ProjeQtOr free project management software - V7.4.3 - Page 3 - ProjeQtOr
V7.4.3
14 Mar 2019 15:45 #13 by Durou C
Replied by Durou C on topic V7.4.3
I already could not create activity...
It's really problematic now.
14 Mar 2019 16:04 #14 by Durou C
so, now it's work, I can create an activity but it's take around 3 minutes to create one, it's not usable.
14 Mar 2019 16:29 #15 by babynus
Replied by babynus on topic V7.4.3
I guess you have some issue on your platform.
First try to restart the DB.
Then you'll need to contect your technical team to analyse the issue.
15 Mar 2019 07:14 #16 by Durou C
I'd restart the projeqtor computer and DB. nothing change.
The pb is that i'm the technical team ....
I need your help.
15 Mar 2019 07:23 #17 by Durou C
this id the last error log file from apache3
'/var/www/projeqtor/toor.php' not found or unable to stat
[Fri Mar 15 04:41:10.145215 2019] [:error] [pid 11421] [client 106.13.43.1:1768] script '/var/www/projeqtor/uu.php' not found or unable to stat
[Fri Mar 15 04:41:10.526326 2019] [:error] [pid 11421] [client 106.13.43.1:1768] script '/var/www/projeqtor/aa.php' not found or unable to stat
[Fri Mar 15 04:41:10.790446 2019] [:error] [pid 11421] [client 106.13.43.1:1768] script '/var/www/projeqtor/wb.php' not found or unable to stat
[Fri Mar 15 04:41:11.097950 2019] [:error] [pid 11421] [client 106.13.43.1:1768] script '/var/www/projeqtor/yj.php' not found or unable to stat
[Fri Mar 15 04:41:11.388276 2019] [:error] [pid 11421] [client 106.13.43.1:1768] script '/var/www/projeqtor/z.php' not found or unable to stat
[Fri Mar 15 04:41:11.723995 2019] [:error] [pid 11421] [client 106.13.43.1:1768] script '/var/www/projeqtor/7.php' not found or unable to stat
[Fri Mar 15 04:41:13.657998 2019] [:error] [pid 11421] [client 106.13.43.1:1768] script '/var/www/projeqtor/xiaoma.php' not found or unable to stat
[Fri Mar 15 04:41:13.926651 2019] [:error] [pid 11421] [client 106.13.43.1:1768] script '/var/www/projeqtor/xiaomae.php' not found or unable to stat
[Fri Mar 15 04:41:14.209297 2019] [:error] [pid 11421] [client 106.13.43.1:1768] script '/var/www/projeqtor/xiaomar.php' not found or unable to stat
[Fri Mar 15 04:41:14.451236 2019] [:error] [pid 11421] [client 106.13.43.1:1768] script '/var/www/projeqtor/qq.php' not found or unable to stat
[Fri Mar 15 04:41:14.794485 2019] [:error] [pid 11421] [client 106.13.43.1:1768] script '/var/www/projeqtor/data.php' not found or unable to stat
[Fri Mar 15 04:41:15.160340 2019] [:error] [pid 11421] [client 106.13.43.1:1768] script '/var/www/projeqtor/log.php' not found or unable to stat
[Fri Mar 15 04:41:15.463764 2019] [:error] [pid 11421] [client 106.13.43.1:1768] script '/var/www/projeqtor/fack.php' not found or unable to stat
[Fri Mar 15 04:41:15.828230 2019] [:error] [pid 11421] [client 106.13.43.1:1768] script '/var/www/projeqtor/angge.php' not found or unable to stat
[Fri Mar 15 04:41:16.951421 2019] [:error] [pid 11421] [client 106.13.43.1:1768] script '/var/www/projeqtor/cxfm666.php' not found or unable to stat
[Fri Mar 15 04:41:17.266099 2019] [:error] [pid 11421] [client 106.13.43.1:1768] script '/var/www/projeqtor/db.php' not found or unable to stat
[Fri Mar 15 04:41:17.787122 2019] [:error] [pid 11421] [client 106.13.43.1:1768] script '/var/www/projeqtor/hacly.php' not found or unable to stat
