ProjeQtOr free project management software - V7.4.3 - Page 2 - ProjeQtOr
V7.4.3
13 Mar 2019 16:54 #7 by Durou C
Replied by Durou C on topic V7.4.3
I've change wesum.idActivty to wesum.idActibity.
I have no error on log file now. But I could not create new activity...
13 Mar 2019 17:39 #8 by babynus
Replied by babynus on topic V7.4.3
If you used screen customization, try and rename file model/custom/Activity.php (to model/custom/Activity.php.sav for instance)
If you then can create activity. Post the file here for fixing.
Also be sure to use latest version of the plugin (old versions may lead to such issues)
If problem persists, please chack for errors in :
- projeqtor log file
- apache log file
- browser console
13 Mar 2019 18:07 #9 by Durou C
I try to renane Activity.php.sav on custom folder, nothing change, cannot create activity.
Nothing on log file projeqtor.
Where i can find the apache2 log file ?
13 Mar 2019 18:09 #10 by Durou C
apache2 error log:
Wed Mar 13 05:32:17.526121 2019] [:error] [pid 16514] [client 14.192.8.246:12405] script '/var/www/projeqtor/mybestloves.php' not found or unable to stat
[Wed Mar 13 10:04:31.919591 2019] [:error] [pid 20515] [client 192.168.100.105:50928] PHP Warning: POST Content-Length of 31997052 bytes exceeds the limit of 8388608 bytes in Unknown on line 0, referer: http://192.168.100.200/view/main.php
[Wed Mar 13 11:22:23.551030 2019] [:error] [pid 20368] [client 192.168.100.105:51371] PHP Fatal error: Maximum execution time of 0 seconds exceeded in /var/www/projeqtor/tool/projeqtor.php on line 3317, referer: http://192.168.100.200/view/main.php
[Wed Mar 13 13:40:45.372025 2019] [:error] [pid 20959] [client 106.13.70.118:57434] script '/var/www/projeqtor/main.php' not found or unable to stat, referer: 185.18.208.18/
[Wed Mar 13 15:54:18.043005 2019] [:error] [pid 22186] [client 192.168.100.157:51840] PHP Fatal error: Maximum execution time of 0 seconds exceeded in /var/www/projeqtor/model/persistence/SqlElement.php on line 2906, referer: http://192.168.100.200/view/main.php?directAccess=true&objectClass=Requirement&objectId=78
[Wed Mar 13 16:46:08.203166 2019] [core:notice] [pid 9395] AH00051: child pid 16100 exit signal Segmentation fault (11), possible coredump in /etc/apache2
[Wed Mar 13 16:46:08.203231 2019] [mpm_prefork:notice] [pid 9395] AH00169: caught SIGTERM, shutting down
[Wed Mar 13 16:46:08.991475 2019] [mpm_prefork:notice] [pid 22777] AH00163: Apache/2.4.7 (Ubuntu) mod_wsgi/3.4 Python/2.7.6 configured -- resuming normal operations
[Wed Mar 13 16:46:08.991540 2019] [core:notice] [pid 22777] AH00094: Command line: '/usr/sbin/apache2'
[Wed Mar 13 16:47:55.123017 2019] [:error] [pid 22781] [client 127.0.0.1:40136] PHP Fatal error: Maximum execution time of 0 seconds exceeded in /var/www/projeqtor/model/persistence/SqlElement.php on line 2906, referer: http://127.0.0.1/view/main.php
[Wed Mar 13 17:04:42.559018 2019] [:error] [pid 23361] [client 192.168.100.105:53393] PHP Fatal error: Maximum execution time of 0 seconds exceeded in /var/www/projeqtor/model/persistence/SqlElement.php on line 3026, referer: http://192.168.100.200/view/main.php
[Wed Mar 13 18:01:18.528398 2019] [mpm_prefork:notice] [pid 22777] AH00169: caught SIGTERM, shutting down
[Wed Mar 13 18:01:19.581359 2019] [mpm_prefork:notice] [pid 24586] AH00163: Apache/2.4.7 (Ubuntu) mod_wsgi/3.4 Python/2.7.6 configured -- resuming normal operations
[Wed Mar 13 18:01:19.581425 2019] [core:notice] [pid 24586] AH00094: Command line: '/usr/sbin/apache2'
[Wed Mar 13 18:03:22.971010 2019] [:error] [pid 24600] [client 127.0.0.1:42826] PHP Fatal error: Maximum execution time of 0 seconds exceeded in /var/www/projeqtor/model/persistence/SqlElement.php on line 3026, referer: http://127.0.0.1/view/main.php
13 Mar 2019 21:28 #11 by babynus
Strange : infinite limite reached !
Try and change max_execution_time to something over zero (and possibly big)
14 Mar 2019 15:44 #12 by Durou C
I change value max_execution_time of all of php.ini file to 30000.
But nothing change...
