.
2019-09-23 10:09:32.338 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'totalTaxAmount' for Class 'Tender' : field 'totalTaxAmount' not found in Database.
2019-09-23 10:09:32.339 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'totalFullAmount' for Class 'Tender' : field 'totalFullAmount' not found in Database.
2019-09-23 10:09:32.342 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'taxAmount' for Class 'Tender' : field 'taxAmount' not found in Database.
2019-09-23 10:09:32.342 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'fullAmount' for Class 'Tender' : field 'fullAmount' not found in Database.
2019-09-23 10:09:32.342 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'totalUntaxedAmount' for Class 'Tender' : field 'totalUntaxedAmount' not found in Database.
2019-09-23 10:09:32.343 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'totalTaxAmount' for Class 'Tender' : field 'totalTaxAmount' not found in Database.
2019-09-23 10:09:32.343 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'totalFullAmount' for Class 'Tender' : field 'totalFullAmount' not found in Database.
2019-09-23 10:09:32.380 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'taxAmount' for Class 'Tender' : field 'taxAmount' not found in Database.
2019-09-23 10:09:32.380 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'fullAmount' for Class 'Tender' : field 'fullAmount' not found in Database.
2019-09-23 10:09:32.380 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'totalUntaxedAmount' for Class 'Tender' : field 'totalUntaxedAmount' not found in Database.
2019-09-23 10:09:32.381 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'totalTaxAmount' for Class 'Tender' : field 'totalTaxAmount' not found in Database.
2019-09-23 10:09:32.381 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'totalFullAmount' for Class 'Tender' : field 'totalFullAmount' not found in Database.
2019-09-23 10:09:32.702 ***** ERROR ***** [V8.2.0] Exception-[42703] SQLSTATE[42703]: Undefined column: 7 ERROR: column tender.totaluntaxedamount does not exist
2019-09-23 10:09:32.702 ***** ERROR ***** [V8.2.0] For query : select tender.id as "id", T1.name as "nameProject", T2.name as "nameTenderType", tender.name as "name", T3.sortOrder || '#split#' ||T3.name || '#split#' ||COALESCE(T3.color,'') as "colorNameTenderStatus", tender.totalUntaxedAmount as "totalUntaxedAmount", T4.sortOrder || '#split#' ||T4.name || '#split#' ||COALESCE(T4.color,'') as "colorNameStatus", tender.idle as "idle",tender.idProject as idproject from tender left join project as T1 on tender.idProject = T1.id left join type as T2 on tender.idTenderType = T2.id left join tenderstatus as T3 on tender.idTenderStatus = T3.id left join status as T4 on tender.idStatus = T4.id where tender.idle=0 and tender.idProject <> 13 and ( ((tender.idProject not in (0) or tender.idProject is null ) and (tender.idProject not in (0) or tender.idProject is null or (tender.idResource='3') ) and (tender.idProject not in (0) or tender.idProject is null or (tender.idUser='3') )) ) order by tender.id desc
2019-09-23 10:09:32.702 ***** ERROR ***** [V8.2.0] Strack trace :
2019-09-23 10:09:32.702 ***** ERROR ***** [V8.2.0] #0 Sql->query called at [/var/www/....../htdocs/tool/jsonQuery.php:707]
2019-09-23 10:09:33.040 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'taxAmount' for Class 'Tender' : field 'taxAmount' not found in Database.
2019-09-23 10:09:33.041 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'fullAmount' for Class 'Tender' : field 'fullAmount' not found in Database.
2019-09-23 10:09:33.041 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'totalUntaxedAmount' for Class 'Tender' : field 'totalUntaxedAmount' not found in Database.
2019-09-23 10:09:33.041 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'totalTaxAmount' for Class 'Tender' : field 'totalTaxAmount' not found in Database.
2019-09-23 10:09:33.041 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'totalFullAmount' for Class 'Tender' : field 'totalFullAmount' not found in Database.
2019-09-23 10:09:33.106 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'taxAmount' for Class 'Tender' : field 'taxAmount' not found in Database.
2019-09-23 10:09:33.106 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'fullAmount' for Class 'Tender' : field 'fullAmount' not found in Database.
2019-09-23 10:09:33.106 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'totalUntaxedAmount' for Class 'Tender' : field 'totalUntaxedAmount' not found in Database.
2019-09-23 10:09:33.107 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'totalTaxAmount' for Class 'Tender' : field 'totalTaxAmount' not found in Database.
2019-09-23 10:09:33.107 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'totalFullAmount' for Class 'Tender' : field 'totalFullAmount' not found in Database.
2019-09-23 10:09:33.184 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'taxAmount' for Class 'Tender' : field 'taxAmount' not found in Database.
2019-09-23 10:09:33.184 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'fullAmount' for Class 'Tender' : field 'fullAmount' not found in Database.
2019-09-23 10:09:33.184 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'totalUntaxedAmount' for Class 'Tender' : field 'totalUntaxedAmount' not found in Database.
2019-09-23 10:09:33.185 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'totalTaxAmount' for Class 'Tender' : field 'totalTaxAmount' not found in Database.
2019-09-23 10:09:33.185 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'totalFullAmount' for Class 'Tender' : field 'totalFullAmount' not found in Database.
2019-09-23 10:09:33.245 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'taxAmount' for Class 'Tender' : field 'taxAmount' not found in Database.
2019-09-23 10:09:33.246 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'fullAmount' for Class 'Tender' : field 'fullAmount' not found in Database.
2019-09-23 10:09:33.246 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'totalUntaxedAmount' for Class 'Tender' : field 'totalUntaxedAmount' not found in Database.
2019-09-23 10:09:33.246 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'totalTaxAmount' for Class 'Tender' : field 'totalTaxAmount' not found in Database.
2019-09-23 10:09:33.247 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'totalFullAmount' for Class 'Tender' : field 'totalFullAmount' not found in Database.
2019-09-23 10:09:34.710 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'taxAmount' for Class 'Tender' : field 'taxAmount' not found in Database.
2019-09-23 10:09:34.710 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'fullAmount' for Class 'Tender' : field 'fullAmount' not found in Database.
2019-09-23 10:09:34.710 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'totalUntaxedAmount' for Class 'Tender' : field 'totalUntaxedAmount' not found in Database.
2019-09-23 10:09:34.710 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'totalTaxAmount' for Class 'Tender' : field 'totalTaxAmount' not found in Database.
2019-09-23 10:09:34.710 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'totalFullAmount' for Class 'Tender' : field 'totalFullAmount' not found in Database.
2019-09-23 10:09:36.388 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'taxAmount' for Class 'Tender' : field 'taxAmount' not found in Database.
2019-09-23 10:09:36.388 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'fullAmount' for Class 'Tender' : field 'fullAmount' not found in Database.
2019-09-23 10:09:36.388 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'totalUntaxedAmount' for Class 'Tender' : field 'totalUntaxedAmount' not found in Database.
2019-09-23 10:09:36.388 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'totalTaxAmount' for Class 'Tender' : field 'totalTaxAmount' not found in Database.
2019-09-23 10:09:36.388 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'totalFullAmount' for Class 'Tender' : field 'totalFullAmount' not found in Database.
2019-09-23 10:09:36.989 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'taxAmount' for Class 'Tender' : field 'taxAmount' not found in Database.
2019-09-23 10:09:36.989 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'fullAmount' for Class 'Tender' : field 'fullAmount' not found in Database.
2019-09-23 10:09:36.990 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'totalUntaxedAmount' for Class 'Tender' : field 'totalUntaxedAmount' not found in Database.
2019-09-23 10:09:36.990 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'totalTaxAmount' for Class 'Tender' : field 'totalTaxAmount' not found in Database.
2019-09-23 10:09:36.990 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'totalFullAmount' for Class 'Tender' : field 'totalFullAmount' not found in Database.
2019-09-23 10:11:26.738 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'taxAmount' for Class 'Tender' : field 'taxAmount' not found in Database.
2019-09-23 10:11:26.738 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'fullAmount' for Class 'Tender' : field 'fullAmount' not found in Database.
2019-09-23 10:11:26.738 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'totalUntaxedAmount' for Class 'Tender' : field 'totalUntaxedAmount' not found in Database.
2019-09-23 10:11:26.738 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'totalTaxAmount' for Class 'Tender' : field 'totalTaxAmount' not found in Database.
2019-09-23 10:11:26.739 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'totalFullAmount' for Class 'Tender' : field 'totalFullAmount' not found in Database.
2019-09-23 10:11:26.742 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'taxAmount' for Class 'Tender' : field 'taxAmount' not found in Database.
2019-09-23 10:11:26.742 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'fullAmount' for Class 'Tender' : field 'fullAmount' not found in Database.
2019-09-23 10:11:26.742 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'totalUntaxedAmount' for Class 'Tender' : field 'totalUntaxedAmount' not found in Database.
2019-09-23 10:11:26.742 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'totalTaxAmount' for Class 'Tender' : field 'totalTaxAmount' not found in Database.
2019-09-23 10:11:26.742 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'totalFullAmount' for Class 'Tender' : field 'totalFullAmount' not found in Database.
2019-09-23 10:11:26.745 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'taxAmount' for Class 'Tender' : field 'taxAmount' not found in Database.
2019-09-23 10:11:26.746 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'fullAmount' for Class 'Tender' : field 'fullAmount' not found in Database.
2019-09-23 10:11:26.746 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'totalUntaxedAmount' for Class 'Tender' : field 'totalUntaxedAmount' not found in Database.
2019-09-23 10:11:26.746 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'totalTaxAmount' for Class 'Tender' : field 'totalTaxAmount' not found in Database.
2019-09-23 10:11:26.746 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'totalFullAmount' for Class 'Tender' : field 'totalFullAmount' not found in Database.
2019-09-23 10:11:26.756 ***** ERROR ***** [V8.2.0] Exception-[42703] SQLSTATE[42703]: Undefined column: 7 ERROR: column "taxamount" of relation "tender" does not exist
LINE 1: update tender set untaxedamount='135384.98' , taxamount='257...
2019-09-23 10:11:26.757 ***** ERROR ***** [V8.2.0] For query : update tender set untaxedamount='135384.98' , taxamount='25723.15' , fullamount='161108.13' , totaluntaxedamount='135384.98' , totaltaxamount='25723.15' , totalfullamount='161108.13' where id=2
2019-09-23 10:11:26.757 ***** ERROR ***** [V8.2.0] Strack trace :
2019-09-23 10:11:26.757 ***** ERROR ***** [V8.2.0] #0 Sql->query called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1575]
2019-09-23 10:11:26.757 ***** ERROR ***** [V8.2.0] #1 SqlElement->updateSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1064]
2019-09-23 10:11:26.757 ***** ERROR ***** [V8.2.0] #2 SqlElement->saveSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:733]
2019-09-23 10:11:26.757 ***** ERROR ***** [V8.2.0] #3 SqlElement->save called at [/var/www/....../htdocs/model/TenderMain.php:339]
2019-09-23 10:11:26.758 ***** ERROR ***** [V8.2.0] #4 TenderMain->save called at [/var/www/....../htdocs/tool/saveObject.php:78]
2019-09-23 10:11:26.758 ***** ERROR ***** [V8.2.0] Exception-[25P02] SQLSTATE[25P02]: In failed sql transaction: 7 ERROR: current transaction is aborted, commands ignored until end of transaction block
2019-09-23 10:11:26.758 ***** ERROR ***** [V8.2.0] For query : select * from project where id=14
2019-09-23 10:11:26.758 ***** ERROR ***** [V8.2.0] Strack trace :
2019-09-23 10:11:26.759 ***** ERROR ***** [V8.2.0] #0 Sql->query called at [/var/www/....../htdocs/model/persistence/SqlElement.php:2939]
2019-09-23 10:11:26.759 ***** ERROR ***** [V8.2.0] #1 SqlElement->getSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:672]
2019-09-23 10:11:26.759 ***** ERROR ***** [V8.2.0] #2 SqlElement->__construct called at [/var/www/....../htdocs/model/ProjectMain.php:188]
2019-09-23 10:11:26.759 ***** ERROR ***** [V8.2.0] #3 ProjectMain->__construct called at [/var/www/....../htdocs/model/Project.php:40]
2019-09-23 10:11:26.759 ***** ERROR ***** [V8.2.0] #4 Project->__construct called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1103]
2019-09-23 10:11:26.759 ***** ERROR ***** [V8.2.0] #5 SqlElement->saveSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:733]
2019-09-23 10:11:26.760 ***** ERROR ***** [V8.2.0] #6 SqlElement->save called at [/var/www/....../htdocs/model/TenderMain.php:339]
2019-09-23 10:11:26.760 ***** ERROR ***** [V8.2.0] #7 TenderMain->save called at [/var/www/....../htdocs/tool/saveObject.php:78]
2019-09-23 10:11:26.760 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.760 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.760 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.761 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.761 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.761 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'id' for Class 'Project' : field 'id' not found in Database.
2019-09-23 10:11:26.761 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.761 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.762 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.762 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.762 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'name' for Class 'Project' : field 'name' not found in Database.
2019-09-23 10:11:26.762 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.762 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.763 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.763 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.763 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.763 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'idProjectType' for Class 'Project' : field 'idProjectType' not found in Database.
2019-09-23 10:11:26.763 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.764 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.764 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.764 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.764 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'idOrganization' for Class 'Project' : field 'idOrganization' not found in Database.
2019-09-23 10:11:26.764 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.765 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.765 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.765 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.765 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'idCategory' for Class 'Project' : field 'idCategory' not found in Database.
2019-09-23 10:11:26.766 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.766 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.766 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.766 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.766 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'organizationInherited' for Class 'Project' : field 'organizationInherited' not found in Database.
2019-09-23 10:11:26.767 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.767 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.767 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.767 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.767 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'organizationElementary' for Class 'Project' : field 'organizationElementary' not found in Database.
2019-09-23 10:11:26.768 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.768 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.768 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.768 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.769 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'codeType' for Class 'Project' : field 'codeType' not found in Database.
2019-09-23 10:11:26.769 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.769 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.769 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.769 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.770 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'idClient' for Class 'Project' : field 'idClient' not found in Database.
2019-09-23 10:11:26.770 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.770 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.770 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.770 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.771 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.771 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'idContact' for Class 'Project' : field 'idContact' not found in Database.
2019-09-23 10:11:26.771 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.771 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.771 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.772 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.772 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'projectCode' for Class 'Project' : field 'projectCode' not found in Database.
2019-09-23 10:11:26.772 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.772 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.773 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.773 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.773 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'contractCode' for Class 'Project' : field 'contractCode' not found in Database.
2019-09-23 10:11:26.773 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.773 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.774 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.774 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.774 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.774 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'clientCode' for Class 'Project' : field 'clientCode' not found in Database.
2019-09-23 10:11:26.774 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.775 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.775 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.775 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.775 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'idProject' for Class 'Project' : field 'idProject' not found in Database.
2019-09-23 10:11:26.775 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.776 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.776 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.776 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.776 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'idSponsor' for Class 'Project' : field 'idSponsor' not found in Database.
2019-09-23 10:11:26.777 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.777 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.777 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.777 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.777 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'idResource' for Class 'Project' : field 'idResource' not found in Database.
2019-09-23 10:11:26.778 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.778 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.778 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.778 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.779 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'idUser' for Class 'Project' : field 'idUser' not found in Database.
2019-09-23 10:11:26.779 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.779 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.779 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.779 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.780 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.780 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'creationDate' for Class 'Project' : field 'creationDate' not found in Database.
2019-09-23 10:11:26.780 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.780 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.781 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.781 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.781 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'lastUpdateDateTime' for Class 'Project' : field 'lastUpdateDateTime' not found in Database.
2019-09-23 10:11:26.781 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.781 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.782 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.782 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.782 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'color' for Class 'Project' : field 'color' not found in Database.
2019-09-23 10:11:26.782 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.782 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.783 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.783 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.783 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'longitude' for Class 'Project' : field 'longitude' not found in Database.
2019-09-23 10:11:26.783 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.783 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.784 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.784 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.784 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.784 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'latitude' for Class 'Project' : field 'latitude' not found in Database.
2019-09-23 10:11:26.785 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.785 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.785 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.785 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.785 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'description' for Class 'Project' : field 'description' not found in Database.
2019-09-23 10:11:26.786 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.786 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.786 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.786 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.786 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'objectives' for Class 'Project' : field 'objectives' not found in Database.
2019-09-23 10:11:26.787 ***** ERROR ***** [V8.2.0] Exception-[25P02] SQLSTATE[25P02]: In failed sql transaction: 7 ERROR: current transaction is aborted, commands ignored until end of transaction block
2019-09-23 10:11:26.787 ***** ERROR ***** [V8.2.0] For query : select id from planningelement where refId =14 and refType ='Project'
2019-09-23 10:11:26.787 ***** ERROR ***** [V8.2.0] Strack trace :
2019-09-23 10:11:26.787 ***** ERROR ***** [V8.2.0] #0 Sql->query called at [/var/www/....../htdocs/model/persistence/SqlElement.php:3069]
2019-09-23 10:11:26.788 ***** ERROR ***** [V8.2.0] #1 SqlElement->getDependantSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:2990]
2019-09-23 10:11:26.788 ***** ERROR ***** [V8.2.0] #2 SqlElement->getSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:672]
2019-09-23 10:11:26.788 ***** ERROR ***** [V8.2.0] #3 SqlElement->__construct called at [/var/www/....../htdocs/model/ProjectMain.php:188]
2019-09-23 10:11:26.788 ***** ERROR ***** [V8.2.0] #4 ProjectMain->__construct called at [/var/www/....../htdocs/model/Project.php:40]
2019-09-23 10:11:26.788 ***** ERROR ***** [V8.2.0] #5 Project->__construct called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1103]
2019-09-23 10:11:26.788 ***** ERROR ***** [V8.2.0] #6 SqlElement->saveSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:733]
2019-09-23 10:11:26.789 ***** ERROR ***** [V8.2.0] #7 SqlElement->save called at [/var/www/....../htdocs/model/TenderMain.php:339]
2019-09-23 10:11:26.789 ***** ERROR ***** [V8.2.0] #8 TenderMain->save called at [/var/www/....../htdocs/tool/saveObject.php:78]
2019-09-23 10:11:26.789 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.789 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.789 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.789 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.790 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.790 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'idStatus' for Class 'Project' : field 'idStatus' not found in Database.
2019-09-23 10:11:26.790 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.790 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.791 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.791 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.791 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'idHealth' for Class 'Project' : field 'idHealth' not found in Database.
2019-09-23 10:11:26.791 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.791 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.792 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.792 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.792 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'idQuality' for Class 'Project' : field 'idQuality' not found in Database.
2019-09-23 10:11:26.792 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.792 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.793 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.793 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.793 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.793 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'idTrend' for Class 'Project' : field 'idTrend' not found in Database.
2019-09-23 10:11:26.793 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.794 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.794 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.794 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.794 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'idOverallProgress' for Class 'Project' : field 'idOverallProgress' not found in Database.
2019-09-23 10:11:26.794 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.795 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.795 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.795 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.795 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'fixPlanning' for Class 'Project' : field 'fixPlanning' not found in Database.
2019-09-23 10:11:26.796 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.796 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.796 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.796 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.796 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'fixPerimeter' for Class 'Project' : field 'fixPerimeter' not found in Database.
2019-09-23 10:11:26.797 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.797 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.797 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.797 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.797 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'isUnderConstruction' for Class 'Project' : field 'isUnderConstruction' not found in Database.
2019-09-23 10:11:26.798 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.798 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.798 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.798 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.799 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'excludeFromGlobalPlanning' for Class 'Project' : field 'excludeFromGlobalPlanning' not found in Database.
2019-09-23 10:11:26.799 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.799 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.799 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.799 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.800 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'handled' for Class 'Project' : field 'handled' not found in Database.
2019-09-23 10:11:26.800 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.800 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.800 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.801 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.801 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.801 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'handledDate' for Class 'Project' : field 'handledDate' not found in Database.
2019-09-23 10:11:26.801 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.801 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.802 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.802 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.802 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'done' for Class 'Project' : field 'done' not found in Database.
2019-09-23 10:11:26.802 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.802 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.803 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.803 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.803 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'doneDate' for Class 'Project' : field 'doneDate' not found in Database.
2019-09-23 10:11:26.803 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.803 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.804 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.804 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.804 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.804 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'idle' for Class 'Project' : field 'idle' not found in Database.
2019-09-23 10:11:26.804 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.805 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.805 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.805 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.805 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'idleDate' for Class 'Project' : field 'idleDate' not found in Database.
2019-09-23 10:11:26.805 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.806 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.806 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.806 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.806 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'cancelled' for Class 'Project' : field 'cancelled' not found in Database.