[Fri Mar 15 04:41:18.062165 2019] [:error] [pid 11421] [client 106.13.43.1:1768] script '/var/www/projeqtor/xiaomo.php' not found or unable to stat
[Fri Mar 15 04:41:18.318501 2019] [:error] [pid 11421] [client 106.13.43.1:1768] script '/var/www/projeqtor/xiaoyu.php' not found or unable to stat
[Fri Mar 15 04:41:18.622237 2019] [:error] [pid 11421] [client 106.13.43.1:1768] script '/var/www/projeqtor/xiaohei.php' not found or unable to stat
[Fri Mar 15 04:41:18.903309 2019] [:error] [pid 11421] [client 106.13.43.1:1768] script '/var/www/projeqtor/j.php' not found or unable to stat
[Fri Mar 15 04:41:19.240156 2019] [:error] [pid 11421] [client 106.13.43.1:1768] script '/var/www/projeqtor/qq5262.php' not found or unable to stat
[Fri Mar 15 04:41:19.508009 2019] [:error] [pid 11421] [client 106.13.43.1:1768] script '/var/www/projeqtor/lost.php' not found or unable to stat
[Fri Mar 15 04:41:19.809590 2019] [:error] [pid 11421] [client 106.13.43.1:1768] script '/var/www/projeqtor/php.php' not found or unable to stat
[Fri Mar 15 04:41:20.099595 2019] [:error] [pid 11421] [client 106.13.43.1:1768] script '/var/www/projeqtor/win.php' not found or unable to stat
[Fri Mar 15 04:41:20.350130 2019] [:error] [pid 11421] [client 106.13.43.1:1768] script '/var/www/projeqtor/win1.php' not found or unable to stat
[Fri Mar 15 04:41:20.654196 2019] [:error] [pid 11421] [client 106.13.43.1:1768] script '/var/www/projeqtor/linux.php' not found or unable to stat
[Fri Mar 15 04:41:21.783628 2019] [:error] [pid 11421] [client 106.13.43.1:1768] script '/var/www/projeqtor/linux1.php' not found or unable to stat
[Fri Mar 15 04:41:22.094671 2019] [:error] [pid 11421] [client 106.13.43.1:1768] script '/var/www/projeqtor/cc.php' not found or unable to stat
[Fri Mar 15 04:41:22.380794 2019] [:error] [pid 11421] [client 106.13.43.1:1768] script '/var/www/projeqtor/x.php' not found or unable to stat
[Fri Mar 15 04:41:22.747713 2019] [:error] [pid 11421] [client 106.13.43.1:1768] script '/var/www/projeqtor/lanke.php' not found or unable to stat
[Fri Mar 15 04:41:23.133125 2019] [:error] [pid 11421] [client 106.13.43.1:1768] script '/var/www/projeqtor/neko.php' not found or unable to stat
[Fri Mar 15 04:41:23.488406 2019] [:error] [pid 11421] [client 106.13.43.1:1768] script '/var/www/projeqtor/super.php' not found or unable to stat
[Fri Mar 15 04:41:23.742403 2019] [:error] [pid 11421] [client 106.13.43.1:1768] script '/var/www/projeqtor/cere.php' not found or unable to stat
[Fri Mar 15 04:41:24.053747 2019] [:error] [pid 11421] [client 106.13.43.1:1768] script '/var/www/projeqtor/aaa.php' not found or unable to stat
[Fri Mar 15 04:41:24.399992 2019] [:error] [pid 11421] [client 106.13.43.1:1768] script '/var/www/projeqtor/Administrator.php' not found or unable to stat
[Fri Mar 15 04:41:24.742569 2019] [:error] [pid 11421] [client 106.13.43.1:1768] script '/var/www/projeqtor/liangchen.php' not found or unable to stat
[Fri Mar 15 04:41:25.114908 2019] [:error] [pid 11421] [client 106.13.43.1:1768] script '/var/www/projeqtor/lucky.php' not found or unable to stat
[Fri Mar 15 04:41:25.364135 2019] [:error] [pid 11421] [client 106.13.43.1:1768] script '/var/www/projeqtor/meng.php' not found or unable to stat
