ProjeQtOr free project management software - [SOLVED] Calculate and font - ProjeQtOr
26 Mar 2019 19:42 #1 by Lee
Calculate and font was created by Lee
I got this error in the log.
2019-03-26 19:20:08.384 ===== TRACE ===== Calcul automatique du planning : <b>calcul différentiel</b> - Projets : 1
2019-03-26 19:20:08.587 ===== TRACE ===== Calcul automatique du planning : <b>calcul différentiel</b> - INCOMPLETE
See also then problem with the font, specials characters are not displayed correctly.
Thx.
27 Mar 2019 09:23 - 27 Mar 2019 09:25 #2 by babynus
Replied by babynus on topic Calculate and font
This is not an error, this is a trace of execution.
Message INCOMPLETE means there was nothing to plan.
This may be linked to issue we fixed on V7.4.3 : access rights were not adapted to automatic planning.
We also changed message to be more clear.
Try V7.4.3
Special characters are due to messae stored in UTF-8, and you may have opened log file in ANSI mode.
Last edit: 27 Mar 2019 09:25 by babynus.
27 Mar 2019 09:32 - 27 Mar 2019 09:32 #3 by Lee
Replied by Lee on topic Calculate and font
Ok, this means that for other projects, no problem ?
I see on the calendar absence, month like "février" are not displayed correctly.
Last edit: 27 Mar 2019 09:32 by Lee.
27 Mar 2019 12:53 #4 by babynus
There is no "problem".
It is just that calculation is not executed as expected.
Try and migrate to V7.4.3 to avoid the issue.
I don't reproduce.
Can you show print screen ?
27 Mar 2019 14:45 #5 by Lee
Ok, migration done. I'll verify later.
Here my screen...
27 Mar 2019 18:41 #6 by babynus
Text within brackets means code is not translated...
which language have yu selected ?
Can you try and clean browset cahce (not only F5, really clean cache with dedicate browser feature)