2019-09-23 10:11:26.807 ***** ERROR ***** [V8.2.0] Exception-[25P02] SQLSTATE[25P02]: In failed sql transaction: 7 ERROR: current transaction is aborted, commands ignored until end of transaction block
2019-09-23 10:11:26.807 ***** ERROR ***** [V8.2.0] For query : select id from productproject where idProject= '14' order by id desc
2019-09-23 10:11:26.807 ***** ERROR ***** [V8.2.0] Strack trace :
2019-09-23 10:11:26.807 ***** ERROR ***** [V8.2.0] #0 Sql->query called at [/var/www/....../htdocs/model/persistence/SqlElement.php:3113]
2019-09-23 10:11:26.808 ***** ERROR ***** [V8.2.0] #1 SqlElement->getDependantSqlElements called at [/var/www/....../htdocs/model/persistence/SqlElement.php:2984]
2019-09-23 10:11:26.808 ***** ERROR ***** [V8.2.0] #2 SqlElement->getSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:672]
2019-09-23 10:11:26.808 ***** ERROR ***** [V8.2.0] #3 SqlElement->__construct called at [/var/www/....../htdocs/model/ProjectMain.php:188]
2019-09-23 10:11:26.808 ***** ERROR ***** [V8.2.0] #4 ProjectMain->__construct called at [/var/www/....../htdocs/model/Project.php:40]
2019-09-23 10:11:26.808 ***** ERROR ***** [V8.2.0] #5 Project->__construct called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1103]
2019-09-23 10:11:26.808 ***** ERROR ***** [V8.2.0] #6 SqlElement->saveSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:733]
2019-09-23 10:11:26.808 ***** ERROR ***** [V8.2.0] #7 SqlElement->save called at [/var/www/....../htdocs/model/TenderMain.php:339]
2019-09-23 10:11:26.809 ***** ERROR ***** [V8.2.0] #8 TenderMain->save called at [/var/www/....../htdocs/tool/saveObject.php:78]
2019-09-23 10:11:26.809 ***** ERROR ***** [V8.2.0] Exception-[25P02] SQLSTATE[25P02]: In failed sql transaction: 7 ERROR: current transaction is aborted, commands ignored until end of transaction block
2019-09-23 10:11:26.809 ***** ERROR ***** [V8.2.0] For query : select * from versionproject where versionproject.idProject=14
2019-09-23 10:11:26.809 ***** ERROR ***** [V8.2.0] Strack trace :
2019-09-23 10:11:26.810 ***** ERROR ***** [V8.2.0] #0 Sql->query called at [/var/www/....../htdocs/model/persistence/SqlElement.php:2480]
2019-09-23 10:11:26.810 ***** ERROR ***** [V8.2.0] #1 SqlElement->getSqlElementsFromCriteria called at [/var/www/....../htdocs/model/persistence/SqlElement.php:2961]
2019-09-23 10:11:26.810 ***** ERROR ***** [V8.2.0] #2 SqlElement->getSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:672]
2019-09-23 10:11:26.810 ***** ERROR ***** [V8.2.0] #3 SqlElement->__construct called at [/var/www/....../htdocs/model/ProjectMain.php:188]
2019-09-23 10:11:26.810 ***** ERROR ***** [V8.2.0] #4 ProjectMain->__construct called at [/var/www/....../htdocs/model/Project.php:40]
2019-09-23 10:11:26.810 ***** ERROR ***** [V8.2.0] #5 Project->__construct called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1103]
2019-09-23 10:11:26.811 ***** ERROR ***** [V8.2.0] #6 SqlElement->saveSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:733]
2019-09-23 10:11:26.811 ***** ERROR ***** [V8.2.0] #7 SqlElement->save called at [/var/www/....../htdocs/model/TenderMain.php:339]
2019-09-23 10:11:26.811 ***** ERROR ***** [V8.2.0] #8 TenderMain->save called at [/var/www/....../htdocs/tool/saveObject.php:78]
2019-09-23 10:11:26.811 ***** ERROR ***** [V8.2.0] Exception-[25P02] SQLSTATE[25P02]: In failed sql transaction: 7 ERROR: current transaction is aborted, commands ignored until end of transaction block
2019-09-23 10:11:26.812 ***** ERROR ***** [V8.2.0] For query : select * from dependency where dependency.SuccessorRefType='Project' and dependency.SuccessorRefId=14
2019-09-23 10:11:26.812 ***** ERROR ***** [V8.2.0] Strack trace :
2019-09-23 10:11:26.812 ***** ERROR ***** [V8.2.0] #0 Sql->query called at [/var/www/....../htdocs/model/persistence/SqlElement.php:2480]
2019-09-23 10:11:26.812 ***** ERROR ***** [V8.2.0] #1 SqlElement->getSqlElementsFromCriteria called at [/var/www/....../htdocs/model/persistence/SqlElement.php:2981]
2019-09-23 10:11:26.812 ***** ERROR ***** [V8.2.0] #2 SqlElement->getSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:672]
2019-09-23 10:11:26.812 ***** ERROR ***** [V8.2.0] #3 SqlElement->__construct called at [/var/www/....../htdocs/model/ProjectMain.php:188]
2019-09-23 10:11:26.813 ***** ERROR ***** [V8.2.0] #4 ProjectMain->__construct called at [/var/www/....../htdocs/model/Project.php:40]
2019-09-23 10:11:26.813 ***** ERROR ***** [V8.2.0] #5 Project->__construct called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1103]
2019-09-23 10:11:26.813 ***** ERROR ***** [V8.2.0] #6 SqlElement->saveSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:733]
2019-09-23 10:11:26.813 ***** ERROR ***** [V8.2.0] #7 SqlElement->save called at [/var/www/....../htdocs/model/TenderMain.php:339]
2019-09-23 10:11:26.813 ***** ERROR ***** [V8.2.0] #8 TenderMain->save called at [/var/www/....../htdocs/tool/saveObject.php:78]
2019-09-23 10:11:26.814 ***** ERROR ***** [V8.2.0] Exception-[25P02] SQLSTATE[25P02]: In failed sql transaction: 7 ERROR: current transaction is aborted, commands ignored until end of transaction block
2019-09-23 10:11:26.814 ***** ERROR ***** [V8.2.0] For query : select * from dependency where dependency.PredecessorRefType='Project' and dependency.PredecessorRefId=14
2019-09-23 10:11:26.814 ***** ERROR ***** [V8.2.0] Strack trace :
2019-09-23 10:11:26.814 ***** ERROR ***** [V8.2.0] #0 Sql->query called at [/var/www/....../htdocs/model/persistence/SqlElement.php:2480]
2019-09-23 10:11:26.814 ***** ERROR ***** [V8.2.0] #1 SqlElement->getSqlElementsFromCriteria called at [/var/www/....../htdocs/model/persistence/SqlElement.php:2981]
2019-09-23 10:11:26.814 ***** ERROR ***** [V8.2.0] #2 SqlElement->getSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:672]
2019-09-23 10:11:26.815 ***** ERROR ***** [V8.2.0] #3 SqlElement->__construct called at [/var/www/....../htdocs/model/ProjectMain.php:188]
2019-09-23 10:11:26.815 ***** ERROR ***** [V8.2.0] #4 ProjectMain->__construct called at [/var/www/....../htdocs/model/Project.php:40]
2019-09-23 10:11:26.815 ***** ERROR ***** [V8.2.0] #5 Project->__construct called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1103]
2019-09-23 10:11:26.815 ***** ERROR ***** [V8.2.0] #6 SqlElement->saveSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:733]
2019-09-23 10:11:26.815 ***** ERROR ***** [V8.2.0] #7 SqlElement->save called at [/var/www/....../htdocs/model/TenderMain.php:339]
2019-09-23 10:11:26.815 ***** ERROR ***** [V8.2.0] #8 TenderMain->save called at [/var/www/....../htdocs/tool/saveObject.php:78]
2019-09-23 10:11:26.816 ***** ERROR ***** [V8.2.0] Exception-[25P02] SQLSTATE[25P02]: In failed sql transaction: 7 ERROR: current transaction is aborted, commands ignored until end of transaction block
2019-09-23 10:11:26.816 ***** ERROR ***** [V8.2.0] For query : select * from link where ( ref1Type='Project' and ref1Id=14) or ( ref2Type='Project' and ref2Id=14 )
2019-09-23 10:11:26.816 ***** ERROR ***** [V8.2.0] Strack trace :
2019-09-23 10:11:26.816 ***** ERROR ***** [V8.2.0] #0 Sql->query called at [/var/www/....../htdocs/model/persistence/SqlElement.php:2480]
2019-09-23 10:11:26.817 ***** ERROR ***** [V8.2.0] #1 SqlElement->getSqlElementsFromCriteria called at [/var/www/....../htdocs/model/Link.php:170]
2019-09-23 10:11:26.817 ***** ERROR ***** [V8.2.0] #2 Link->getLinksForObject called at [/var/www/....../htdocs/model/persistence/SqlElement.php:2953]
2019-09-23 10:11:26.817 ***** ERROR ***** [V8.2.0] #3 SqlElement->getSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:672]
2019-09-23 10:11:26.817 ***** ERROR ***** [V8.2.0] #4 SqlElement->__construct called at [/var/www/....../htdocs/model/ProjectMain.php:188]
2019-09-23 10:11:26.817 ***** ERROR ***** [V8.2.0] #5 ProjectMain->__construct called at [/var/www/....../htdocs/model/Project.php:40]
2019-09-23 10:11:26.818 ***** ERROR ***** [V8.2.0] #6 Project->__construct called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1103]
2019-09-23 10:11:26.818 ***** ERROR ***** [V8.2.0] #7 SqlElement->saveSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:733]
2019-09-23 10:11:26.818 ***** ERROR ***** [V8.2.0] #8 SqlElement->save called at [/var/www/....../htdocs/model/TenderMain.php:339]
2019-09-23 10:11:26.818 ***** ERROR ***** [V8.2.0] #9 TenderMain->save called at [/var/www/....../htdocs/tool/saveObject.php:78]
2019-09-23 10:11:26.818 ***** ERROR ***** [V8.2.0] Exception-[25P02] SQLSTATE[25P02]: In failed sql transaction: 7 ERROR: current transaction is aborted, commands ignored until end of transaction block
2019-09-23 10:11:26.819 ***** ERROR ***** [V8.2.0] For query : select id from attachment where refId ='14' and refType ='Project' order by id desc
2019-09-23 10:11:26.819 ***** ERROR ***** [V8.2.0] Strack trace :
2019-09-23 10:11:26.819 ***** ERROR ***** [V8.2.0] #0 Sql->query called at [/var/www/....../htdocs/model/persistence/SqlElement.php:3113]
2019-09-23 10:11:26.819 ***** ERROR ***** [V8.2.0] #1 SqlElement->getDependantSqlElements called at [/var/www/....../htdocs/model/persistence/SqlElement.php:2984]
2019-09-23 10:11:26.819 ***** ERROR ***** [V8.2.0] #2 SqlElement->getSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:672]
2019-09-23 10:11:26.819 ***** ERROR ***** [V8.2.0] #3 SqlElement->__construct called at [/var/www/....../htdocs/model/ProjectMain.php:188]
2019-09-23 10:11:26.820 ***** ERROR ***** [V8.2.0] #4 ProjectMain->__construct called at [/var/www/....../htdocs/model/Project.php:40]
2019-09-23 10:11:26.820 ***** ERROR ***** [V8.2.0] #5 Project->__construct called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1103]
2019-09-23 10:11:26.820 ***** ERROR ***** [V8.2.0] #6 SqlElement->saveSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:733]
2019-09-23 10:11:26.820 ***** ERROR ***** [V8.2.0] #7 SqlElement->save called at [/var/www/....../htdocs/model/TenderMain.php:339]
2019-09-23 10:11:26.820 ***** ERROR ***** [V8.2.0] #8 TenderMain->save called at [/var/www/....../htdocs/tool/saveObject.php:78]
2019-09-23 10:11:26.821 ***** ERROR ***** [V8.2.0] Exception-[25P02] SQLSTATE[25P02]: In failed sql transaction: 7 ERROR: current transaction is aborted, commands ignored until end of transaction block
2019-09-23 10:11:26.821 ***** ERROR ***** [V8.2.0] For query : select id from note where refId ='14' and refType ='Project' order by id desc
2019-09-23 10:11:26.821 ***** ERROR ***** [V8.2.0] Strack trace :
2019-09-23 10:11:26.821 ***** ERROR ***** [V8.2.0] #0 Sql->query called at [/var/www/....../htdocs/model/persistence/SqlElement.php:3113]
2019-09-23 10:11:26.821 ***** ERROR ***** [V8.2.0] #1 SqlElement->getDependantSqlElements called at [/var/www/....../htdocs/model/persistence/SqlElement.php:2984]
2019-09-23 10:11:26.821 ***** ERROR ***** [V8.2.0] #2 SqlElement->getSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:672]
2019-09-23 10:11:26.821 ***** ERROR ***** [V8.2.0] #3 SqlElement->__construct called at [/var/www/....../htdocs/model/ProjectMain.php:188]
2019-09-23 10:11:26.822 ***** ERROR ***** [V8.2.0] #4 ProjectMain->__construct called at [/var/www/....../htdocs/model/Project.php:40]
2019-09-23 10:11:26.822 ***** ERROR ***** [V8.2.0] #5 Project->__construct called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1103]
2019-09-23 10:11:26.822 ***** ERROR ***** [V8.2.0] #6 SqlElement->saveSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:733]
2019-09-23 10:11:26.822 ***** ERROR ***** [V8.2.0] #7 SqlElement->save called at [/var/www/....../htdocs/model/TenderMain.php:339]
2019-09-23 10:11:26.822 ***** ERROR ***** [V8.2.0] #8 TenderMain->save called at [/var/www/....../htdocs/tool/saveObject.php:78]
2019-09-23 10:11:26.822 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.823 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.823 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.823 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.823 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.823 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'sortOrder' for Class 'Project' : field 'sortOrder' not found in Database.
2019-09-23 10:11:26.824 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.824 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.824 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.824 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.825 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'isLeaveMngProject' for Class 'Project' : field 'isLeaveMngProject' not found in Database.
2019-09-23 10:11:26.825 ***** ERROR ***** [V8.2.0] Exception-[25P02] SQLSTATE[25P02]: In failed sql transaction: 7 ERROR: current transaction is aborted, commands ignored until end of transaction block
2019-09-23 10:11:26.825 ***** ERROR ***** [V8.2.0] For query : select * from indicatordefinition where nameIndicatorable='Tender' and idle = 0 and idProject in (14)
2019-09-23 10:11:26.825 ***** ERROR ***** [V8.2.0] Strack trace :
2019-09-23 10:11:26.825 ***** ERROR ***** [V8.2.0] #0 Sql->query called at [/var/www/....../htdocs/model/persistence/SqlElement.php:2480]
2019-09-23 10:11:26.826 ***** ERROR ***** [V8.2.0] #1 SqlElement->getSqlElementsFromCriteria called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1112]
2019-09-23 10:11:26.826 ***** ERROR ***** [V8.2.0] #2 SqlElement->saveSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:733]
2019-09-23 10:11:26.826 ***** ERROR ***** [V8.2.0] #3 SqlElement->save called at [/var/www/....../htdocs/model/TenderMain.php:339]
2019-09-23 10:11:26.826 ***** ERROR ***** [V8.2.0] #4 TenderMain->save called at [/var/www/....../htdocs/tool/saveObject.php:78]
2019-09-23 10:11:26.826 ***** ERROR ***** [V8.2.0] Exception-[25P02] SQLSTATE[25P02]: In failed sql transaction: 7 ERROR: current transaction is aborted, commands ignored until end of transaction block
2019-09-23 10:11:26.827 ***** ERROR ***** [V8.2.0] For query : select * from indicatordefinition where indicatordefinition.nameIndicatorable='Tender' and indicatordefinition.idle=0 and indicatordefinition.idProject is null
2019-09-23 10:11:26.827 ***** ERROR ***** [V8.2.0] Strack trace :
2019-09-23 10:11:26.827 ***** ERROR ***** [V8.2.0] #0 Sql->query called at [/var/www/....../htdocs/model/persistence/SqlElement.php:2480]
2019-09-23 10:11:26.827 ***** ERROR ***** [V8.2.0] #1 SqlElement->getSqlElementsFromCriteria called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1115]
2019-09-23 10:11:26.827 ***** ERROR ***** [V8.2.0] #2 SqlElement->saveSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:733]
2019-09-23 10:11:26.827 ***** ERROR ***** [V8.2.0] #3 SqlElement->save called at [/var/www/....../htdocs/model/TenderMain.php:339]
2019-09-23 10:11:26.827 ***** ERROR ***** [V8.2.0] #4 TenderMain->save called at [/var/www/....../htdocs/tool/saveObject.php:78]
2019-09-23 10:11:26.828 ***** ERROR ***** [V8.2.0] Exception-[25P02] SQLSTATE[25P02]: In failed sql transaction: 7 ERROR: current transaction is aborted, commands ignored until end of transaction block
2019-09-23 10:11:26.828 ***** ERROR ***** [V8.2.0] For query : select * from billline where billline.refType='Tender' and billline.refId=2
2019-09-23 10:11:26.828 ***** ERROR ***** [V8.2.0] Strack trace :
2019-09-23 10:11:26.828 ***** ERROR ***** [V8.2.0] #0 Sql->query called at [/var/www/....../htdocs/model/persistence/SqlElement.php:2480]
2019-09-23 10:11:26.829 ***** ERROR ***** [V8.2.0] #1 SqlElement->getSqlElementsFromCriteria called at [/var/www/....../htdocs/model/TenderMain.php:348]
2019-09-23 10:11:26.829 ***** ERROR ***** [V8.2.0] #2 TenderMain->save called at [/var/www/....../htdocs/tool/saveObject.php:78]
2019-09-23 10:11:26.829 ***** ERROR ***** [V8.2.0] Exception-[25P02] SQLSTATE[25P02]: In failed sql transaction: 7 ERROR: current transaction is aborted, commands ignored until end of transaction block
2019-09-23 10:11:26.829 ***** ERROR ***** [V8.2.0] For query : select * from status where id=1
2019-09-23 10:11:26.830 ***** ERROR ***** [V8.2.0] Strack trace :
2019-09-23 10:11:26.830 ***** ERROR ***** [V8.2.0] #0 Sql->query called at [/var/www/....../htdocs/model/persistence/SqlElement.php:2939]
2019-09-23 10:11:26.830 ***** ERROR ***** [V8.2.0] #1 SqlElement->getSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:672]
2019-09-23 10:11:26.830 ***** ERROR ***** [V8.2.0] #2 SqlElement->__construct called at [/var/www/....../htdocs/model/StatusMain.php:82]
2019-09-23 10:11:26.830 ***** ERROR ***** [V8.2.0] #3 StatusMain->__construct called at [/var/www/....../htdocs/model/Status.php:39]
2019-09-23 10:11:26.830 ***** ERROR ***** [V8.2.0] #4 Status->__construct called at [/var/www/....../htdocs/model/persistence/SqlElement.php:6029]
2019-09-23 10:11:26.831 ***** ERROR ***** [V8.2.0] #5 SqlElement->recalculateCheckboxes called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1001]
2019-09-23 10:11:26.831 ***** ERROR ***** [V8.2.0] #6 SqlElement->saveSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:876]
2019-09-23 10:11:26.831 ***** ERROR ***** [V8.2.0] #7 SqlElement->saveForced called at [/var/www/....../htdocs/model/persistence/SqlElement.php:887]
2019-09-23 10:11:26.831 ***** ERROR ***** [V8.2.0] #8 SqlElement->simpleSave called at [/var/www/....../htdocs/model/TenderMain.php:389]
2019-09-23 10:11:26.831 ***** ERROR ***** [V8.2.0] #9 TenderMain->save called at [/var/www/....../htdocs/tool/saveObject.php:78]
2019-09-23 10:11:26.831 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.832 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.832 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.832 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.832 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.832 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'id' for Class 'Status' : field 'id' not found in Database.
2019-09-23 10:11:26.833 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.833 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.833 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.833 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.833 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'name' for Class 'Status' : field 'name' not found in Database.
2019-09-23 10:11:26.834 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.834 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.834 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.834 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.834 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'setHandledStatus' for Class 'Status' : field 'setHandledStatus' not found in Database.
2019-09-23 10:11:26.835 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.835 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.835 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.835 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.836 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'setDoneStatus' for Class 'Status' : field 'setDoneStatus' not found in Database.
2019-09-23 10:11:26.836 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.836 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.836 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.836 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.837 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'setIntoserviceStatus' for Class 'Status' : field 'setIntoserviceStatus' not found in Database.
2019-09-23 10:11:26.837 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.837 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.837 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.837 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.838 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.838 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'setIdleStatus' for Class 'Status' : field 'setIdleStatus' not found in Database.
2019-09-23 10:11:26.838 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.838 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.838 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.839 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.839 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'setCancelledStatus' for Class 'Status' : field 'setCancelledStatus' not found in Database.
2019-09-23 10:11:26.839 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.839 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.840 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.840 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.840 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'color' for Class 'Status' : field 'color' not found in Database.
2019-09-23 10:11:26.840 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.840 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.841 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.841 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.841 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'sortOrder' for Class 'Status' : field 'sortOrder' not found in Database.
2019-09-23 10:11:26.841 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.841 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.842 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.842 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.842 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'idle' for Class 'Status' : field 'idle' not found in Database.
2019-09-23 10:11:26.842 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.842 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.843 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.843 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.843 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.843 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'isCopyStatus' for Class 'Status' : field 'isCopyStatus' not found in Database.
2019-09-23 10:11:26.843 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.844 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.844 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.844 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.844 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'setSubmittedLeave' for Class 'Status' : field 'setSubmittedLeave' not found in Database.
