ProjeQtOr free project management software - [SOLVED] Calculate and font - Page 2 - ProjeQtOr
27 Mar 2019 19:21 #7 by Lee
Replied by Lee on topic Calculate and font
Il select French language.
After clean, almost same problem...
Thx.
27 Mar 2019 23:22 #8 by babynus
Replied by babynus on topic Calculate and font
Ok,
it seems the methos used to display month name generate different results depending on PHP settings.
We'll find another way to fix display.
Will be published in next patch.
28 Mar 2019 09:33 #9 by Lee
If you have the parameter to change, I can change it.
Else, I ll wait the patch...
Thx