2019-09-23 10:11:26.844 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.845 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.845 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.845 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.845 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'setAcceptedLeave' for Class 'Status' : field 'setAcceptedLeave' not found in Database.
2019-09-23 10:11:26.846 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.846 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.846 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.846 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.846 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'setRejectedLeave' for Class 'Status' : field 'setRejectedLeave' not found in Database.
2019-09-23 10:11:26.847 ***** ERROR ***** [V8.2.0] Exception-[25P02] SQLSTATE[25P02]: In failed sql transaction: 7 ERROR: current transaction is aborted, commands ignored until end of transaction block
2019-09-23 10:11:26.847 ***** ERROR ***** [V8.2.0] For query : select * from type where id=114 and scope = 'Tender'
2019-09-23 10:11:26.847 ***** ERROR ***** [V8.2.0] Strack trace :
2019-09-23 10:11:26.847 ***** ERROR ***** [V8.2.0] #0 Sql->query called at [/var/www/....../htdocs/model/persistence/SqlElement.php:2939]
2019-09-23 10:11:26.847 ***** ERROR ***** [V8.2.0] #1 SqlElement->getSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:672]
2019-09-23 10:11:26.848 ***** ERROR ***** [V8.2.0] #2 SqlElement->__construct called at [/var/www/....../htdocs/model/TenderType.php:89]
2019-09-23 10:11:26.848 ***** ERROR ***** [V8.2.0] #3 TenderType->__construct called at [/var/www/....../htdocs/model/persistence/SqlElement.php:6036]
2019-09-23 10:11:26.848 ***** ERROR ***** [V8.2.0] #4 SqlElement->recalculateCheckboxes called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1001]
2019-09-23 10:11:26.848 ***** ERROR ***** [V8.2.0] #5 SqlElement->saveSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:876]
2019-09-23 10:11:26.848 ***** ERROR ***** [V8.2.0] #6 SqlElement->saveForced called at [/var/www/....../htdocs/model/persistence/SqlElement.php:887]
2019-09-23 10:11:26.848 ***** ERROR ***** [V8.2.0] #7 SqlElement->simpleSave called at [/var/www/....../htdocs/model/TenderMain.php:389]
2019-09-23 10:11:26.849 ***** ERROR ***** [V8.2.0] #8 TenderMain->save called at [/var/www/....../htdocs/tool/saveObject.php:78]
2019-09-23 10:11:26.849 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.849 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.849 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.849 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.850 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'id' for Class 'TenderType' : field 'id' not found in Database.
2019-09-23 10:11:26.850 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.850 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.850 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.850 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.851 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.851 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'name' for Class 'TenderType' : field 'name' not found in Database.
2019-09-23 10:11:26.851 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.851 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.851 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.852 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.852 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'code' for Class 'TenderType' : field 'code' not found in Database.
2019-09-23 10:11:26.852 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.852 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.853 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.853 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.853 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'idWorkflow' for Class 'TenderType' : field 'idWorkflow' not found in Database.
2019-09-23 10:11:26.853 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.853 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.854 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.854 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.854 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'sortOrder' for Class 'TenderType' : field 'sortOrder' not found in Database.
2019-09-23 10:11:26.854 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.854 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.855 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.855 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.855 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.855 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'idle' for Class 'TenderType' : field 'idle' not found in Database.
2019-09-23 10:11:26.855 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.856 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.856 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.856 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.856 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'description' for Class 'TenderType' : field 'description' not found in Database.
2019-09-23 10:11:26.857 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.857 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.857 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.857 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.857 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'mandatoryDescription' for Class 'TenderType' : field 'mandatoryDescription' not found in Database.
2019-09-23 10:11:26.858 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.858 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.858 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.858 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.858 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'mandatoryResourceOnHandled' for Class 'TenderType' : field 'mandatoryResourceOnHandled' not found in Database.
2019-09-23 10:11:26.859 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.859 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.859 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.859 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.859 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'mandatoryResultOnDone' for Class 'TenderType' : field 'mandatoryResultOnDone' not found in Database.
2019-09-23 10:11:26.860 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.860 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.860 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.860 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.861 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'lockHandled' for Class 'TenderType' : field 'lockHandled' not found in Database.
2019-09-23 10:11:26.861 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.861 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.861 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.861 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.862 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.862 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'lockDone' for Class 'TenderType' : field 'lockDone' not found in Database.
2019-09-23 10:11:26.862 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.862 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.862 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.863 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.863 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'lockIdle' for Class 'TenderType' : field 'lockIdle' not found in Database.
2019-09-23 10:11:26.863 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.863 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.864 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.864 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.864 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'lockCancelled' for Class 'TenderType' : field 'lockCancelled' not found in Database.
2019-09-23 10:11:26.864 ***** ERROR ***** [V8.2.0] Exception-[25P02] SQLSTATE[25P02]: In failed sql transaction: 7 ERROR: current transaction is aborted, commands ignored until end of transaction block
2019-09-23 10:11:26.865 ***** ERROR ***** [V8.2.0] For query : select * from tender where id=2
2019-09-23 10:11:26.865 ***** ERROR ***** [V8.2.0] Strack trace :
2019-09-23 10:11:26.865 ***** ERROR ***** [V8.2.0] #0 Sql->query called at [/var/www/....../htdocs/model/persistence/SqlElement.php:2939]
2019-09-23 10:11:26.865 ***** ERROR ***** [V8.2.0] #1 SqlElement->getSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:672]
2019-09-23 10:11:26.865 ***** ERROR ***** [V8.2.0] #2 SqlElement->__construct called at [/var/www/....../htdocs/model/TenderMain.php:151]
2019-09-23 10:11:26.865 ***** ERROR ***** [V8.2.0] #3 TenderMain->__construct called at [/var/www/....../htdocs/model/Tender.php:39]
2019-09-23 10:11:26.865 ***** ERROR ***** [V8.2.0] #4 Tender->__construct called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1036]
2019-09-23 10:11:26.866 ***** ERROR ***** [V8.2.0] #5 SqlElement->saveSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:876]
2019-09-23 10:11:26.866 ***** ERROR ***** [V8.2.0] #6 SqlElement->saveForced called at [/var/www/....../htdocs/model/persistence/SqlElement.php:887]
2019-09-23 10:11:26.866 ***** ERROR ***** [V8.2.0] #7 SqlElement->simpleSave called at [/var/www/....../htdocs/model/TenderMain.php:389]
2019-09-23 10:11:26.866 ***** ERROR ***** [V8.2.0] #8 TenderMain->save called at [/var/www/....../htdocs/tool/saveObject.php:78]
2019-09-23 10:11:26.866 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.866 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.867 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.867 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.867 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.867 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'id' for Class 'Tender' : field 'id' not found in Database.
2019-09-23 10:11:26.867 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.868 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.868 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.868 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.868 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'reference' for Class 'Tender' : field 'reference' not found in Database.
2019-09-23 10:11:26.869 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.869 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.869 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.869 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.869 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'name' for Class 'Tender' : field 'name' not found in Database.
2019-09-23 10:11:26.870 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.870 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.870 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.870 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.870 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'idTenderType' for Class 'Tender' : field 'idTenderType' not found in Database.
2019-09-23 10:11:26.871 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.871 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.871 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.871 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.872 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'idProject' for Class 'Tender' : field 'idProject' not found in Database.
2019-09-23 10:11:26.872 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.872 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.872 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.872 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.873 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'idCallForTender' for Class 'Tender' : field 'idCallForTender' not found in Database.
2019-09-23 10:11:26.873 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.873 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.873 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.873 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.874 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'idTenderStatus' for Class 'Tender' : field 'idTenderStatus' not found in Database.
2019-09-23 10:11:26.874 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.874 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.874 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.874 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.875 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.875 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'idUser' for Class 'Tender' : field 'idUser' not found in Database.
2019-09-23 10:11:26.875 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.875 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.875 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.876 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.876 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'creationDate' for Class 'Tender' : field 'creationDate' not found in Database.
2019-09-23 10:11:26.876 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.876 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.877 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.877 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.877 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'idProvider' for Class 'Tender' : field 'idProvider' not found in Database.
2019-09-23 10:11:26.877 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.877 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.878 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.878 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.878 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'externalReference' for Class 'Tender' : field 'externalReference' not found in Database.
2019-09-23 10:11:26.878 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.878 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.879 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.879 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.879 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.879 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'description' for Class 'Tender' : field 'description' not found in Database.
2019-09-23 10:11:26.879 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.880 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.880 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.880 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.880 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'idStatus' for Class 'Tender' : field 'idStatus' not found in Database.
2019-09-23 10:11:26.880 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.881 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.881 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.881 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.881 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'idResource' for Class 'Tender' : field 'idResource' not found in Database.
2019-09-23 10:11:26.881 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.882 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.882 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.882 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.882 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'idContact' for Class 'Tender' : field 'idContact' not found in Database.
2019-09-23 10:11:26.882 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.883 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.883 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.883 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.883 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'requestDateTime' for Class 'Tender' : field 'requestDateTime' not found in Database.
2019-09-23 10:11:26.884 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.884 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.884 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.884 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.884 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'expectedTenderDateTime' for Class 'Tender' : field 'expectedTenderDateTime' not found in Database.
2019-09-23 10:11:26.885 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.885 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.885 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.885 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.885 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'receptionDateTime' for Class 'Tender' : field 'receptionDateTime' not found in Database.
2019-09-23 10:11:26.886 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.886 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.886 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.886 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.886 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'offerValidityEndDate' for Class 'Tender' : field 'offerValidityEndDate' not found in Database.
2019-09-23 10:11:26.887 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.887 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.887 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.887 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.888 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'untaxedAmount' for Class 'Tender' : field 'untaxedAmount' not found in Database.
2019-09-23 10:11:26.888 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.888 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.888 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.888 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.889 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'taxPct' for Class 'Tender' : field 'taxPct' not found in Database.
2019-09-23 10:11:26.889 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.889 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.889 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.889 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.890 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.890 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'taxAmount' for Class 'Tender' : field 'taxAmount' not found in Database.
2019-09-23 10:11:26.890 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.890 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.890 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.891 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.891 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'fullAmount' for Class 'Tender' : field 'fullAmount' not found in Database.
2019-09-23 10:11:26.891 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.891 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.892 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.892 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.892 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'discountAmount' for Class 'Tender' : field 'discountAmount' not found in Database.
2019-09-23 10:11:26.892 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.892 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.893 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.893 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.893 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.893 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'discountRate' for Class 'Tender' : field 'discountRate' not found in Database.
2019-09-23 10:11:26.893 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.894 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.894 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.894 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.894 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'discountFullAmount' for Class 'Tender' : field 'discountFullAmount' not found in Database.
2019-09-23 10:11:26.894 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.895 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.895 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.895 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.895 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'totalUntaxedAmount' for Class 'Tender' : field 'totalUntaxedAmount' not found in Database.
2019-09-23 10:11:26.895 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.896 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.896 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.896 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.896 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'discountFrom' for Class 'Tender' : field 'discountFrom' not found in Database.
2019-09-23 10:11:26.897 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.897 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.897 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.897 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.897 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'totalTaxAmount' for Class 'Tender' : field 'totalTaxAmount' not found in Database.
2019-09-23 10:11:26.898 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.898 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.898 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.898 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.898 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'totalFullAmount' for Class 'Tender' : field 'totalFullAmount' not found in Database.
2019-09-23 10:11:26.899 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.899 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.899 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.899 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.899 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'idProjectExpense' for Class 'Tender' : field 'idProjectExpense' not found in Database.
2019-09-23 10:11:26.900 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.900 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.900 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.900 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.900 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'paymentCondition' for Class 'Tender' : field 'paymentCondition' not found in Database.
2019-09-23 10:11:26.901 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.901 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.901 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.901 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.902 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'deliveryDelay' for Class 'Tender' : field 'deliveryDelay' not found in Database.
2019-09-23 10:11:26.902 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.902 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.902 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.902 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.903 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'deliveryDate' for Class 'Tender' : field 'deliveryDate' not found in Database.
2019-09-23 10:11:26.903 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.903 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.903 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.904 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.904 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.904 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'handled' for Class 'Tender' : field 'handled' not found in Database.
2019-09-23 10:11:26.904 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.904 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.905 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.905 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.905 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'handledDate' for Class 'Tender' : field 'handledDate' not found in Database.
2019-09-23 10:11:26.905 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.905 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.906 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.906 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.906 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.906 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'done' for Class 'Tender' : field 'done' not found in Database.
2019-09-23 10:11:26.906 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.907 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.907 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.907 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.907 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'doneDate' for Class 'Tender' : field 'doneDate' not found in Database.
2019-09-23 10:11:26.907 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.908 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.908 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.908 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.908 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'idle' for Class 'Tender' : field 'idle' not found in Database.
2019-09-23 10:11:26.909 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.909 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.909 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.909 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.909 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'idleDate' for Class 'Tender' : field 'idleDate' not found in Database.
2019-09-23 10:11:26.910 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.910 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.910 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.910 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.910 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'cancelled' for Class 'Tender' : field 'cancelled' not found in Database.
2019-09-23 10:11:26.911 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.911 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.911 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.911 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.911 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'result' for Class 'Tender' : field 'result' not found in Database.
2019-09-23 10:11:26.912 ***** ERROR ***** [V8.2.0] Exception-[25P02] SQLSTATE[25P02]: In failed sql transaction: 7 ERROR: current transaction is aborted, commands ignored until end of transaction block
2019-09-23 10:11:26.912 ***** ERROR ***** [V8.2.0] For query : select id from billline where refId ='2' and refType ='Tender' order by id desc
2019-09-23 10:11:26.912 ***** ERROR ***** [V8.2.0] Strack trace :
2019-09-23 10:11:26.912 ***** ERROR ***** [V8.2.0] #0 Sql->query called at [/var/www/....../htdocs/model/persistence/SqlElement.php:3113]
2019-09-23 10:11:26.913 ***** ERROR ***** [V8.2.0] #1 SqlElement->getDependantSqlElements called at [/var/www/....../htdocs/model/persistence/SqlElement.php:2984]
2019-09-23 10:11:26.913 ***** ERROR ***** [V8.2.0] #2 SqlElement->getSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:672]
2019-09-23 10:11:26.913 ***** ERROR ***** [V8.2.0] #3 SqlElement->__construct called at [/var/www/....../htdocs/model/TenderMain.php:151]
2019-09-23 10:11:26.913 ***** ERROR ***** [V8.2.0] #4 TenderMain->__construct called at [/var/www/....../htdocs/model/Tender.php:39]
2019-09-23 10:11:26.913 ***** ERROR ***** [V8.2.0] #5 Tender->__construct called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1036]
2019-09-23 10:11:26.913 ***** ERROR ***** [V8.2.0] #6 SqlElement->saveSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:876]
2019-09-23 10:11:26.913 ***** ERROR ***** [V8.2.0] #7 SqlElement->saveForced called at [/var/www/....../htdocs/model/persistence/SqlElement.php:887]
2019-09-23 10:11:26.914 ***** ERROR ***** [V8.2.0] #8 SqlElement->simpleSave called at [/var/www/....../htdocs/model/TenderMain.php:389]
2019-09-23 10:11:26.914 ***** ERROR ***** [V8.2.0] #9 TenderMain->save called at [/var/www/....../htdocs/tool/saveObject.php:78]
2019-09-23 10:11:26.914 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.914 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.915 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.915 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.915 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.915 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'evaluationValue' for Class 'Tender' : field 'evaluationValue' not found in Database.
2019-09-23 10:11:26.916 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.916 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.916 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.916 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.917 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'evaluationRank' for Class 'Tender' : field 'evaluationRank' not found in Database.
2019-09-23 10:11:26.917 ***** ERROR ***** [V8.2.0] Exception-[25P02] SQLSTATE[25P02]: In failed sql transaction: 7 ERROR: current transaction is aborted, commands ignored until end of transaction block
2019-09-23 10:11:26.917 ***** ERROR ***** [V8.2.0] For query : select * from link where ( ref1Type='Tender' and ref1Id=2) or ( ref2Type='Tender' and ref2Id=2 )
2019-09-23 10:11:26.917 ***** ERROR ***** [V8.2.0] Strack trace :
2019-09-23 10:11:26.917 ***** ERROR ***** [V8.2.0] #0 Sql->query called at [/var/www/....../htdocs/model/persistence/SqlElement.php:2480]
2019-09-23 10:11:26.918 ***** ERROR ***** [V8.2.0] #1 SqlElement->getSqlElementsFromCriteria called at [/var/www/....../htdocs/model/Link.php:170]
2019-09-23 10:11:26.918 ***** ERROR ***** [V8.2.0] #2 Link->getLinksForObject called at [/var/www/....../htdocs/model/persistence/SqlElement.php:2953]
2019-09-23 10:11:26.918 ***** ERROR ***** [V8.2.0] #3 SqlElement->getSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:672]
2019-09-23 10:11:26.918 ***** ERROR ***** [V8.2.0] #4 SqlElement->__construct called at [/var/www/....../htdocs/model/TenderMain.php:151]
2019-09-23 10:11:26.918 ***** ERROR ***** [V8.2.0] #5 TenderMain->__construct called at [/var/www/....../htdocs/model/Tender.php:39]
2019-09-23 10:11:26.918 ***** ERROR ***** [V8.2.0] #6 Tender->__construct called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1036]
2019-09-23 10:11:26.918 ***** ERROR ***** [V8.2.0] #7 SqlElement->saveSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:876]
2019-09-23 10:11:26.919 ***** ERROR ***** [V8.2.0] #8 SqlElement->saveForced called at [/var/www/....../htdocs/model/persistence/SqlElement.php:887]
2019-09-23 10:11:26.919 ***** ERROR ***** [V8.2.0] #9 SqlElement->simpleSave called at [/var/www/....../htdocs/model/TenderMain.php:389]
2019-09-23 10:11:26.919 ***** ERROR ***** [V8.2.0] #10 TenderMain->save called at [/var/www/....../htdocs/tool/saveObject.php:78]
2019-09-23 10:11:26.919 ***** ERROR ***** [V8.2.0] Exception-[25P02] SQLSTATE[25P02]: In failed sql transaction: 7 ERROR: current transaction is aborted, commands ignored until end of transaction block
2019-09-23 10:11:26.920 ***** ERROR ***** [V8.2.0] For query : select id from attachment where refId ='2' and refType ='Tender' order by id desc
2019-09-23 10:11:26.920 ***** ERROR ***** [V8.2.0] Strack trace :
2019-09-23 10:11:26.920 ***** ERROR ***** [V8.2.0] #0 Sql->query called at [/var/www/....../htdocs/model/persistence/SqlElement.php:3113]
2019-09-23 10:11:26.921 ***** ERROR ***** [V8.2.0] #1 SqlElement->getDependantSqlElements called at [/var/www/....../htdocs/model/persistence/SqlElement.php:2984]
2019-09-23 10:11:26.921 ***** ERROR ***** [V8.2.0] #2 SqlElement->getSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:672]
2019-09-23 10:11:26.921 ***** ERROR ***** [V8.2.0] #3 SqlElement->__construct called at [/var/www/....../htdocs/model/TenderMain.php:151]
2019-09-23 10:11:26.921 ***** ERROR ***** [V8.2.0] #4 TenderMain->__construct called at [/var/www/....../htdocs/model/Tender.php:39]
2019-09-23 10:11:26.922 ***** ERROR ***** [V8.2.0] #5 Tender->__construct called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1036]
2019-09-23 10:11:26.922 ***** ERROR ***** [V8.2.0] #6 SqlElement->saveSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:876]
2019-09-23 10:11:26.922 ***** ERROR ***** [V8.2.0] #7 SqlElement->saveForced called at [/var/www/....../htdocs/model/persistence/SqlElement.php:887]
2019-09-23 10:11:26.923 ***** ERROR ***** [V8.2.0] #8 SqlElement->simpleSave called at [/var/www/....../htdocs/model/TenderMain.php:389]
2019-09-23 10:11:26.923 ***** ERROR ***** [V8.2.0] #9 TenderMain->save called at [/var/www/....../htdocs/tool/saveObject.php:78]
2019-09-23 10:11:26.924 ***** ERROR ***** [V8.2.0] Exception-[25P02] SQLSTATE[25P02]: In failed sql transaction: 7 ERROR: current transaction is aborted, commands ignored until end of transaction block
2019-09-23 10:11:26.924 ***** ERROR ***** [V8.2.0] For query : select id from note where refId ='2' and refType ='Tender' order by id desc
2019-09-23 10:11:26.925 ***** ERROR ***** [V8.2.0] Strack trace :
2019-09-23 10:11:26.925 ***** ERROR ***** [V8.2.0] #0 Sql->query called at [/var/www/....../htdocs/model/persistence/SqlElement.php:3113]
2019-09-23 10:11:26.925 ***** ERROR ***** [V8.2.0] #1 SqlElement->getDependantSqlElements called at [/var/www/....../htdocs/model/persistence/SqlElement.php:2984]
2019-09-23 10:11:26.926 ***** ERROR ***** [V8.2.0] #2 SqlElement->getSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:672]
2019-09-23 10:11:26.926 ***** ERROR ***** [V8.2.0] #3 SqlElement->__construct called at [/var/www/....../htdocs/model/TenderMain.php:151]
2019-09-23 10:11:26.926 ***** ERROR ***** [V8.2.0] #4 TenderMain->__construct called at [/var/www/....../htdocs/model/Tender.php:39]
2019-09-23 10:11:26.926 ***** ERROR ***** [V8.2.0] #5 Tender->__construct called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1036]
2019-09-23 10:11:26.927 ***** ERROR ***** [V8.2.0] #6 SqlElement->saveSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:876]
2019-09-23 10:11:26.927 ***** ERROR ***** [V8.2.0] #7 SqlElement->saveForced called at [/var/www/....../htdocs/model/persistence/SqlElement.php:887]
2019-09-23 10:11:26.927 ***** ERROR ***** [V8.2.0] #8 SqlElement->simpleSave called at [/var/www/....../htdocs/model/TenderMain.php:389]
2019-09-23 10:11:26.928 ***** ERROR ***** [V8.2.0] #9 TenderMain->save called at [/var/www/....../htdocs/tool/saveObject.php:78]
2019-09-23 10:11:26.928 ***** ERROR ***** [V8.2.0] Exception-[25P02] SQLSTATE[25P02]: In failed sql transaction: 7 ERROR: current transaction is aborted, commands ignored until end of transaction block
2019-09-23 10:11:26.929 ***** ERROR ***** [V8.2.0] For query : select * from tender where id=2
2019-09-23 10:11:26.929 ***** ERROR ***** [V8.2.0] Strack trace :
2019-09-23 10:11:26.929 ***** ERROR ***** [V8.2.0] #0 Sql->query called at [/var/www/....../htdocs/model/persistence/SqlElement.php:2939]
2019-09-23 10:11:26.930 ***** ERROR ***** [V8.2.0] #1 SqlElement->getSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:672]
2019-09-23 10:11:26.930 ***** ERROR ***** [V8.2.0] #2 SqlElement->__construct called at [/var/www/....../htdocs/model/TenderMain.php:151]
2019-09-23 10:11:26.930 ***** ERROR ***** [V8.2.0] #3 TenderMain->__construct called at [/var/www/....../htdocs/model/Tender.php:39]
2019-09-23 10:11:26.931 ***** ERROR ***** [V8.2.0] #4 Tender->__construct called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1330]
2019-09-23 10:11:26.931 ***** ERROR ***** [V8.2.0] #5 SqlElement->getCurrentObject called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1430]
2019-09-23 10:11:26.931 ***** ERROR ***** [V8.2.0] #6 SqlElement->updateSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1064]
2019-09-23 10:11:26.932 ***** ERROR ***** [V8.2.0] #7 SqlElement->saveSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:876]
2019-09-23 10:11:26.932 ***** ERROR ***** [V8.2.0] #8 SqlElement->saveForced called at [/var/www/....../htdocs/model/persistence/SqlElement.php:887]
2019-09-23 10:11:26.932 ***** ERROR ***** [V8.2.0] #9 SqlElement->simpleSave called at [/var/www/....../htdocs/model/TenderMain.php:389]
2019-09-23 10:11:26.933 ***** ERROR ***** [V8.2.0] #10 TenderMain->save called at [/var/www/....../htdocs/tool/saveObject.php:78]
2019-09-23 10:11:26.933 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.933 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.934 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.934 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.934 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.935 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.935 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'id' for Class 'Tender' : field 'id' not found in Database.
2019-09-23 10:11:26.935 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.935 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.936 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.936 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.936 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.937 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.937 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'reference' for Class 'Tender' : field 'reference' not found in Database.
2019-09-23 10:11:26.937 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.938 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.938 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.938 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.939 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.939 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.939 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'name' for Class 'Tender' : field 'name' not found in Database.
2019-09-23 10:11:26.940 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.940 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.940 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.941 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.941 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.941 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.942 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'idTenderType' for Class 'Tender' : field 'idTenderType' not found in Database.
2019-09-23 10:11:26.942 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.942 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.942 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.943 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.943 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.943 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.944 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'idProject' for Class 'Tender' : field 'idProject' not found in Database.
2019-09-23 10:11:26.944 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.944 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.945 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.945 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.945 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.946 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.946 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'idCallForTender' for Class 'Tender' : field 'idCallForTender' not found in Database.
2019-09-23 10:11:26.946 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.946 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.947 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.947 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.947 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.948 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.948 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'idTenderStatus' for Class 'Tender' : field 'idTenderStatus' not found in Database.
2019-09-23 10:11:26.948 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.949 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.949 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.949 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.949 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.950 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.950 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'idUser' for Class 'Tender' : field 'idUser' not found in Database.
2019-09-23 10:11:26.950 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.951 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.951 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.951 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.952 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.952 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.952 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'creationDate' for Class 'Tender' : field 'creationDate' not found in Database.
2019-09-23 10:11:26.953 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.953 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.953 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.954 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.954 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.954 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'idProvider' for Class 'Tender' : field 'idProvider' not found in Database.
2019-09-23 10:11:26.955 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.955 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.955 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.956 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.956 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.956 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.957 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'externalReference' for Class 'Tender' : field 'externalReference' not found in Database.
2019-09-23 10:11:26.957 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.957 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.958 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.958 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.958 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.959 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'description' for Class 'Tender' : field 'description' not found in Database.
2019-09-23 10:11:26.959 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.959 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.960 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.960 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.960 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.961 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.961 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'idStatus' for Class 'Tender' : field 'idStatus' not found in Database.
2019-09-23 10:11:26.961 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.962 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.962 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.962 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.963 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.963 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.963 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'idResource' for Class 'Tender' : field 'idResource' not found in Database.
2019-09-23 10:11:26.963 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.964 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.964 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.964 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.965 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.965 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.965 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'idContact' for Class 'Tender' : field 'idContact' not found in Database.
2019-09-23 10:11:26.966 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.966 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.966 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.967 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.967 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.967 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.967 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'requestDateTime' for Class 'Tender' : field 'requestDateTime' not found in Database.
2019-09-23 10:11:26.968 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.968 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.969 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.969 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.969 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.970 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.970 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'expectedTenderDateTime' for Class 'Tender' : field 'expectedTenderDateTime' not found in Database.
2019-09-23 10:11:26.971 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.971 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.972 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.973 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.973 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.973 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.974 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'receptionDateTime' for Class 'Tender' : field 'receptionDateTime' not found in Database.
2019-09-23 10:11:26.974 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.975 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.976 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.976 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.977 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.977 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.978 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'offerValidityEndDate' for Class 'Tender' : field 'offerValidityEndDate' not found in Database.
2019-09-23 10:11:26.978 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.979 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.979 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.980 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.980 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.981 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.981 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'untaxedAmount' for Class 'Tender' : field 'untaxedAmount' not found in Database.
2019-09-23 10:11:26.982 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.982 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.983 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.983 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.984 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.985 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.985 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'taxPct' for Class 'Tender' : field 'taxPct' not found in Database.
2019-09-23 10:11:26.986 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.986 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.987 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.987 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.988 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.988 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.989 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'taxAmount' for Class 'Tender' : field 'taxAmount' not found in Database.
2019-09-23 10:11:26.989 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.990 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.990 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.991 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.991 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.991 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.992 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'fullAmount' for Class 'Tender' : field 'fullAmount' not found in Database.
2019-09-23 10:11:26.992 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.993 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.993 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.994 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.994 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.995 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.995 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'discountAmount' for Class 'Tender' : field 'discountAmount' not found in Database.
2019-09-23 10:11:26.996 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.996 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:26.997 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.997 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:26.998 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:26.998 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:26.999 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'discountRate' for Class 'Tender' : field 'discountRate' not found in Database.
2019-09-23 10:11:26.999 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.000 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:27.000 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.001 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.001 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:27.002 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.002 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'discountFullAmount' for Class 'Tender' : field 'discountFullAmount' not found in Database.
2019-09-23 10:11:27.003 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.003 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:27.004 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.004 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.005 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:27.005 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.006 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'totalUntaxedAmount' for Class 'Tender' : field 'totalUntaxedAmount' not found in Database.
2019-09-23 10:11:27.006 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.007 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:27.007 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.008 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.008 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:27.009 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.009 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'discountFrom' for Class 'Tender' : field 'discountFrom' not found in Database.
2019-09-23 10:11:27.010 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.010 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:27.011 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.011 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.012 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:27.012 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.013 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'totalTaxAmount' for Class 'Tender' : field 'totalTaxAmount' not found in Database.
2019-09-23 10:11:27.013 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.014 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:27.014 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.015 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.015 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:27.016 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.016 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'totalFullAmount' for Class 'Tender' : field 'totalFullAmount' not found in Database.
2019-09-23 10:11:27.017 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.017 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:27.018 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.018 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.019 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:27.019 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.019 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'idProjectExpense' for Class 'Tender' : field 'idProjectExpense' not found in Database.
2019-09-23 10:11:27.020 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.021 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:27.021 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.021 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.022 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:27.022 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.023 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'paymentCondition' for Class 'Tender' : field 'paymentCondition' not found in Database.
2019-09-23 10:11:27.023 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.024 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:27.024 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.025 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.025 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:27.026 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.026 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'deliveryDelay' for Class 'Tender' : field 'deliveryDelay' not found in Database.
2019-09-23 10:11:27.027 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.027 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:27.028 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.028 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.029 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:27.029 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.030 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'deliveryDate' for Class 'Tender' : field 'deliveryDate' not found in Database.
2019-09-23 10:11:27.030 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.031 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:27.031 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.032 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.032 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:27.033 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.033 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'handled' for Class 'Tender' : field 'handled' not found in Database.
2019-09-23 10:11:27.034 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.034 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:27.035 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.035 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.036 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:27.036 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.037 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'handledDate' for Class 'Tender' : field 'handledDate' not found in Database.
2019-09-23 10:11:27.037 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.038 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:27.038 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.039 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.039 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:27.039 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.040 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'done' for Class 'Tender' : field 'done' not found in Database.
2019-09-23 10:11:27.040 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.041 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:27.041 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.041 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.042 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:27.042 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.042 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'doneDate' for Class 'Tender' : field 'doneDate' not found in Database.
2019-09-23 10:11:27.042 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.043 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:27.043 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.043 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.044 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:27.044 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.044 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'idle' for Class 'Tender' : field 'idle' not found in Database.
2019-09-23 10:11:27.045 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.045 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:27.045 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.046 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.046 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:27.046 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.046 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'idleDate' for Class 'Tender' : field 'idleDate' not found in Database.
2019-09-23 10:11:27.047 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.047 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:27.047 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.048 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.048 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:27.048 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.049 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'cancelled' for Class 'Tender' : field 'cancelled' not found in Database.
2019-09-23 10:11:27.049 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.049 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:27.050 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.050 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.050 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:27.051 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'result' for Class 'Tender' : field 'result' not found in Database.
2019-09-23 10:11:27.052 ***** ERROR ***** [V8.2.0] Exception-[25P02] SQLSTATE[25P02]: In failed sql transaction: 7 ERROR: current transaction is aborted, commands ignored until end of transaction block
2019-09-23 10:11:27.052 ***** ERROR ***** [V8.2.0] For query : select id from billline where refId ='2' and refType ='Tender' order by id desc
2019-09-23 10:11:27.052 ***** ERROR ***** [V8.2.0] Strack trace :
2019-09-23 10:11:27.053 ***** ERROR ***** [V8.2.0] #0 Sql->query called at [/var/www/....../htdocs/model/persistence/SqlElement.php:3113]
2019-09-23 10:11:27.053 ***** ERROR ***** [V8.2.0] #1 SqlElement->getDependantSqlElements called at [/var/www/....../htdocs/model/persistence/SqlElement.php:2984]
2019-09-23 10:11:27.053 ***** ERROR ***** [V8.2.0] #2 SqlElement->getSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:672]
2019-09-23 10:11:27.054 ***** ERROR ***** [V8.2.0] #3 SqlElement->__construct called at [/var/www/....../htdocs/model/TenderMain.php:151]
2019-09-23 10:11:27.054 ***** ERROR ***** [V8.2.0] #4 TenderMain->__construct called at [/var/www/....../htdocs/model/Tender.php:39]
2019-09-23 10:11:27.054 ***** ERROR ***** [V8.2.0] #5 Tender->__construct called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1330]
2019-09-23 10:11:27.055 ***** ERROR ***** [V8.2.0] #6 SqlElement->getCurrentObject called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1430]
2019-09-23 10:11:27.055 ***** ERROR ***** [V8.2.0] #7 SqlElement->updateSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1064]
2019-09-23 10:11:27.055 ***** ERROR ***** [V8.2.0] #8 SqlElement->saveSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:876]
2019-09-23 10:11:27.055 ***** ERROR ***** [V8.2.0] #9 SqlElement->saveForced called at [/var/www/....../htdocs/model/persistence/SqlElement.php:887]
2019-09-23 10:11:27.056 ***** ERROR ***** [V8.2.0] #10 SqlElement->simpleSave called at [/var/www/....../htdocs/model/TenderMain.php:389]
2019-09-23 10:11:27.056 ***** ERROR ***** [V8.2.0] #11 TenderMain->save called at [/var/www/....../htdocs/tool/saveObject.php:78]
2019-09-23 10:11:27.056 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.057 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:27.057 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.057 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.058 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:27.058 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.058 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'evaluationValue' for Class 'Tender' : field 'evaluationValue' not found in Database.
2019-09-23 10:11:27.059 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.059 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:27.059 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.060 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.060 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:27.060 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.061 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'evaluationRank' for Class 'Tender' : field 'evaluationRank' not found in Database.
2019-09-23 10:11:27.062 ***** ERROR ***** [V8.2.0] Exception-[25P02] SQLSTATE[25P02]: In failed sql transaction: 7 ERROR: current transaction is aborted, commands ignored until end of transaction block
2019-09-23 10:11:27.062 ***** ERROR ***** [V8.2.0] For query : select * from link where ( ref1Type='Tender' and ref1Id=2) or ( ref2Type='Tender' and ref2Id=2 )
2019-09-23 10:11:27.062 ***** ERROR ***** [V8.2.0] Strack trace :
2019-09-23 10:11:27.063 ***** ERROR ***** [V8.2.0] #0 Sql->query called at [/var/www/....../htdocs/model/persistence/SqlElement.php:2480]
2019-09-23 10:11:27.063 ***** ERROR ***** [V8.2.0] #1 SqlElement->getSqlElementsFromCriteria called at [/var/www/....../htdocs/model/Link.php:170]
2019-09-23 10:11:27.063 ***** ERROR ***** [V8.2.0] #2 Link->getLinksForObject called at [/var/www/....../htdocs/model/persistence/SqlElement.php:2953]
2019-09-23 10:11:27.064 ***** ERROR ***** [V8.2.0] #3 SqlElement->getSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:672]
2019-09-23 10:11:27.064 ***** ERROR ***** [V8.2.0] #4 SqlElement->__construct called at [/var/www/....../htdocs/model/TenderMain.php:151]
2019-09-23 10:11:27.064 ***** ERROR ***** [V8.2.0] #5 TenderMain->__construct called at [/var/www/....../htdocs/model/Tender.php:39]
2019-09-23 10:11:27.065 ***** ERROR ***** [V8.2.0] #6 Tender->__construct called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1330]
2019-09-23 10:11:27.065 ***** ERROR ***** [V8.2.0] #7 SqlElement->getCurrentObject called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1430]
2019-09-23 10:11:27.065 ***** ERROR ***** [V8.2.0] #8 SqlElement->updateSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1064]
2019-09-23 10:11:27.066 ***** ERROR ***** [V8.2.0] #9 SqlElement->saveSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:876]
2019-09-23 10:11:27.066 ***** ERROR ***** [V8.2.0] #10 SqlElement->saveForced called at [/var/www/....../htdocs/model/persistence/SqlElement.php:887]
2019-09-23 10:11:27.066 ***** ERROR ***** [V8.2.0] #11 SqlElement->simpleSave called at [/var/www/....../htdocs/model/TenderMain.php:389]
2019-09-23 10:11:27.066 ***** ERROR ***** [V8.2.0] #12 TenderMain->save called at [/var/www/....../htdocs/tool/saveObject.php:78]
2019-09-23 10:11:27.067 ***** ERROR ***** [V8.2.0] Exception-[25P02] SQLSTATE[25P02]: In failed sql transaction: 7 ERROR: current transaction is aborted, commands ignored until end of transaction block
2019-09-23 10:11:27.068 ***** ERROR ***** [V8.2.0] For query : select id from attachment where refId ='2' and refType ='Tender' order by id desc
2019-09-23 10:11:27.068 ***** ERROR ***** [V8.2.0] Strack trace :
2019-09-23 10:11:27.068 ***** ERROR ***** [V8.2.0] #0 Sql->query called at [/var/www/....../htdocs/model/persistence/SqlElement.php:3113]
2019-09-23 10:11:27.069 ***** ERROR ***** [V8.2.0] #1 SqlElement->getDependantSqlElements called at [/var/www/....../htdocs/model/persistence/SqlElement.php:2984]
2019-09-23 10:11:27.069 ***** ERROR ***** [V8.2.0] #2 SqlElement->getSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:672]
2019-09-23 10:11:27.069 ***** ERROR ***** [V8.2.0] #3 SqlElement->__construct called at [/var/www/....../htdocs/model/TenderMain.php:151]
2019-09-23 10:11:27.070 ***** ERROR ***** [V8.2.0] #4 TenderMain->__construct called at [/var/www/....../htdocs/model/Tender.php:39]
2019-09-23 10:11:27.070 ***** ERROR ***** [V8.2.0] #5 Tender->__construct called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1330]
2019-09-23 10:11:27.070 ***** ERROR ***** [V8.2.0] #6 SqlElement->getCurrentObject called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1430]
2019-09-23 10:11:27.070 ***** ERROR ***** [V8.2.0] #7 SqlElement->updateSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1064]
2019-09-23 10:11:27.071 ***** ERROR ***** [V8.2.0] #8 SqlElement->saveSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:876]
2019-09-23 10:11:27.071 ***** ERROR ***** [V8.2.0] #9 SqlElement->saveForced called at [/var/www/....../htdocs/model/persistence/SqlElement.php:887]
2019-09-23 10:11:27.071 ***** ERROR ***** [V8.2.0] #10 SqlElement->simpleSave called at [/var/www/....../htdocs/model/TenderMain.php:389]
2019-09-23 10:11:27.072 ***** ERROR ***** [V8.2.0] #11 TenderMain->save called at [/var/www/....../htdocs/tool/saveObject.php:78]
2019-09-23 10:11:27.072 ***** ERROR ***** [V8.2.0] Exception-[25P02] SQLSTATE[25P02]: In failed sql transaction: 7 ERROR: current transaction is aborted, commands ignored until end of transaction block
2019-09-23 10:11:27.073 ***** ERROR ***** [V8.2.0] For query : select id from note where refId ='2' and refType ='Tender' order by id desc
2019-09-23 10:11:27.073 ***** ERROR ***** [V8.2.0] Strack trace :
2019-09-23 10:11:27.073 ***** ERROR ***** [V8.2.0] #0 Sql->query called at [/var/www/....../htdocs/model/persistence/SqlElement.php:3113]
2019-09-23 10:11:27.074 ***** ERROR ***** [V8.2.0] #1 SqlElement->getDependantSqlElements called at [/var/www/....../htdocs/model/persistence/SqlElement.php:2984]
2019-09-23 10:11:27.074 ***** ERROR ***** [V8.2.0] #2 SqlElement->getSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:672]
2019-09-23 10:11:27.074 ***** ERROR ***** [V8.2.0] #3 SqlElement->__construct called at [/var/www/....../htdocs/model/TenderMain.php:151]
2019-09-23 10:11:27.075 ***** ERROR ***** [V8.2.0] #4 TenderMain->__construct called at [/var/www/....../htdocs/model/Tender.php:39]
2019-09-23 10:11:27.075 ***** ERROR ***** [V8.2.0] #5 Tender->__construct called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1330]
2019-09-23 10:11:27.075 ***** ERROR ***** [V8.2.0] #6 SqlElement->getCurrentObject called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1430]
2019-09-23 10:11:27.076 ***** ERROR ***** [V8.2.0] #7 SqlElement->updateSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1064]
2019-09-23 10:11:27.076 ***** ERROR ***** [V8.2.0] #8 SqlElement->saveSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:876]
2019-09-23 10:11:27.076 ***** ERROR ***** [V8.2.0] #9 SqlElement->saveForced called at [/var/www/....../htdocs/model/persistence/SqlElement.php:887]
2019-09-23 10:11:27.077 ***** ERROR ***** [V8.2.0] #10 SqlElement->simpleSave called at [/var/www/....../htdocs/model/TenderMain.php:389]
2019-09-23 10:11:27.077 ***** ERROR ***** [V8.2.0] #11 TenderMain->save called at [/var/www/....../htdocs/tool/saveObject.php:78]
2019-09-23 10:11:27.079 ***** ERROR ***** [V8.2.0] Exception-[25P02] SQLSTATE[25P02]: In failed sql transaction: 7 ERROR: current transaction is aborted, commands ignored until end of transaction block
2019-09-23 10:11:27.079 ***** ERROR ***** [V8.2.0] For query : insert into history ( refType , refId , operation , colName , newValue , operationDate , idUser , isWorkHistory ) values ('Tender', '2', 'update', 'reference', '--0002', '2019-09-23 10:11:26', '3', '0')
2019-09-23 10:11:27.080 ***** ERROR ***** [V8.2.0] Strack trace :
2019-09-23 10:11:27.080 ***** ERROR ***** [V8.2.0] #0 Sql->query called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1276]
2019-09-23 10:11:27.080 ***** ERROR ***** [V8.2.0] #1 SqlElement->insertSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1070]
2019-09-23 10:11:27.081 ***** ERROR ***** [V8.2.0] #2 SqlElement->saveSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:733]
2019-09-23 10:11:27.081 ***** ERROR ***** [V8.2.0] #3 SqlElement->save called at [/var/www/....../htdocs/model/History.php:116]
2019-09-23 10:11:27.081 ***** ERROR ***** [V8.2.0] #4 History->store called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1553]
2019-09-23 10:11:27.082 ***** ERROR ***** [V8.2.0] #5 SqlElement->updateSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1064]
2019-09-23 10:11:27.082 ***** ERROR ***** [V8.2.0] #6 SqlElement->saveSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:876]
2019-09-23 10:11:27.082 ***** ERROR ***** [V8.2.0] #7 SqlElement->saveForced called at [/var/www/....../htdocs/model/persistence/SqlElement.php:887]
2019-09-23 10:11:27.083 ***** ERROR ***** [V8.2.0] #8 SqlElement->simpleSave called at [/var/www/....../htdocs/model/TenderMain.php:389]
2019-09-23 10:11:27.083 ***** ERROR ***** [V8.2.0] #9 TenderMain->save called at [/var/www/....../htdocs/tool/saveObject.php:78]
2019-09-23 10:11:27.085 ***** ERROR ***** [V8.2.0] Exception-[25P02] SQLSTATE[25P02]: In failed sql transaction: 7 ERROR: current transaction is aborted, commands ignored until end of transaction block
2019-09-23 10:11:27.086 ***** ERROR ***** [V8.2.0] For query : insert into history ( refType , refId , operation , colName , newValue , operationDate , idUser , isWorkHistory ) values ('Tender', '2', 'update', 'name', 'DEP.AC/190 010 - Software Management Solutions', '2019-09-23 10:11:26', '3', '0')
2019-09-23 10:11:27.086 ***** ERROR ***** [V8.2.0] Strack trace :
2019-09-23 10:11:27.086 ***** ERROR ***** [V8.2.0] #0 Sql->query called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1276]
2019-09-23 10:11:27.087 ***** ERROR ***** [V8.2.0] #1 SqlElement->insertSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1070]
2019-09-23 10:11:27.087 ***** ERROR ***** [V8.2.0] #2 SqlElement->saveSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:733]
2019-09-23 10:11:27.087 ***** ERROR ***** [V8.2.0] #3 SqlElement->save called at [/var/www/....../htdocs/model/History.php:116]
2019-09-23 10:11:27.087 ***** ERROR ***** [V8.2.0] #4 History->store called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1553]
2019-09-23 10:11:27.088 ***** ERROR ***** [V8.2.0] #5 SqlElement->updateSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1064]
2019-09-23 10:11:27.088 ***** ERROR ***** [V8.2.0] #6 SqlElement->saveSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:876]
2019-09-23 10:11:27.088 ***** ERROR ***** [V8.2.0] #7 SqlElement->saveForced called at [/var/www/....../htdocs/model/persistence/SqlElement.php:887]
2019-09-23 10:11:27.089 ***** ERROR ***** [V8.2.0] #8 SqlElement->simpleSave called at [/var/www/....../htdocs/model/TenderMain.php:389]
2019-09-23 10:11:27.089 ***** ERROR ***** [V8.2.0] #9 TenderMain->save called at [/var/www/....../htdocs/tool/saveObject.php:78]
2019-09-23 10:11:27.091 ***** ERROR ***** [V8.2.0] Exception-[25P02] SQLSTATE[25P02]: In failed sql transaction: 7 ERROR: current transaction is aborted, commands ignored until end of transaction block
2019-09-23 10:11:27.092 ***** ERROR ***** [V8.2.0] For query : insert into history ( refType , refId , operation , colName , newValue , operationDate , idUser , isWorkHistory ) values ('Tender', '2', 'update', 'idTenderType', '114', '2019-09-23 10:11:26', '3', '0')
2019-09-23 10:11:27.092 ***** ERROR ***** [V8.2.0] Strack trace :
2019-09-23 10:11:27.092 ***** ERROR ***** [V8.2.0] #0 Sql->query called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1276]
2019-09-23 10:11:27.093 ***** ERROR ***** [V8.2.0] #1 SqlElement->insertSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1070]
2019-09-23 10:11:27.093 ***** ERROR ***** [V8.2.0] #2 SqlElement->saveSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:733]
2019-09-23 10:11:27.093 ***** ERROR ***** [V8.2.0] #3 SqlElement->save called at [/var/www/....../htdocs/model/History.php:116]
2019-09-23 10:11:27.094 ***** ERROR ***** [V8.2.0] #4 History->store called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1553]
2019-09-23 10:11:27.094 ***** ERROR ***** [V8.2.0] #5 SqlElement->updateSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1064]
2019-09-23 10:11:27.094 ***** ERROR ***** [V8.2.0] #6 SqlElement->saveSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:876]
2019-09-23 10:11:27.095 ***** ERROR ***** [V8.2.0] #7 SqlElement->saveForced called at [/var/www/....../htdocs/model/persistence/SqlElement.php:887]
2019-09-23 10:11:27.095 ***** ERROR ***** [V8.2.0] #8 SqlElement->simpleSave called at [/var/www/....../htdocs/model/TenderMain.php:389]
2019-09-23 10:11:27.095 ***** ERROR ***** [V8.2.0] #9 TenderMain->save called at [/var/www/....../htdocs/tool/saveObject.php:78]
2019-09-23 10:11:27.097 ***** ERROR ***** [V8.2.0] Exception-[25P02] SQLSTATE[25P02]: In failed sql transaction: 7 ERROR: current transaction is aborted, commands ignored until end of transaction block
2019-09-23 10:11:27.098 ***** ERROR ***** [V8.2.0] For query : insert into history ( refType , refId , operation , colName , newValue , operationDate , idUser , isWorkHistory ) values ('Tender', '2', 'update', 'idProject', '14', '2019-09-23 10:11:26', '3', '0')
2019-09-23 10:11:27.098 ***** ERROR ***** [V8.2.0] Strack trace :
2019-09-23 10:11:27.098 ***** ERROR ***** [V8.2.0] #0 Sql->query called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1276]
2019-09-23 10:11:27.099 ***** ERROR ***** [V8.2.0] #1 SqlElement->insertSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1070]
2019-09-23 10:11:27.099 ***** ERROR ***** [V8.2.0] #2 SqlElement->saveSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:733]
2019-09-23 10:11:27.099 ***** ERROR ***** [V8.2.0] #3 SqlElement->save called at [/var/www/....../htdocs/model/History.php:116]
2019-09-23 10:11:27.100 ***** ERROR ***** [V8.2.0] #4 History->store called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1553]
2019-09-23 10:11:27.100 ***** ERROR ***** [V8.2.0] #5 SqlElement->updateSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1064]
2019-09-23 10:11:27.100 ***** ERROR ***** [V8.2.0] #6 SqlElement->saveSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:876]
2019-09-23 10:11:27.100 ***** ERROR ***** [V8.2.0] #7 SqlElement->saveForced called at [/var/www/....../htdocs/model/persistence/SqlElement.php:887]
2019-09-23 10:11:27.101 ***** ERROR ***** [V8.2.0] #8 SqlElement->simpleSave called at [/var/www/....../htdocs/model/TenderMain.php:389]
2019-09-23 10:11:27.101 ***** ERROR ***** [V8.2.0] #9 TenderMain->save called at [/var/www/....../htdocs/tool/saveObject.php:78]
2019-09-23 10:11:27.103 ***** ERROR ***** [V8.2.0] Exception-[25P02] SQLSTATE[25P02]: In failed sql transaction: 7 ERROR: current transaction is aborted, commands ignored until end of transaction block
2019-09-23 10:11:27.103 ***** ERROR ***** [V8.2.0] For query : insert into history ( refType , refId , operation , colName , newValue , operationDate , idUser , isWorkHistory ) values ('Tender', '2', 'update', 'idCallForTender', '1', '2019-09-23 10:11:26', '3', '0')
2019-09-23 10:11:27.104 ***** ERROR ***** [V8.2.0] Strack trace :
2019-09-23 10:11:27.104 ***** ERROR ***** [V8.2.0] #0 Sql->query called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1276]
2019-09-23 10:11:27.104 ***** ERROR ***** [V8.2.0] #1 SqlElement->insertSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1070]
2019-09-23 10:11:27.105 ***** ERROR ***** [V8.2.0] #2 SqlElement->saveSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:733]
2019-09-23 10:11:27.105 ***** ERROR ***** [V8.2.0] #3 SqlElement->save called at [/var/www/....../htdocs/model/History.php:116]
2019-09-23 10:11:27.105 ***** ERROR ***** [V8.2.0] #4 History->store called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1553]
2019-09-23 10:11:27.106 ***** ERROR ***** [V8.2.0] #5 SqlElement->updateSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1064]
2019-09-23 10:11:27.106 ***** ERROR ***** [V8.2.0] #6 SqlElement->saveSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:876]
2019-09-23 10:11:27.106 ***** ERROR ***** [V8.2.0] #7 SqlElement->saveForced called at [/var/www/....../htdocs/model/persistence/SqlElement.php:887]
2019-09-23 10:11:27.107 ***** ERROR ***** [V8.2.0] #8 SqlElement->simpleSave called at [/var/www/....../htdocs/model/TenderMain.php:389]
2019-09-23 10:11:27.107 ***** ERROR ***** [V8.2.0] #9 TenderMain->save called at [/var/www/....../htdocs/tool/saveObject.php:78]
2019-09-23 10:11:27.109 ***** ERROR ***** [V8.2.0] Exception-[25P02] SQLSTATE[25P02]: In failed sql transaction: 7 ERROR: current transaction is aborted, commands ignored until end of transaction block
2019-09-23 10:11:27.109 ***** ERROR ***** [V8.2.0] For query : insert into history ( refType , refId , operation , colName , newValue , operationDate , idUser , isWorkHistory ) values ('Tender', '2', 'update', 'idTenderStatus', '5', '2019-09-23 10:11:26', '3', '0')
2019-09-23 10:11:27.110 ***** ERROR ***** [V8.2.0] Strack trace :
2019-09-23 10:11:27.110 ***** ERROR ***** [V8.2.0] #0 Sql->query called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1276]
2019-09-23 10:11:27.110 ***** ERROR ***** [V8.2.0] #1 SqlElement->insertSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1070]
2019-09-23 10:11:27.111 ***** ERROR ***** [V8.2.0] #2 SqlElement->saveSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:733]
2019-09-23 10:11:27.111 ***** ERROR ***** [V8.2.0] #3 SqlElement->save called at [/var/www/....../htdocs/model/History.php:116]
2019-09-23 10:11:27.111 ***** ERROR ***** [V8.2.0] #4 History->store called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1553]
2019-09-23 10:11:27.112 ***** ERROR ***** [V8.2.0] #5 SqlElement->updateSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1064]
2019-09-23 10:11:27.112 ***** ERROR ***** [V8.2.0] #6 SqlElement->saveSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:876]
2019-09-23 10:11:27.112 ***** ERROR ***** [V8.2.0] #7 SqlElement->saveForced called at [/var/www/....../htdocs/model/persistence/SqlElement.php:887]
2019-09-23 10:11:27.113 ***** ERROR ***** [V8.2.0] #8 SqlElement->simpleSave called at [/var/www/....../htdocs/model/TenderMain.php:389]
2019-09-23 10:11:27.113 ***** ERROR ***** [V8.2.0] #9 TenderMain->save called at [/var/www/....../htdocs/tool/saveObject.php:78]
2019-09-23 10:11:27.115 ***** ERROR ***** [V8.2.0] Exception-[25P02] SQLSTATE[25P02]: In failed sql transaction: 7 ERROR: current transaction is aborted, commands ignored until end of transaction block
2019-09-23 10:11:27.115 ***** ERROR ***** [V8.2.0] For query : insert into history ( refType , refId , operation , colName , newValue , operationDate , idUser , isWorkHistory ) values ('Tender', '2', 'update', 'idUser', '3', '2019-09-23 10:11:26', '3', '0')
2019-09-23 10:11:27.116 ***** ERROR ***** [V8.2.0] Strack trace :
2019-09-23 10:11:27.116 ***** ERROR ***** [V8.2.0] #0 Sql->query called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1276]
2019-09-23 10:11:27.116 ***** ERROR ***** [V8.2.0] #1 SqlElement->insertSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1070]
2019-09-23 10:11:27.117 ***** ERROR ***** [V8.2.0] #2 SqlElement->saveSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:733]
2019-09-23 10:11:27.117 ***** ERROR ***** [V8.2.0] #3 SqlElement->save called at [/var/www/....../htdocs/model/History.php:116]
2019-09-23 10:11:27.118 ***** ERROR ***** [V8.2.0] #4 History->store called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1553]
2019-09-23 10:11:27.118 ***** ERROR ***** [V8.2.0] #5 SqlElement->updateSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1064]
2019-09-23 10:11:27.118 ***** ERROR ***** [V8.2.0] #6 SqlElement->saveSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:876]
2019-09-23 10:11:27.119 ***** ERROR ***** [V8.2.0] #7 SqlElement->saveForced called at [/var/www/....../htdocs/model/persistence/SqlElement.php:887]
2019-09-23 10:11:27.119 ***** ERROR ***** [V8.2.0] #8 SqlElement->simpleSave called at [/var/www/....../htdocs/model/TenderMain.php:389]
2019-09-23 10:11:27.119 ***** ERROR ***** [V8.2.0] #9 TenderMain->save called at [/var/www/....../htdocs/tool/saveObject.php:78]
2019-09-23 10:11:27.121 ***** ERROR ***** [V8.2.0] Exception-[25P02] SQLSTATE[25P02]: In failed sql transaction: 7 ERROR: current transaction is aborted, commands ignored until end of transaction block
2019-09-23 10:11:27.121 ***** ERROR ***** [V8.2.0] For query : insert into history ( refType , refId , operation , colName , newValue , operationDate , idUser , isWorkHistory ) values ('Tender', '2', 'update', 'creationDate', '2019-09-23', '2019-09-23 10:11:26', '3', '0')
2019-09-23 10:11:27.122 ***** ERROR ***** [V8.2.0] Strack trace :
2019-09-23 10:11:27.122 ***** ERROR ***** [V8.2.0] #0 Sql->query called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1276]
2019-09-23 10:11:27.122 ***** ERROR ***** [V8.2.0] #1 SqlElement->insertSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1070]
2019-09-23 10:11:27.123 ***** ERROR ***** [V8.2.0] #2 SqlElement->saveSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:733]
2019-09-23 10:11:27.123 ***** ERROR ***** [V8.2.0] #3 SqlElement->save called at [/var/www/....../htdocs/model/History.php:116]
2019-09-23 10:11:27.123 ***** ERROR ***** [V8.2.0] #4 History->store called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1553]
2019-09-23 10:11:27.124 ***** ERROR ***** [V8.2.0] #5 SqlElement->updateSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1064]
2019-09-23 10:11:27.124 ***** ERROR ***** [V8.2.0] #6 SqlElement->saveSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:876]
2019-09-23 10:11:27.124 ***** ERROR ***** [V8.2.0] #7 SqlElement->saveForced called at [/var/www/....../htdocs/model/persistence/SqlElement.php:887]
2019-09-23 10:11:27.125 ***** ERROR ***** [V8.2.0] #8 SqlElement->simpleSave called at [/var/www/....../htdocs/model/TenderMain.php:389]
2019-09-23 10:11:27.125 ***** ERROR ***** [V8.2.0] #9 TenderMain->save called at [/var/www/....../htdocs/tool/saveObject.php:78]
2019-09-23 10:11:27.127 ***** ERROR ***** [V8.2.0] Exception-[25P02] SQLSTATE[25P02]: In failed sql transaction: 7 ERROR: current transaction is aborted, commands ignored until end of transaction block
2019-09-23 10:11:27.127 ***** ERROR ***** [V8.2.0] For query : insert into history ( refType , refId , operation , colName , newValue , operationDate , idUser , isWorkHistory ) values ('Tender', '2', 'update', 'idProvider', '4', '2019-09-23 10:11:26', '3', '0')
2019-09-23 10:11:27.128 ***** ERROR ***** [V8.2.0] Strack trace :
2019-09-23 10:11:27.128 ***** ERROR ***** [V8.2.0] #0 Sql->query called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1276]
2019-09-23 10:11:27.128 ***** ERROR ***** [V8.2.0] #1 SqlElement->insertSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1070]
2019-09-23 10:11:27.129 ***** ERROR ***** [V8.2.0] #2 SqlElement->saveSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:733]
2019-09-23 10:11:27.129 ***** ERROR ***** [V8.2.0] #3 SqlElement->save called at [/var/www/....../htdocs/model/History.php:116]
2019-09-23 10:11:27.129 ***** ERROR ***** [V8.2.0] #4 History->store called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1553]
2019-09-23 10:11:27.129 ***** ERROR ***** [V8.2.0] #5 SqlElement->updateSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1064]
2019-09-23 10:11:27.130 ***** ERROR ***** [V8.2.0] #6 SqlElement->saveSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:876]
2019-09-23 10:11:27.130 ***** ERROR ***** [V8.2.0] #7 SqlElement->saveForced called at [/var/www/....../htdocs/model/persistence/SqlElement.php:887]
2019-09-23 10:11:27.130 ***** ERROR ***** [V8.2.0] #8 SqlElement->simpleSave called at [/var/www/....../htdocs/model/TenderMain.php:389]
2019-09-23 10:11:27.131 ***** ERROR ***** [V8.2.0] #9 TenderMain->save called at [/var/www/....../htdocs/tool/saveObject.php:78]
2019-09-23 10:11:27.133 ***** ERROR ***** [V8.2.0] Exception-[25P02] SQLSTATE[25P02]: In failed sql transaction: 7 ERROR: current transaction is aborted, commands ignored until end of transaction block
2019-09-23 10:11:27.133 ***** ERROR ***** [V8.2.0] For query : insert into history ( refType , refId , operation , colName , newValue , operationDate , idUser , isWorkHistory ) values ('Tender', '2', 'update', 'idStatus', '1', '2019-09-23 10:11:26', '3', '0')
2019-09-23 10:11:27.133 ***** ERROR ***** [V8.2.0] Strack trace :
2019-09-23 10:11:27.133 ***** ERROR ***** [V8.2.0] #0 Sql->query called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1276]
2019-09-23 10:11:27.134 ***** ERROR ***** [V8.2.0] #1 SqlElement->insertSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1070]
2019-09-23 10:11:27.134 ***** ERROR ***** [V8.2.0] #2 SqlElement->saveSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:733]
2019-09-23 10:11:27.134 ***** ERROR ***** [V8.2.0] #3 SqlElement->save called at [/var/www/....../htdocs/model/History.php:116]
2019-09-23 10:11:27.135 ***** ERROR ***** [V8.2.0] #4 History->store called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1553]
2019-09-23 10:11:27.135 ***** ERROR ***** [V8.2.0] #5 SqlElement->updateSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1064]
2019-09-23 10:11:27.135 ***** ERROR ***** [V8.2.0] #6 SqlElement->saveSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:876]
2019-09-23 10:11:27.136 ***** ERROR ***** [V8.2.0] #7 SqlElement->saveForced called at [/var/www/....../htdocs/model/persistence/SqlElement.php:887]
2019-09-23 10:11:27.136 ***** ERROR ***** [V8.2.0] #8 SqlElement->simpleSave called at [/var/www/....../htdocs/model/TenderMain.php:389]
2019-09-23 10:11:27.136 ***** ERROR ***** [V8.2.0] #9 TenderMain->save called at [/var/www/....../htdocs/tool/saveObject.php:78]
2019-09-23 10:11:27.138 ***** ERROR ***** [V8.2.0] Exception-[25P02] SQLSTATE[25P02]: In failed sql transaction: 7 ERROR: current transaction is aborted, commands ignored until end of transaction block
2019-09-23 10:11:27.138 ***** ERROR ***** [V8.2.0] For query : insert into history ( refType , refId , operation , colName , newValue , operationDate , idUser , isWorkHistory ) values ('Tender', '2', 'update', 'idResource', '15', '2019-09-23 10:11:26', '3', '0')
2019-09-23 10:11:27.139 ***** ERROR ***** [V8.2.0] Strack trace :
2019-09-23 10:11:27.139 ***** ERROR ***** [V8.2.0] #0 Sql->query called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1276]
2019-09-23 10:11:27.139 ***** ERROR ***** [V8.2.0] #1 SqlElement->insertSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1070]
2019-09-23 10:11:27.140 ***** ERROR ***** [V8.2.0] #2 SqlElement->saveSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:733]
2019-09-23 10:11:27.140 ***** ERROR ***** [V8.2.0] #3 SqlElement->save called at [/var/www/....../htdocs/model/History.php:116]
2019-09-23 10:11:27.140 ***** ERROR ***** [V8.2.0] #4 History->store called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1553]
2019-09-23 10:11:27.141 ***** ERROR ***** [V8.2.0] #5 SqlElement->updateSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1064]
2019-09-23 10:11:27.141 ***** ERROR ***** [V8.2.0] #6 SqlElement->saveSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:876]
2019-09-23 10:11:27.142 ***** ERROR ***** [V8.2.0] #7 SqlElement->saveForced called at [/var/www/....../htdocs/model/persistence/SqlElement.php:887]
2019-09-23 10:11:27.142 ***** ERROR ***** [V8.2.0] #8 SqlElement->simpleSave called at [/var/www/....../htdocs/model/TenderMain.php:389]
2019-09-23 10:11:27.143 ***** ERROR ***** [V8.2.0] #9 TenderMain->save called at [/var/www/....../htdocs/tool/saveObject.php:78]
2019-09-23 10:11:27.146 ***** ERROR ***** [V8.2.0] Exception-[25P02] SQLSTATE[25P02]: In failed sql transaction: 7 ERROR: current transaction is aborted, commands ignored until end of transaction block
2019-09-23 10:11:27.146 ***** ERROR ***** [V8.2.0] For query : insert into history ( refType , refId , operation , colName , newValue , operationDate , idUser , isWorkHistory ) values ('Tender', '2', 'update', 'expectedTenderDateTime', '2019-09-17 10:00:00', '2019-09-23 10:11:26', '3', '0')
2019-09-23 10:11:27.147 ***** ERROR ***** [V8.2.0] Strack trace :
2019-09-23 10:11:27.147 ***** ERROR ***** [V8.2.0] #0 Sql->query called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1276]
2019-09-23 10:11:27.148 ***** ERROR ***** [V8.2.0] #1 SqlElement->insertSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1070]
2019-09-23 10:11:27.148 ***** ERROR ***** [V8.2.0] #2 SqlElement->saveSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:733]
2019-09-23 10:11:27.149 ***** ERROR ***** [V8.2.0] #3 SqlElement->save called at [/var/www/....../htdocs/model/History.php:116]
2019-09-23 10:11:27.149 ***** ERROR ***** [V8.2.0] #4 History->store called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1553]
2019-09-23 10:11:27.150 ***** ERROR ***** [V8.2.0] #5 SqlElement->updateSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1064]
2019-09-23 10:11:27.150 ***** ERROR ***** [V8.2.0] #6 SqlElement->saveSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:876]
2019-09-23 10:11:27.151 ***** ERROR ***** [V8.2.0] #7 SqlElement->saveForced called at [/var/www/....../htdocs/model/persistence/SqlElement.php:887]
2019-09-23 10:11:27.151 ***** ERROR ***** [V8.2.0] #8 SqlElement->simpleSave called at [/var/www/....../htdocs/model/TenderMain.php:389]
2019-09-23 10:11:27.152 ***** ERROR ***** [V8.2.0] #9 TenderMain->save called at [/var/www/....../htdocs/tool/saveObject.php:78]
2019-09-23 10:11:27.155 ***** ERROR ***** [V8.2.0] Exception-[25P02] SQLSTATE[25P02]: In failed sql transaction: 7 ERROR: current transaction is aborted, commands ignored until end of transaction block
2019-09-23 10:11:27.155 ***** ERROR ***** [V8.2.0] For query : insert into history ( refType , refId , operation , colName , newValue , operationDate , idUser , isWorkHistory ) values ('Tender', '2', 'update', 'receptionDateTime', '2019-09-17 10:00:00', '2019-09-23 10:11:26', '3', '0')
2019-09-23 10:11:27.155 ***** ERROR ***** [V8.2.0] Strack trace :
2019-09-23 10:11:27.156 ***** ERROR ***** [V8.2.0] #0 Sql->query called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1276]
2019-09-23 10:11:27.156 ***** ERROR ***** [V8.2.0] #1 SqlElement->insertSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1070]
2019-09-23 10:11:27.156 ***** ERROR ***** [V8.2.0] #2 SqlElement->saveSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:733]
2019-09-23 10:11:27.157 ***** ERROR ***** [V8.2.0] #3 SqlElement->save called at [/var/www/....../htdocs/model/History.php:116]
2019-09-23 10:11:27.157 ***** ERROR ***** [V8.2.0] #4 History->store called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1553]
2019-09-23 10:11:27.157 ***** ERROR ***** [V8.2.0] #5 SqlElement->updateSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1064]
2019-09-23 10:11:27.157 ***** ERROR ***** [V8.2.0] #6 SqlElement->saveSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:876]
2019-09-23 10:11:27.158 ***** ERROR ***** [V8.2.0] #7 SqlElement->saveForced called at [/var/www/....../htdocs/model/persistence/SqlElement.php:887]
2019-09-23 10:11:27.158 ***** ERROR ***** [V8.2.0] #8 SqlElement->simpleSave called at [/var/www/....../htdocs/model/TenderMain.php:389]
2019-09-23 10:11:27.158 ***** ERROR ***** [V8.2.0] #9 TenderMain->save called at [/var/www/....../htdocs/tool/saveObject.php:78]
2019-09-23 10:11:27.160 ***** ERROR ***** [V8.2.0] Exception-[25P02] SQLSTATE[25P02]: In failed sql transaction: 7 ERROR: current transaction is aborted, commands ignored until end of transaction block
2019-09-23 10:11:27.161 ***** ERROR ***** [V8.2.0] For query : insert into history ( refType , refId , operation , colName , newValue , operationDate , idUser , isWorkHistory ) values ('Tender', '2', 'update', 'offerValidityEndDate', '2020-01-25', '2019-09-23 10:11:26', '3', '0')
2019-09-23 10:11:27.161 ***** ERROR ***** [V8.2.0] Strack trace :
2019-09-23 10:11:27.161 ***** ERROR ***** [V8.2.0] #0 Sql->query called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1276]
2019-09-23 10:11:27.162 ***** ERROR ***** [V8.2.0] #1 SqlElement->insertSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1070]
2019-09-23 10:11:27.162 ***** ERROR ***** [V8.2.0] #2 SqlElement->saveSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:733]
2019-09-23 10:11:27.162 ***** ERROR ***** [V8.2.0] #3 SqlElement->save called at [/var/www/....../htdocs/model/History.php:116]
2019-09-23 10:11:27.162 ***** ERROR ***** [V8.2.0] #4 History->store called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1553]
2019-09-23 10:11:27.163 ***** ERROR ***** [V8.2.0] #5 SqlElement->updateSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1064]
2019-09-23 10:11:27.163 ***** ERROR ***** [V8.2.0] #6 SqlElement->saveSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:876]
2019-09-23 10:11:27.163 ***** ERROR ***** [V8.2.0] #7 SqlElement->saveForced called at [/var/www/....../htdocs/model/persistence/SqlElement.php:887]
2019-09-23 10:11:27.164 ***** ERROR ***** [V8.2.0] #8 SqlElement->simpleSave called at [/var/www/....../htdocs/model/TenderMain.php:389]
2019-09-23 10:11:27.164 ***** ERROR ***** [V8.2.0] #9 TenderMain->save called at [/var/www/....../htdocs/tool/saveObject.php:78]
2019-09-23 10:11:27.166 ***** ERROR ***** [V8.2.0] Exception-[25P02] SQLSTATE[25P02]: In failed sql transaction: 7 ERROR: current transaction is aborted, commands ignored until end of transaction block
2019-09-23 10:11:27.166 ***** ERROR ***** [V8.2.0] For query : insert into history ( refType , refId , operation , colName , newValue , operationDate , idUser , isWorkHistory ) values ('Tender', '2', 'update', 'untaxedAmount', '135384.98', '2019-09-23 10:11:26', '3', '0')
2019-09-23 10:11:27.166 ***** ERROR ***** [V8.2.0] Strack trace :
2019-09-23 10:11:27.167 ***** ERROR ***** [V8.2.0] #0 Sql->query called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1276]
2019-09-23 10:11:27.167 ***** ERROR ***** [V8.2.0] #1 SqlElement->insertSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1070]
2019-09-23 10:11:27.167 ***** ERROR ***** [V8.2.0] #2 SqlElement->saveSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:733]
2019-09-23 10:11:27.168 ***** ERROR ***** [V8.2.0] #3 SqlElement->save called at [/var/www/....../htdocs/model/History.php:116]
2019-09-23 10:11:27.168 ***** ERROR ***** [V8.2.0] #4 History->store called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1553]
2019-09-23 10:11:27.168 ***** ERROR ***** [V8.2.0] #5 SqlElement->updateSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1064]
2019-09-23 10:11:27.169 ***** ERROR ***** [V8.2.0] #6 SqlElement->saveSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:876]
2019-09-23 10:11:27.169 ***** ERROR ***** [V8.2.0] #7 SqlElement->saveForced called at [/var/www/....../htdocs/model/persistence/SqlElement.php:887]
2019-09-23 10:11:27.169 ***** ERROR ***** [V8.2.0] #8 SqlElement->simpleSave called at [/var/www/....../htdocs/model/TenderMain.php:389]
2019-09-23 10:11:27.170 ***** ERROR ***** [V8.2.0] #9 TenderMain->save called at [/var/www/....../htdocs/tool/saveObject.php:78]
2019-09-23 10:11:27.171 ***** ERROR ***** [V8.2.0] Exception-[25P02] SQLSTATE[25P02]: In failed sql transaction: 7 ERROR: current transaction is aborted, commands ignored until end of transaction block
2019-09-23 10:11:27.172 ***** ERROR ***** [V8.2.0] For query : insert into history ( refType , refId , operation , colName , newValue , operationDate , idUser , isWorkHistory ) values ('Tender', '2', 'update', 'taxPct', '19', '2019-09-23 10:11:26', '3', '0')
2019-09-23 10:11:27.172 ***** ERROR ***** [V8.2.0] Strack trace :
2019-09-23 10:11:27.172 ***** ERROR ***** [V8.2.0] #0 Sql->query called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1276]
2019-09-23 10:11:27.173 ***** ERROR ***** [V8.2.0] #1 SqlElement->insertSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1070]
2019-09-23 10:11:27.173 ***** ERROR ***** [V8.2.0] #2 SqlElement->saveSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:733]
2019-09-23 10:11:27.173 ***** ERROR ***** [V8.2.0] #3 SqlElement->save called at [/var/www/....../htdocs/model/History.php:116]
2019-09-23 10:11:27.173 ***** ERROR ***** [V8.2.0] #4 History->store called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1553]
2019-09-23 10:11:27.174 ***** ERROR ***** [V8.2.0] #5 SqlElement->updateSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1064]
2019-09-23 10:11:27.174 ***** ERROR ***** [V8.2.0] #6 SqlElement->saveSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:876]
2019-09-23 10:11:27.174 ***** ERROR ***** [V8.2.0] #7 SqlElement->saveForced called at [/var/www/....../htdocs/model/persistence/SqlElement.php:887]
2019-09-23 10:11:27.175 ***** ERROR ***** [V8.2.0] #8 SqlElement->simpleSave called at [/var/www/....../htdocs/model/TenderMain.php:389]
2019-09-23 10:11:27.175 ***** ERROR ***** [V8.2.0] #9 TenderMain->save called at [/var/www/....../htdocs/tool/saveObject.php:78]
2019-09-23 10:11:27.177 ***** ERROR ***** [V8.2.0] Exception-[25P02] SQLSTATE[25P02]: In failed sql transaction: 7 ERROR: current transaction is aborted, commands ignored until end of transaction block
2019-09-23 10:11:27.177 ***** ERROR ***** [V8.2.0] For query : insert into history ( refType , refId , operation , colName , newValue , operationDate , idUser , isWorkHistory ) values ('Tender', '2', 'update', 'taxAmount', '25723.15', '2019-09-23 10:11:26', '3', '0')
2019-09-23 10:11:27.178 ***** ERROR ***** [V8.2.0] Strack trace :
2019-09-23 10:11:27.178 ***** ERROR ***** [V8.2.0] #0 Sql->query called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1276]
2019-09-23 10:11:27.178 ***** ERROR ***** [V8.2.0] #1 SqlElement->insertSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1070]
2019-09-23 10:11:27.178 ***** ERROR ***** [V8.2.0] #2 SqlElement->saveSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:733]
2019-09-23 10:11:27.179 ***** ERROR ***** [V8.2.0] #3 SqlElement->save called at [/var/www/....../htdocs/model/History.php:116]
2019-09-23 10:11:27.179 ***** ERROR ***** [V8.2.0] #4 History->store called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1553]
2019-09-23 10:11:27.179 ***** ERROR ***** [V8.2.0] #5 SqlElement->updateSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1064]
2019-09-23 10:11:27.180 ***** ERROR ***** [V8.2.0] #6 SqlElement->saveSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:876]
2019-09-23 10:11:27.180 ***** ERROR ***** [V8.2.0] #7 SqlElement->saveForced called at [/var/www/....../htdocs/model/persistence/SqlElement.php:887]
2019-09-23 10:11:27.180 ***** ERROR ***** [V8.2.0] #8 SqlElement->simpleSave called at [/var/www/....../htdocs/model/TenderMain.php:389]
2019-09-23 10:11:27.181 ***** ERROR ***** [V8.2.0] #9 TenderMain->save called at [/var/www/....../htdocs/tool/saveObject.php:78]
2019-09-23 10:11:27.183 ***** ERROR ***** [V8.2.0] Exception-[25P02] SQLSTATE[25P02]: In failed sql transaction: 7 ERROR: current transaction is aborted, commands ignored until end of transaction block
2019-09-23 10:11:27.183 ***** ERROR ***** [V8.2.0] For query : insert into history ( refType , refId , operation , colName , newValue , operationDate , idUser , isWorkHistory ) values ('Tender', '2', 'update', 'fullAmount', '161108.13', '2019-09-23 10:11:26', '3', '0')
2019-09-23 10:11:27.183 ***** ERROR ***** [V8.2.0] Strack trace :
2019-09-23 10:11:27.184 ***** ERROR ***** [V8.2.0] #0 Sql->query called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1276]
2019-09-23 10:11:27.184 ***** ERROR ***** [V8.2.0] #1 SqlElement->insertSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1070]
2019-09-23 10:11:27.184 ***** ERROR ***** [V8.2.0] #2 SqlElement->saveSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:733]
2019-09-23 10:11:27.185 ***** ERROR ***** [V8.2.0] #3 SqlElement->save called at [/var/www/....../htdocs/model/History.php:116]
2019-09-23 10:11:27.185 ***** ERROR ***** [V8.2.0] #4 History->store called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1553]
2019-09-23 10:11:27.185 ***** ERROR ***** [V8.2.0] #5 SqlElement->updateSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1064]
2019-09-23 10:11:27.185 ***** ERROR ***** [V8.2.0] #6 SqlElement->saveSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:876]
2019-09-23 10:11:27.186 ***** ERROR ***** [V8.2.0] #7 SqlElement->saveForced called at [/var/www/....../htdocs/model/persistence/SqlElement.php:887]
2019-09-23 10:11:27.186 ***** ERROR ***** [V8.2.0] #8 SqlElement->simpleSave called at [/var/www/....../htdocs/model/TenderMain.php:389]
2019-09-23 10:11:27.186 ***** ERROR ***** [V8.2.0] #9 TenderMain->save called at [/var/www/....../htdocs/tool/saveObject.php:78]
2019-09-23 10:11:27.188 ***** ERROR ***** [V8.2.0] Exception-[25P02] SQLSTATE[25P02]: In failed sql transaction: 7 ERROR: current transaction is aborted, commands ignored until end of transaction block
2019-09-23 10:11:27.189 ***** ERROR ***** [V8.2.0] For query : insert into history ( refType , refId , operation , colName , newValue , operationDate , idUser , isWorkHistory ) values ('Tender', '2', 'update', 'discountRate', '0', '2019-09-23 10:11:26', '3', '0')
2019-09-23 10:11:27.189 ***** ERROR ***** [V8.2.0] Strack trace :
2019-09-23 10:11:27.189 ***** ERROR ***** [V8.2.0] #0 Sql->query called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1276]
2019-09-23 10:11:27.189 ***** ERROR ***** [V8.2.0] #1 SqlElement->insertSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1070]
2019-09-23 10:11:27.190 ***** ERROR ***** [V8.2.0] #2 SqlElement->saveSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:733]
2019-09-23 10:11:27.190 ***** ERROR ***** [V8.2.0] #3 SqlElement->save called at [/var/www/....../htdocs/model/History.php:116]
2019-09-23 10:11:27.191 ***** ERROR ***** [V8.2.0] #4 History->store called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1553]
2019-09-23 10:11:27.191 ***** ERROR ***** [V8.2.0] #5 SqlElement->updateSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1064]
2019-09-23 10:11:27.191 ***** ERROR ***** [V8.2.0] #6 SqlElement->saveSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:876]
2019-09-23 10:11:27.191 ***** ERROR ***** [V8.2.0] #7 SqlElement->saveForced called at [/var/www/....../htdocs/model/persistence/SqlElement.php:887]
2019-09-23 10:11:27.192 ***** ERROR ***** [V8.2.0] #8 SqlElement->simpleSave called at [/var/www/....../htdocs/model/TenderMain.php:389]
2019-09-23 10:11:27.192 ***** ERROR ***** [V8.2.0] #9 TenderMain->save called at [/var/www/....../htdocs/tool/saveObject.php:78]
2019-09-23 10:11:27.194 ***** ERROR ***** [V8.2.0] Exception-[25P02] SQLSTATE[25P02]: In failed sql transaction: 7 ERROR: current transaction is aborted, commands ignored until end of transaction block
2019-09-23 10:11:27.194 ***** ERROR ***** [V8.2.0] For query : insert into history ( refType , refId , operation , colName , newValue , operationDate , idUser , isWorkHistory ) values ('Tender', '2', 'update', 'totalUntaxedAmount', '135384.98', '2019-09-23 10:11:26', '3', '0')
2019-09-23 10:11:27.195 ***** ERROR ***** [V8.2.0] Strack trace :
2019-09-23 10:11:27.195 ***** ERROR ***** [V8.2.0] #0 Sql->query called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1276]
2019-09-23 10:11:27.195 ***** ERROR ***** [V8.2.0] #1 SqlElement->insertSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1070]
2019-09-23 10:11:27.196 ***** ERROR ***** [V8.2.0] #2 SqlElement->saveSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:733]
2019-09-23 10:11:27.196 ***** ERROR ***** [V8.2.0] #3 SqlElement->save called at [/var/www/....../htdocs/model/History.php:116]
2019-09-23 10:11:27.196 ***** ERROR ***** [V8.2.0] #4 History->store called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1553]
2019-09-23 10:11:27.197 ***** ERROR ***** [V8.2.0] #5 SqlElement->updateSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1064]
2019-09-23 10:11:27.197 ***** ERROR ***** [V8.2.0] #6 SqlElement->saveSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:876]
2019-09-23 10:11:27.197 ***** ERROR ***** [V8.2.0] #7 SqlElement->saveForced called at [/var/www/....../htdocs/model/persistence/SqlElement.php:887]
2019-09-23 10:11:27.198 ***** ERROR ***** [V8.2.0] #8 SqlElement->simpleSave called at [/var/www/....../htdocs/model/TenderMain.php:389]
2019-09-23 10:11:27.198 ***** ERROR ***** [V8.2.0] #9 TenderMain->save called at [/var/www/....../htdocs/tool/saveObject.php:78]
2019-09-23 10:11:27.200 ***** ERROR ***** [V8.2.0] Exception-[25P02] SQLSTATE[25P02]: In failed sql transaction: 7 ERROR: current transaction is aborted, commands ignored until end of transaction block
2019-09-23 10:11:27.200 ***** ERROR ***** [V8.2.0] For query : insert into history ( refType , refId , operation , colName , newValue , operationDate , idUser , isWorkHistory ) values ('Tender', '2', 'update', 'totalTaxAmount', '25723.15', '2019-09-23 10:11:26', '3', '0')
2019-09-23 10:11:27.201 ***** ERROR ***** [V8.2.0] Strack trace :
2019-09-23 10:11:27.201 ***** ERROR ***** [V8.2.0] #0 Sql->query called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1276]
2019-09-23 10:11:27.201 ***** ERROR ***** [V8.2.0] #1 SqlElement->insertSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1070]
2019-09-23 10:11:27.202 ***** ERROR ***** [V8.2.0] #2 SqlElement->saveSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:733]
2019-09-23 10:11:27.202 ***** ERROR ***** [V8.2.0] #3 SqlElement->save called at [/var/www/....../htdocs/model/History.php:116]
2019-09-23 10:11:27.202 ***** ERROR ***** [V8.2.0] #4 History->store called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1553]
2019-09-23 10:11:27.203 ***** ERROR ***** [V8.2.0] #5 SqlElement->updateSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1064]
2019-09-23 10:11:27.203 ***** ERROR ***** [V8.2.0] #6 SqlElement->saveSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:876]
2019-09-23 10:11:27.203 ***** ERROR ***** [V8.2.0] #7 SqlElement->saveForced called at [/var/www/....../htdocs/model/persistence/SqlElement.php:887]
2019-09-23 10:11:27.203 ***** ERROR ***** [V8.2.0] #8 SqlElement->simpleSave called at [/var/www/....../htdocs/model/TenderMain.php:389]
2019-09-23 10:11:27.204 ***** ERROR ***** [V8.2.0] #9 TenderMain->save called at [/var/www/....../htdocs/tool/saveObject.php:78]
2019-09-23 10:11:27.206 ***** ERROR ***** [V8.2.0] Exception-[25P02] SQLSTATE[25P02]: In failed sql transaction: 7 ERROR: current transaction is aborted, commands ignored until end of transaction block
2019-09-23 10:11:27.206 ***** ERROR ***** [V8.2.0] For query : insert into history ( refType , refId , operation , colName , newValue , operationDate , idUser , isWorkHistory ) values ('Tender', '2', 'update', 'totalFullAmount', '161108.13', '2019-09-23 10:11:26', '3', '0')
2019-09-23 10:11:27.206 ***** ERROR ***** [V8.2.0] Strack trace :
2019-09-23 10:11:27.207 ***** ERROR ***** [V8.2.0] #0 Sql->query called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1276]
2019-09-23 10:11:27.207 ***** ERROR ***** [V8.2.0] #1 SqlElement->insertSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1070]
2019-09-23 10:11:27.207 ***** ERROR ***** [V8.2.0] #2 SqlElement->saveSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:733]
2019-09-23 10:11:27.208 ***** ERROR ***** [V8.2.0] #3 SqlElement->save called at [/var/www/....../htdocs/model/History.php:116]
2019-09-23 10:11:27.208 ***** ERROR ***** [V8.2.0] #4 History->store called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1553]
2019-09-23 10:11:27.208 ***** ERROR ***** [V8.2.0] #5 SqlElement->updateSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1064]
2019-09-23 10:11:27.209 ***** ERROR ***** [V8.2.0] #6 SqlElement->saveSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:876]
2019-09-23 10:11:27.209 ***** ERROR ***** [V8.2.0] #7 SqlElement->saveForced called at [/var/www/....../htdocs/model/persistence/SqlElement.php:887]
2019-09-23 10:11:27.209 ***** ERROR ***** [V8.2.0] #8 SqlElement->simpleSave called at [/var/www/....../htdocs/model/TenderMain.php:389]
2019-09-23 10:11:27.210 ***** ERROR ***** [V8.2.0] #9 TenderMain->save called at [/var/www/....../htdocs/tool/saveObject.php:78]
2019-09-23 10:11:27.212 ***** ERROR ***** [V8.2.0] Exception-[25P02] SQLSTATE[25P02]: In failed sql transaction: 7 ERROR: current transaction is aborted, commands ignored until end of transaction block
2019-09-23 10:11:27.212 ***** ERROR ***** [V8.2.0] For query : insert into history ( refType , refId , operation , colName , newValue , operationDate , idUser , isWorkHistory ) values ('Tender', '2', 'update', 'handled', '0', '2019-09-23 10:11:26', '3', '0')
2019-09-23 10:11:27.212 ***** ERROR ***** [V8.2.0] Strack trace :
2019-09-23 10:11:27.213 ***** ERROR ***** [V8.2.0] #0 Sql->query called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1276]
2019-09-23 10:11:27.213 ***** ERROR ***** [V8.2.0] #1 SqlElement->insertSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1070]
2019-09-23 10:11:27.213 ***** ERROR ***** [V8.2.0] #2 SqlElement->saveSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:733]
2019-09-23 10:11:27.214 ***** ERROR ***** [V8.2.0] #3 SqlElement->save called at [/var/www/....../htdocs/model/History.php:116]
2019-09-23 10:11:27.214 ***** ERROR ***** [V8.2.0] #4 History->store called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1553]
2019-09-23 10:11:27.214 ***** ERROR ***** [V8.2.0] #5 SqlElement->updateSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1064]
2019-09-23 10:11:27.215 ***** ERROR ***** [V8.2.0] #6 SqlElement->saveSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:876]
2019-09-23 10:11:27.215 ***** ERROR ***** [V8.2.0] #7 SqlElement->saveForced called at [/var/www/....../htdocs/model/persistence/SqlElement.php:887]
2019-09-23 10:11:27.215 ***** ERROR ***** [V8.2.0] #8 SqlElement->simpleSave called at [/var/www/....../htdocs/model/TenderMain.php:389]
2019-09-23 10:11:27.216 ***** ERROR ***** [V8.2.0] #9 TenderMain->save called at [/var/www/....../htdocs/tool/saveObject.php:78]
2019-09-23 10:11:27.218 ***** ERROR ***** [V8.2.0] Exception-[25P02] SQLSTATE[25P02]: In failed sql transaction: 7 ERROR: current transaction is aborted, commands ignored until end of transaction block
2019-09-23 10:11:27.218 ***** ERROR ***** [V8.2.0] For query : insert into history ( refType , refId , operation , colName , newValue , operationDate , idUser , isWorkHistory ) values ('Tender', '2', 'update', 'done', '0', '2019-09-23 10:11:26', '3', '0')
2019-09-23 10:11:27.218 ***** ERROR ***** [V8.2.0] Strack trace :
2019-09-23 10:11:27.219 ***** ERROR ***** [V8.2.0] #0 Sql->query called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1276]
2019-09-23 10:11:27.219 ***** ERROR ***** [V8.2.0] #1 SqlElement->insertSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1070]
2019-09-23 10:11:27.219 ***** ERROR ***** [V8.2.0] #2 SqlElement->saveSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:733]
2019-09-23 10:11:27.219 ***** ERROR ***** [V8.2.0] #3 SqlElement->save called at [/var/www/....../htdocs/model/History.php:116]
2019-09-23 10:11:27.220 ***** ERROR ***** [V8.2.0] #4 History->store called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1553]
2019-09-23 10:11:27.220 ***** ERROR ***** [V8.2.0] #5 SqlElement->updateSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1064]
2019-09-23 10:11:27.220 ***** ERROR ***** [V8.2.0] #6 SqlElement->saveSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:876]
2019-09-23 10:11:27.221 ***** ERROR ***** [V8.2.0] #7 SqlElement->saveForced called at [/var/www/....../htdocs/model/persistence/SqlElement.php:887]
2019-09-23 10:11:27.221 ***** ERROR ***** [V8.2.0] #8 SqlElement->simpleSave called at [/var/www/....../htdocs/model/TenderMain.php:389]
2019-09-23 10:11:27.221 ***** ERROR ***** [V8.2.0] #9 TenderMain->save called at [/var/www/....../htdocs/tool/saveObject.php:78]
2019-09-23 10:11:27.223 ***** ERROR ***** [V8.2.0] Exception-[25P02] SQLSTATE[25P02]: In failed sql transaction: 7 ERROR: current transaction is aborted, commands ignored until end of transaction block
2019-09-23 10:11:27.224 ***** ERROR ***** [V8.2.0] For query : insert into history ( refType , refId , operation , colName , newValue , operationDate , idUser , isWorkHistory ) values ('Tender', '2', 'update', 'idle', '0', '2019-09-23 10:11:26', '3', '0')
2019-09-23 10:11:27.224 ***** ERROR ***** [V8.2.0] Strack trace :
2019-09-23 10:11:27.224 ***** ERROR ***** [V8.2.0] #0 Sql->query called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1276]
2019-09-23 10:11:27.225 ***** ERROR ***** [V8.2.0] #1 SqlElement->insertSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1070]
2019-09-23 10:11:27.225 ***** ERROR ***** [V8.2.0] #2 SqlElement->saveSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:733]
2019-09-23 10:11:27.225 ***** ERROR ***** [V8.2.0] #3 SqlElement->save called at [/var/www/....../htdocs/model/History.php:116]
2019-09-23 10:11:27.226 ***** ERROR ***** [V8.2.0] #4 History->store called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1553]
2019-09-23 10:11:27.226 ***** ERROR ***** [V8.2.0] #5 SqlElement->updateSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1064]
2019-09-23 10:11:27.226 ***** ERROR ***** [V8.2.0] #6 SqlElement->saveSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:876]
2019-09-23 10:11:27.227 ***** ERROR ***** [V8.2.0] #7 SqlElement->saveForced called at [/var/www/....../htdocs/model/persistence/SqlElement.php:887]
2019-09-23 10:11:27.227 ***** ERROR ***** [V8.2.0] #8 SqlElement->simpleSave called at [/var/www/....../htdocs/model/TenderMain.php:389]
2019-09-23 10:11:27.227 ***** ERROR ***** [V8.2.0] #9 TenderMain->save called at [/var/www/....../htdocs/tool/saveObject.php:78]
2019-09-23 10:11:27.229 ***** ERROR ***** [V8.2.0] Exception-[25P02] SQLSTATE[25P02]: In failed sql transaction: 7 ERROR: current transaction is aborted, commands ignored until end of transaction block
2019-09-23 10:11:27.230 ***** ERROR ***** [V8.2.0] For query : insert into history ( refType , refId , operation , colName , newValue , operationDate , idUser , isWorkHistory ) values ('Tender', '2', 'update', 'cancelled', '0', '2019-09-23 10:11:26', '3', '0')
2019-09-23 10:11:27.230 ***** ERROR ***** [V8.2.0] Strack trace :
2019-09-23 10:11:27.230 ***** ERROR ***** [V8.2.0] #0 Sql->query called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1276]
2019-09-23 10:11:27.231 ***** ERROR ***** [V8.2.0] #1 SqlElement->insertSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1070]
2019-09-23 10:11:27.231 ***** ERROR ***** [V8.2.0] #2 SqlElement->saveSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:733]
2019-09-23 10:11:27.231 ***** ERROR ***** [V8.2.0] #3 SqlElement->save called at [/var/www/....../htdocs/model/History.php:116]
2019-09-23 10:11:27.231 ***** ERROR ***** [V8.2.0] #4 History->store called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1553]
2019-09-23 10:11:27.232 ***** ERROR ***** [V8.2.0] #5 SqlElement->updateSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1064]
2019-09-23 10:11:27.232 ***** ERROR ***** [V8.2.0] #6 SqlElement->saveSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:876]
2019-09-23 10:11:27.232 ***** ERROR ***** [V8.2.0] #7 SqlElement->saveForced called at [/var/www/....../htdocs/model/persistence/SqlElement.php:887]
2019-09-23 10:11:27.233 ***** ERROR ***** [V8.2.0] #8 SqlElement->simpleSave called at [/var/www/....../htdocs/model/TenderMain.php:389]
2019-09-23 10:11:27.233 ***** ERROR ***** [V8.2.0] #9 TenderMain->save called at [/var/www/....../htdocs/tool/saveObject.php:78]
2019-09-23 10:11:27.234 ***** ERROR ***** [V8.2.0] Exception-[25P02] SQLSTATE[25P02]: In failed sql transaction: 7 ERROR: current transaction is aborted, commands ignored until end of transaction block
2019-09-23 10:11:27.234 ***** ERROR ***** [V8.2.0] For query : select * from project where id=14
2019-09-23 10:11:27.235 ***** ERROR ***** [V8.2.0] Strack trace :
2019-09-23 10:11:27.235 ***** ERROR ***** [V8.2.0] #0 Sql->query called at [/var/www/....../htdocs/model/persistence/SqlElement.php:2939]
2019-09-23 10:11:27.235 ***** ERROR ***** [V8.2.0] #1 SqlElement->getSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:672]
2019-09-23 10:11:27.236 ***** ERROR ***** [V8.2.0] #2 SqlElement->__construct called at [/var/www/....../htdocs/model/ProjectMain.php:188]
2019-09-23 10:11:27.236 ***** ERROR ***** [V8.2.0] #3 ProjectMain->__construct called at [/var/www/....../htdocs/model/Project.php:40]
2019-09-23 10:11:27.237 ***** ERROR ***** [V8.2.0] #4 Project->__construct called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1103]
2019-09-23 10:11:27.237 ***** ERROR ***** [V8.2.0] #5 SqlElement->saveSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:876]
2019-09-23 10:11:27.237 ***** ERROR ***** [V8.2.0] #6 SqlElement->saveForced called at [/var/www/....../htdocs/model/persistence/SqlElement.php:887]
2019-09-23 10:11:27.237 ***** ERROR ***** [V8.2.0] #7 SqlElement->simpleSave called at [/var/www/....../htdocs/model/TenderMain.php:389]
2019-09-23 10:11:27.238 ***** ERROR ***** [V8.2.0] #8 TenderMain->save called at [/var/www/....../htdocs/tool/saveObject.php:78]
2019-09-23 10:11:27.238 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.238 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:27.239 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.239 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.239 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:27.240 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.240 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'id' for Class 'Project' : field 'id' not found in Database.
2019-09-23 10:11:27.240 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.241 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:27.241 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.241 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.242 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:27.242 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.242 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'name' for Class 'Project' : field 'name' not found in Database.
2019-09-23 10:11:27.243 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.243 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:27.243 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.244 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.244 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:27.244 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.245 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'idProjectType' for Class 'Project' : field 'idProjectType' not found in Database.
2019-09-23 10:11:27.245 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.245 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:27.246 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.246 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.246 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:27.247 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'idOrganization' for Class 'Project' : field 'idOrganization' not found in Database.
2019-09-23 10:11:27.247 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.247 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:27.248 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.248 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.248 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:27.249 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.249 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'idCategory' for Class 'Project' : field 'idCategory' not found in Database.
2019-09-23 10:11:27.249 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.250 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:27.250 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.250 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.251 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:27.251 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.251 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'organizationInherited' for Class 'Project' : field 'organizationInherited' not found in Database.
2019-09-23 10:11:27.252 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.252 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:27.253 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.253 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.253 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:27.254 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.254 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'organizationElementary' for Class 'Project' : field 'organizationElementary' not found in Database.
2019-09-23 10:11:27.254 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.255 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:27.255 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.255 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.256 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:27.256 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.256 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'codeType' for Class 'Project' : field 'codeType' not found in Database.
2019-09-23 10:11:27.257 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.257 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:27.257 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.258 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.258 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:27.258 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.258 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'idClient' for Class 'Project' : field 'idClient' not found in Database.
2019-09-23 10:11:27.259 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.259 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:27.259 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.260 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.260 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:27.260 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.261 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'idContact' for Class 'Project' : field 'idContact' not found in Database.
2019-09-23 10:11:27.261 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.261 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:27.262 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.262 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.262 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:27.263 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.263 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'projectCode' for Class 'Project' : field 'projectCode' not found in Database.
2019-09-23 10:11:27.263 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.264 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:27.264 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.264 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.265 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:27.265 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.265 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'contractCode' for Class 'Project' : field 'contractCode' not found in Database.
2019-09-23 10:11:27.266 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.266 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:27.266 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.267 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:27.267 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.267 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'clientCode' for Class 'Project' : field 'clientCode' not found in Database.
2019-09-23 10:11:27.268 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.268 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:27.268 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.269 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.269 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:27.269 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.270 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'idProject' for Class 'Project' : field 'idProject' not found in Database.
2019-09-23 10:11:27.270 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.270 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:27.271 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.271 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.271 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:27.272 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.272 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'idSponsor' for Class 'Project' : field 'idSponsor' not found in Database.
2019-09-23 10:11:27.272 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.273 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:27.273 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.273 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.274 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:27.274 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.274 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'idResource' for Class 'Project' : field 'idResource' not found in Database.
2019-09-23 10:11:27.275 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.275 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:27.275 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.276 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.276 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:27.276 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.277 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'idUser' for Class 'Project' : field 'idUser' not found in Database.
2019-09-23 10:11:27.277 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.277 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:27.278 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.278 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.278 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:27.279 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.279 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'creationDate' for Class 'Project' : field 'creationDate' not found in Database.
2019-09-23 10:11:27.279 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.280 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:27.280 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.280 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.280 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:27.281 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.281 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'lastUpdateDateTime' for Class 'Project' : field 'lastUpdateDateTime' not found in Database.
2019-09-23 10:11:27.281 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.282 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:27.282 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.282 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.283 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:27.283 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.283 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'color' for Class 'Project' : field 'color' not found in Database.
2019-09-23 10:11:27.284 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.284 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:27.284 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.285 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.285 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:27.285 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.286 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'longitude' for Class 'Project' : field 'longitude' not found in Database.
2019-09-23 10:11:27.286 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.286 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:27.287 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.287 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.287 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:27.288 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.288 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'latitude' for Class 'Project' : field 'latitude' not found in Database.
2019-09-23 10:11:27.288 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.289 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:27.289 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.289 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.289 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:27.290 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.290 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'description' for Class 'Project' : field 'description' not found in Database.
2019-09-23 10:11:27.291 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.291 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:27.291 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.292 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:27.292 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.292 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'objectives' for Class 'Project' : field 'objectives' not found in Database.
2019-09-23 10:11:27.293 ***** ERROR ***** [V8.2.0] Exception-[25P02] SQLSTATE[25P02]: In failed sql transaction: 7 ERROR: current transaction is aborted, commands ignored until end of transaction block
2019-09-23 10:11:27.294 ***** ERROR ***** [V8.2.0] For query : select id from planningelement where refId =14 and refType ='Project'
2019-09-23 10:11:27.294 ***** ERROR ***** [V8.2.0] Strack trace :
2019-09-23 10:11:27.294 ***** ERROR ***** [V8.2.0] #0 Sql->query called at [/var/www/....../htdocs/model/persistence/SqlElement.php:3069]
2019-09-23 10:11:27.295 ***** ERROR ***** [V8.2.0] #1 SqlElement->getDependantSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:2990]
2019-09-23 10:11:27.295 ***** ERROR ***** [V8.2.0] #2 SqlElement->getSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:672]
2019-09-23 10:11:27.295 ***** ERROR ***** [V8.2.0] #3 SqlElement->__construct called at [/var/www/....../htdocs/model/ProjectMain.php:188]
2019-09-23 10:11:27.296 ***** ERROR ***** [V8.2.0] #4 ProjectMain->__construct called at [/var/www/....../htdocs/model/Project.php:40]
2019-09-23 10:11:27.296 ***** ERROR ***** [V8.2.0] #5 Project->__construct called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1103]
2019-09-23 10:11:27.296 ***** ERROR ***** [V8.2.0] #6 SqlElement->saveSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:876]
2019-09-23 10:11:27.297 ***** ERROR ***** [V8.2.0] #7 SqlElement->saveForced called at [/var/www/....../htdocs/model/persistence/SqlElement.php:887]
2019-09-23 10:11:27.297 ***** ERROR ***** [V8.2.0] #8 SqlElement->simpleSave called at [/var/www/....../htdocs/model/TenderMain.php:389]
2019-09-23 10:11:27.297 ***** ERROR ***** [V8.2.0] #9 TenderMain->save called at [/var/www/....../htdocs/tool/saveObject.php:78]
2019-09-23 10:11:27.298 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.298 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:27.298 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.299 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.299 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:27.299 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.300 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'idStatus' for Class 'Project' : field 'idStatus' not found in Database.
2019-09-23 10:11:27.300 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.300 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:27.301 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.301 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.301 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:27.302 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.302 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'idHealth' for Class 'Project' : field 'idHealth' not found in Database.
2019-09-23 10:11:27.302 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.302 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:27.303 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.303 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.303 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:27.304 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.304 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'idQuality' for Class 'Project' : field 'idQuality' not found in Database.
2019-09-23 10:11:27.304 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.305 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:27.305 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.305 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.306 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:27.306 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.306 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'idTrend' for Class 'Project' : field 'idTrend' not found in Database.
2019-09-23 10:11:27.307 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.307 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:27.307 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.308 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.308 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:27.308 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.309 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'idOverallProgress' for Class 'Project' : field 'idOverallProgress' not found in Database.
2019-09-23 10:11:27.309 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.309 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:27.310 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.310 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.310 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:27.311 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.311 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'fixPlanning' for Class 'Project' : field 'fixPlanning' not found in Database.
2019-09-23 10:11:27.311 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.312 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:27.312 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.312 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.313 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:27.313 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.313 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'fixPerimeter' for Class 'Project' : field 'fixPerimeter' not found in Database.
2019-09-23 10:11:27.314 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.314 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:27.315 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.315 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.316 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:27.316 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.316 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'isUnderConstruction' for Class 'Project' : field 'isUnderConstruction' not found in Database.
2019-09-23 10:11:27.317 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.317 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:27.318 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.318 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.319 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:27.319 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.320 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'excludeFromGlobalPlanning' for Class 'Project' : field 'excludeFromGlobalPlanning' not found in Database.
2019-09-23 10:11:27.320 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.321 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:27.321 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.322 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.322 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:27.323 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.323 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'handled' for Class 'Project' : field 'handled' not found in Database.
2019-09-23 10:11:27.324 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.324 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:27.325 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.325 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.325 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:27.326 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.326 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'handledDate' for Class 'Project' : field 'handledDate' not found in Database.
2019-09-23 10:11:27.326 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.327 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:27.327 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.327 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.328 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:27.328 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.328 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'done' for Class 'Project' : field 'done' not found in Database.
2019-09-23 10:11:27.329 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.329 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:27.329 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.330 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:27.330 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.330 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'doneDate' for Class 'Project' : field 'doneDate' not found in Database.
2019-09-23 10:11:27.331 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.331 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:27.331 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.332 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.332 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:27.332 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.332 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'idle' for Class 'Project' : field 'idle' not found in Database.
2019-09-23 10:11:27.333 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.333 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:27.333 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.334 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.334 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:27.334 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.335 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'idleDate' for Class 'Project' : field 'idleDate' not found in Database.
2019-09-23 10:11:27.335 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.335 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:27.335 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.336 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.336 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:27.336 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.337 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'cancelled' for Class 'Project' : field 'cancelled' not found in Database.
2019-09-23 10:11:27.338 ***** ERROR ***** [V8.2.0] Exception-[25P02] SQLSTATE[25P02]: In failed sql transaction: 7 ERROR: current transaction is aborted, commands ignored until end of transaction block
2019-09-23 10:11:27.338 ***** ERROR ***** [V8.2.0] For query : select id from productproject where idProject= '14' order by id desc
2019-09-23 10:11:27.338 ***** ERROR ***** [V8.2.0] Strack trace :
2019-09-23 10:11:27.339 ***** ERROR ***** [V8.2.0] #0 Sql->query called at [/var/www/....../htdocs/model/persistence/SqlElement.php:3113]
2019-09-23 10:11:27.339 ***** ERROR ***** [V8.2.0] #1 SqlElement->getDependantSqlElements called at [/var/www/....../htdocs/model/persistence/SqlElement.php:2984]
2019-09-23 10:11:27.339 ***** ERROR ***** [V8.2.0] #2 SqlElement->getSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:672]
2019-09-23 10:11:27.339 ***** ERROR ***** [V8.2.0] #3 SqlElement->__construct called at [/var/www/....../htdocs/model/ProjectMain.php:188]
2019-09-23 10:11:27.340 ***** ERROR ***** [V8.2.0] #4 ProjectMain->__construct called at [/var/www/....../htdocs/model/Project.php:40]
2019-09-23 10:11:27.340 ***** ERROR ***** [V8.2.0] #5 Project->__construct called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1103]
2019-09-23 10:11:27.340 ***** ERROR ***** [V8.2.0] #6 SqlElement->saveSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:876]
2019-09-23 10:11:27.341 ***** ERROR ***** [V8.2.0] #7 SqlElement->saveForced called at [/var/www/....../htdocs/model/persistence/SqlElement.php:887]
2019-09-23 10:11:27.341 ***** ERROR ***** [V8.2.0] #8 SqlElement->simpleSave called at [/var/www/....../htdocs/model/TenderMain.php:389]
2019-09-23 10:11:27.341 ***** ERROR ***** [V8.2.0] #9 TenderMain->save called at [/var/www/....../htdocs/tool/saveObject.php:78]
2019-09-23 10:11:27.342 ***** ERROR ***** [V8.2.0] Exception-[25P02] SQLSTATE[25P02]: In failed sql transaction: 7 ERROR: current transaction is aborted, commands ignored until end of transaction block
2019-09-23 10:11:27.342 ***** ERROR ***** [V8.2.0] For query : select * from versionproject where versionproject.idProject=14
2019-09-23 10:11:27.343 ***** ERROR ***** [V8.2.0] Strack trace :
2019-09-23 10:11:27.343 ***** ERROR ***** [V8.2.0] #0 Sql->query called at [/var/www/....../htdocs/model/persistence/SqlElement.php:2480]
2019-09-23 10:11:27.343 ***** ERROR ***** [V8.2.0] #1 SqlElement->getSqlElementsFromCriteria called at [/var/www/....../htdocs/model/persistence/SqlElement.php:2961]
2019-09-23 10:11:27.344 ***** ERROR ***** [V8.2.0] #2 SqlElement->getSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:672]
2019-09-23 10:11:27.344 ***** ERROR ***** [V8.2.0] #3 SqlElement->__construct called at [/var/www/....../htdocs/model/ProjectMain.php:188]
2019-09-23 10:11:27.344 ***** ERROR ***** [V8.2.0] #4 ProjectMain->__construct called at [/var/www/....../htdocs/model/Project.php:40]
2019-09-23 10:11:27.344 ***** ERROR ***** [V8.2.0] #5 Project->__construct called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1103]
2019-09-23 10:11:27.345 ***** ERROR ***** [V8.2.0] #6 SqlElement->saveSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:876]
2019-09-23 10:11:27.345 ***** ERROR ***** [V8.2.0] #7 SqlElement->saveForced called at [/var/www/....../htdocs/model/persistence/SqlElement.php:887]
2019-09-23 10:11:27.345 ***** ERROR ***** [V8.2.0] #8 SqlElement->simpleSave called at [/var/www/....../htdocs/model/TenderMain.php:389]
2019-09-23 10:11:27.346 ***** ERROR ***** [V8.2.0] #9 TenderMain->save called at [/var/www/....../htdocs/tool/saveObject.php:78]
2019-09-23 10:11:27.346 ***** ERROR ***** [V8.2.0] Exception-[25P02] SQLSTATE[25P02]: In failed sql transaction: 7 ERROR: current transaction is aborted, commands ignored until end of transaction block
2019-09-23 10:11:27.347 ***** ERROR ***** [V8.2.0] For query : select * from dependency where dependency.SuccessorRefType='Project' and dependency.SuccessorRefId=14
2019-09-23 10:11:27.347 ***** ERROR ***** [V8.2.0] Strack trace :
2019-09-23 10:11:27.347 ***** ERROR ***** [V8.2.0] #0 Sql->query called at [/var/www/....../htdocs/model/persistence/SqlElement.php:2480]
2019-09-23 10:11:27.348 ***** ERROR ***** [V8.2.0] #1 SqlElement->getSqlElementsFromCriteria called at [/var/www/....../htdocs/model/persistence/SqlElement.php:2981]
2019-09-23 10:11:27.348 ***** ERROR ***** [V8.2.0] #2 SqlElement->getSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:672]
2019-09-23 10:11:27.348 ***** ERROR ***** [V8.2.0] #3 SqlElement->__construct called at [/var/www/....../htdocs/model/ProjectMain.php:188]
2019-09-23 10:11:27.349 ***** ERROR ***** [V8.2.0] #4 ProjectMain->__construct called at [/var/www/....../htdocs/model/Project.php:40]
2019-09-23 10:11:27.349 ***** ERROR ***** [V8.2.0] #5 Project->__construct called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1103]
2019-09-23 10:11:27.349 ***** ERROR ***** [V8.2.0] #6 SqlElement->saveSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:876]
2019-09-23 10:11:27.349 ***** ERROR ***** [V8.2.0] #7 SqlElement->saveForced called at [/var/www/....../htdocs/model/persistence/SqlElement.php:887]
2019-09-23 10:11:27.350 ***** ERROR ***** [V8.2.0] #8 SqlElement->simpleSave called at [/var/www/....../htdocs/model/TenderMain.php:389]
2019-09-23 10:11:27.350 ***** ERROR ***** [V8.2.0] #9 TenderMain->save called at [/var/www/....../htdocs/tool/saveObject.php:78]
2019-09-23 10:11:27.351 ***** ERROR ***** [V8.2.0] Exception-[25P02] SQLSTATE[25P02]: In failed sql transaction: 7 ERROR: current transaction is aborted, commands ignored until end of transaction block
2019-09-23 10:11:27.351 ***** ERROR ***** [V8.2.0] For query : select * from dependency where dependency.PredecessorRefType='Project' and dependency.PredecessorRefId=14
2019-09-23 10:11:27.352 ***** ERROR ***** [V8.2.0] Strack trace :
2019-09-23 10:11:27.352 ***** ERROR ***** [V8.2.0] #0 Sql->query called at [/var/www/....../htdocs/model/persistence/SqlElement.php:2480]
2019-09-23 10:11:27.352 ***** ERROR ***** [V8.2.0] #1 SqlElement->getSqlElementsFromCriteria called at [/var/www/....../htdocs/model/persistence/SqlElement.php:2981]
2019-09-23 10:11:27.353 ***** ERROR ***** [V8.2.0] #2 SqlElement->getSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:672]
2019-09-23 10:11:27.353 ***** ERROR ***** [V8.2.0] #3 SqlElement->__construct called at [/var/www/....../htdocs/model/ProjectMain.php:188]
2019-09-23 10:11:27.353 ***** ERROR ***** [V8.2.0] #4 ProjectMain->__construct called at [/var/www/....../htdocs/model/Project.php:40]
2019-09-23 10:11:27.353 ***** ERROR ***** [V8.2.0] #5 Project->__construct called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1103]
2019-09-23 10:11:27.354 ***** ERROR ***** [V8.2.0] #6 SqlElement->saveSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:876]
2019-09-23 10:11:27.354 ***** ERROR ***** [V8.2.0] #7 SqlElement->saveForced called at [/var/www/....../htdocs/model/persistence/SqlElement.php:887]
2019-09-23 10:11:27.354 ***** ERROR ***** [V8.2.0] #8 SqlElement->simpleSave called at [/var/www/....../htdocs/model/TenderMain.php:389]
2019-09-23 10:11:27.355 ***** ERROR ***** [V8.2.0] #9 TenderMain->save called at [/var/www/....../htdocs/tool/saveObject.php:78]
2019-09-23 10:11:27.355 ***** ERROR ***** [V8.2.0] Exception-[25P02] SQLSTATE[25P02]: In failed sql transaction: 7 ERROR: current transaction is aborted, commands ignored until end of transaction block
2019-09-23 10:11:27.356 ***** ERROR ***** [V8.2.0] For query : select * from link where ( ref1Type='Project' and ref1Id=14) or ( ref2Type='Project' and ref2Id=14 )
2019-09-23 10:11:27.356 ***** ERROR ***** [V8.2.0] Strack trace :
2019-09-23 10:11:27.356 ***** ERROR ***** [V8.2.0] #0 Sql->query called at [/var/www/....../htdocs/model/persistence/SqlElement.php:2480]
2019-09-23 10:11:27.357 ***** ERROR ***** [V8.2.0] #1 SqlElement->getSqlElementsFromCriteria called at [/var/www/....../htdocs/model/Link.php:170]
2019-09-23 10:11:27.357 ***** ERROR ***** [V8.2.0] #2 Link->getLinksForObject called at [/var/www/....../htdocs/model/persistence/SqlElement.php:2953]
2019-09-23 10:11:27.357 ***** ERROR ***** [V8.2.0] #3 SqlElement->getSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:672]
2019-09-23 10:11:27.358 ***** ERROR ***** [V8.2.0] #4 SqlElement->__construct called at [/var/www/....../htdocs/model/ProjectMain.php:188]
2019-09-23 10:11:27.358 ***** ERROR ***** [V8.2.0] #5 ProjectMain->__construct called at [/var/www/....../htdocs/model/Project.php:40]
2019-09-23 10:11:27.358 ***** ERROR ***** [V8.2.0] #6 Project->__construct called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1103]
2019-09-23 10:11:27.359 ***** ERROR ***** [V8.2.0] #7 SqlElement->saveSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:876]
2019-09-23 10:11:27.359 ***** ERROR ***** [V8.2.0] #8 SqlElement->saveForced called at [/var/www/....../htdocs/model/persistence/SqlElement.php:887]
2019-09-23 10:11:27.359 ***** ERROR ***** [V8.2.0] #9 SqlElement->simpleSave called at [/var/www/....../htdocs/model/TenderMain.php:389]
2019-09-23 10:11:27.359 ***** ERROR ***** [V8.2.0] #10 TenderMain->save called at [/var/www/....../htdocs/tool/saveObject.php:78]
2019-09-23 10:11:27.360 ***** ERROR ***** [V8.2.0] Exception-[25P02] SQLSTATE[25P02]: In failed sql transaction: 7 ERROR: current transaction is aborted, commands ignored until end of transaction block
2019-09-23 10:11:27.361 ***** ERROR ***** [V8.2.0] For query : select id from attachment where refId ='14' and refType ='Project' order by id desc
2019-09-23 10:11:27.361 ***** ERROR ***** [V8.2.0] Strack trace :
2019-09-23 10:11:27.361 ***** ERROR ***** [V8.2.0] #0 Sql->query called at [/var/www/....../htdocs/model/persistence/SqlElement.php:3113]
2019-09-23 10:11:27.361 ***** ERROR ***** [V8.2.0] #1 SqlElement->getDependantSqlElements called at [/var/www/....../htdocs/model/persistence/SqlElement.php:2984]
2019-09-23 10:11:27.362 ***** ERROR ***** [V8.2.0] #2 SqlElement->getSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:672]
2019-09-23 10:11:27.362 ***** ERROR ***** [V8.2.0] #3 SqlElement->__construct called at [/var/www/....../htdocs/model/ProjectMain.php:188]
2019-09-23 10:11:27.362 ***** ERROR ***** [V8.2.0] #4 ProjectMain->__construct called at [/var/www/....../htdocs/model/Project.php:40]
2019-09-23 10:11:27.363 ***** ERROR ***** [V8.2.0] #5 Project->__construct called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1103]
2019-09-23 10:11:27.363 ***** ERROR ***** [V8.2.0] #6 SqlElement->saveSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:876]
2019-09-23 10:11:27.363 ***** ERROR ***** [V8.2.0] #7 SqlElement->saveForced called at [/var/www/....../htdocs/model/persistence/SqlElement.php:887]
2019-09-23 10:11:27.364 ***** ERROR ***** [V8.2.0] #8 SqlElement->simpleSave called at [/var/www/....../htdocs/model/TenderMain.php:389]
2019-09-23 10:11:27.364 ***** ERROR ***** [V8.2.0] #9 TenderMain->save called at [/var/www/....../htdocs/tool/saveObject.php:78]
2019-09-23 10:11:27.365 ***** ERROR ***** [V8.2.0] Exception-[25P02] SQLSTATE[25P02]: In failed sql transaction: 7 ERROR: current transaction is aborted, commands ignored until end of transaction block
2019-09-23 10:11:27.365 ***** ERROR ***** [V8.2.0] For query : select id from note where refId ='14' and refType ='Project' order by id desc
2019-09-23 10:11:27.365 ***** ERROR ***** [V8.2.0] Strack trace :
2019-09-23 10:11:27.366 ***** ERROR ***** [V8.2.0] #0 Sql->query called at [/var/www/....../htdocs/model/persistence/SqlElement.php:3113]
2019-09-23 10:11:27.366 ***** ERROR ***** [V8.2.0] #1 SqlElement->getDependantSqlElements called at [/var/www/....../htdocs/model/persistence/SqlElement.php:2984]
2019-09-23 10:11:27.366 ***** ERROR ***** [V8.2.0] #2 SqlElement->getSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:672]
2019-09-23 10:11:27.367 ***** ERROR ***** [V8.2.0] #3 SqlElement->__construct called at [/var/www/....../htdocs/model/ProjectMain.php:188]
2019-09-23 10:11:27.367 ***** ERROR ***** [V8.2.0] #4 ProjectMain->__construct called at [/var/www/....../htdocs/model/Project.php:40]
2019-09-23 10:11:27.367 ***** ERROR ***** [V8.2.0] #5 Project->__construct called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1103]
2019-09-23 10:11:27.367 ***** ERROR ***** [V8.2.0] #6 SqlElement->saveSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:876]
2019-09-23 10:11:27.368 ***** ERROR ***** [V8.2.0] #7 SqlElement->saveForced called at [/var/www/....../htdocs/model/persistence/SqlElement.php:887]
2019-09-23 10:11:27.368 ***** ERROR ***** [V8.2.0] #8 SqlElement->simpleSave called at [/var/www/....../htdocs/model/TenderMain.php:389]
2019-09-23 10:11:27.368 ***** ERROR ***** [V8.2.0] #9 TenderMain->save called at [/var/www/....../htdocs/tool/saveObject.php:78]
2019-09-23 10:11:27.369 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.369 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:27.369 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.370 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.370 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:27.370 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.371 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'sortOrder' for Class 'Project' : field 'sortOrder' not found in Database.
2019-09-23 10:11:27.371 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.371 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2997)
2019-09-23 10:11:27.372 ***** ERROR ***** [V8.2.0] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-23 10:11:27.372 ***** ERROR ***** [V8.2.0] ERROR *****
2019-09-23 10:11:27.372 ***** ERROR ***** [V8.2.0] on file '/var/www/....../htdocs/model/persistence/SqlElement.php' at line (2999)
2019-09-23 10:11:27.373 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'isLeaveMngProject' for Class 'Project' : field 'isLeaveMngProject' not found in Database.
2019-09-23 10:11:27.373 ***** ERROR ***** [V8.2.0] Exception-[25P02] SQLSTATE[25P02]: In failed sql transaction: 7 ERROR: current transaction is aborted, commands ignored until end of transaction block
2019-09-23 10:11:27.374 ***** ERROR ***** [V8.2.0] For query : select * from indicatordefinition where nameIndicatorable='Tender' and idle = 0 and idProject in (14)
2019-09-23 10:11:27.374 ***** ERROR ***** [V8.2.0] Strack trace :
2019-09-23 10:11:27.374 ***** ERROR ***** [V8.2.0] #0 Sql->query called at [/var/www/....../htdocs/model/persistence/SqlElement.php:2480]
2019-09-23 10:11:27.375 ***** ERROR ***** [V8.2.0] #1 SqlElement->getSqlElementsFromCriteria called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1112]
2019-09-23 10:11:27.375 ***** ERROR ***** [V8.2.0] #2 SqlElement->saveSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:876]
2019-09-23 10:11:27.375 ***** ERROR ***** [V8.2.0] #3 SqlElement->saveForced called at [/var/www/....../htdocs/model/persistence/SqlElement.php:887]
2019-09-23 10:11:27.376 ***** ERROR ***** [V8.2.0] #4 SqlElement->simpleSave called at [/var/www/....../htdocs/model/TenderMain.php:389]
2019-09-23 10:11:27.376 ***** ERROR ***** [V8.2.0] #5 TenderMain->save called at [/var/www/....../htdocs/tool/saveObject.php:78]
2019-09-23 10:11:27.377 ***** ERROR ***** [V8.2.0] Exception-[25P02] SQLSTATE[25P02]: In failed sql transaction: 7 ERROR: current transaction is aborted, commands ignored until end of transaction block
2019-09-23 10:11:27.377 ***** ERROR ***** [V8.2.0] For query : select * from indicatordefinition where indicatordefinition.nameIndicatorable='Tender' and indicatordefinition.idle=0 and indicatordefinition.idProject is null
2019-09-23 10:11:27.377 ***** ERROR ***** [V8.2.0] Strack trace :
2019-09-23 10:11:27.378 ***** ERROR ***** [V8.2.0] #0 Sql->query called at [/var/www/....../htdocs/model/persistence/SqlElement.php:2480]
2019-09-23 10:11:27.378 ***** ERROR ***** [V8.2.0] #1 SqlElement->getSqlElementsFromCriteria called at [/var/www/....../htdocs/model/persistence/SqlElement.php:1115]
2019-09-23 10:11:27.378 ***** ERROR ***** [V8.2.0] #2 SqlElement->saveSqlElement called at [/var/www/....../htdocs/model/persistence/SqlElement.php:876]
2019-09-23 10:11:27.379 ***** ERROR ***** [V8.2.0] #3 SqlElement->saveForced called at [/var/www/....../htdocs/model/persistence/SqlElement.php:887]
2019-09-23 10:11:27.379 ***** ERROR ***** [V8.2.0] #4 SqlElement->simpleSave called at [/var/www/....../htdocs/model/TenderMain.php:389]
2019-09-23 10:11:27.379 ***** ERROR ***** [V8.2.0] #5 TenderMain->save called at [/var/www/....../htdocs/tool/saveObject.php:78]
2019-09-23 10:11:27.380 ***** ERROR ***** [V8.2.0] Exception-[25P02] SQLSTATE[25P02]: In failed sql transaction: 7 ERROR: current transaction is aborted, commands ignored until end of transaction block
2019-09-23 10:11:27.381 ***** ERROR ***** [V8.2.0] For query : select * from checklistdefinition where nameChecklistable='Tender' and (idType is null or idType='114')
2019-09-23 10:11:27.381 ***** ERROR ***** [V8.2.0] Strack trace :
2019-09-23 10:11:27.381 ***** ERROR ***** [V8.2.0] #0 Sql->query called at [/var/www/....../htdocs/model/persistence/SqlElement.php:2480]
2019-09-23 10:11:27.382 ***** ERROR ***** [V8.2.0] #1 SqlElement->getSqlElementsFromCriteria called at [/var/www/....../htdocs/tool/saveObject.php:91]
2019-09-23 10:11:27.997 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'taxAmount' for Class 'Tender' : field 'taxAmount' not found in Database.
2019-09-23 10:11:27.997 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'fullAmount' for Class 'Tender' : field 'fullAmount' not found in Database.
2019-09-23 10:11:27.997 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'totalUntaxedAmount' for Class 'Tender' : field 'totalUntaxedAmount' not found in Database.
2019-09-23 10:11:27.997 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'totalTaxAmount' for Class 'Tender' : field 'totalTaxAmount' not found in Database.
2019-09-23 10:11:27.998 ***** ERROR ***** [V8.2.0] Error on SqlElement to get 'totalFullAmount' for Class 'Tender' : field 'totalFullAmount' not found in Database.
23 Sep 2019 21:50 #8 by babynus
This issue, appearing only on postgres database,, is fixed on V8.2.1
Time to create page: 0.107 seconds