[Fri Mar 15 04:41:25.705788 2019] [:error] [pid 11421] [client 106.13.43.1:1768] script '/var/www/projeqtor/no.php' not found or unable to stat
[Fri Mar 15 04:41:26.394199 2019] [:error] [pid 11421] [client 106.13.43.1:1768] script '/var/www/projeqtor/mysql.php' not found or unable to stat
[Fri Mar 15 04:41:27.371416 2019] [:error] [pid 11421] [client 106.13.43.1:1768] script '/var/www/projeqtor/Updata.php' not found or unable to stat
[Fri Mar 15 04:41:27.716952 2019] [:error] [pid 11421] [client 106.13.43.1:1768] script '/var/www/projeqtor/xxxx.php' not found or unable to stat
[Fri Mar 15 04:41:29.425465 2019] [:error] [pid 11421] [client 106.13.43.1:1768] script '/var/www/projeqtor/guai.php' not found or unable to stat
[Fri Mar 15 04:41:29.716816 2019] [:error] [pid 11421] [client 106.13.43.1:1768] script '/var/www/projeqtor/ljb.php' not found or unable to stat
[Fri Mar 15 04:41:30.687437 2019] [:error] [pid 11421] [client 106.13.43.1:1768] script '/var/www/projeqtor/www.php' not found or unable to stat
[Fri Mar 15 04:41:33.270054 2019] [:error] [pid 11421] [client 106.13.43.1:1768] script '/var/www/projeqtor/1.php' not found or unable to stat
[Fri Mar 15 04:41:33.726022 2019] [:error] [pid 11421] [client 106.13.43.1:1768] script '/var/www/projeqtor/chaoda.php' not found or unable to stat
[Fri Mar 15 04:41:34.106780 2019] [:error] [pid 11421] [client 106.13.43.1:1768] script '/var/www/projeqtor/qq.php' not found or unable to stat
[Fri Mar 15 04:41:34.529906 2019] [:error] [pid 11421] [client 106.13.43.1:1768] script '/var/www/projeqtor/vuln1.php' not found or unable to stat
[Fri Mar 15 04:41:36.404048 2019] [:error] [pid 11421] [client 106.13.43.1:1768] script '/var/www/projeqtor/orange.php' not found or unable to stat
[Fri Mar 15 04:41:37.853917 2019] [:error] [pid 11421] [client 106.13.43.1:1768] script '/var/www/projeqtor/MCLi.php' not found or unable to stat
[Fri Mar 15 04:41:38.211740 2019] [:error] [pid 11421] [client 106.13.43.1:1768] script '/var/www/projeqtor/MCLi.php' not found or unable to stat
[Fri Mar 15 04:41:38.546199 2019] [:error] [pid 11421] [client 106.13.43.1:1768] script '/var/www/projeqtor/coon.php' not found or unable to stat
[Fri Mar 15 04:41:40.813358 2019] [:error] [pid 11421] [client 106.13.43.1:1768] script '/var/www/projeqtor/1.php' not found or unable to stat
[Fri Mar 15 04:41:41.283755 2019] [:error] [pid 11421] [client 106.13.43.1:1768] script '/var/www/projeqtor/d.php' not found or unable to stat
[Fri Mar 15 04:41:41.874831 2019] [:error] [pid 11421] [client 106.13.43.1:1768] script '/var/www/projeqtor/zxc1.php' not found or unable to stat
[Fri Mar 15 04:41:42.123147 2019] [:error] [pid 11421] [client 106.13.43.1:1768] script '/var/www/projeqtor/zxc0.php' not found or unable to stat
[Fri Mar 15 04:41:42.962192 2019] [:error] [pid 11421] [client 106.13.43.1:1768] script '/var/www/projeqtor/zxc1.php' not found or unable to stat
[Fri Mar 15 04:41:43.331913 2019] [:error] [pid 11421] [client 106.13.43.1:1768] script '/var/www/projeqtor/zxc2.php' not found or unable to stat
[Fri Mar 15 04:41:43.613002 2019] [:error] [pid 11421] [client 106.13.43.1:1768] script '/var/www/projeqtor/indexa.php' not found or unable to stat
[Fri Mar 15 04:41:44.069741 2019] [:error] [pid 11421] [client 106.13.43.1:1768] script '/var/www/projeqtor/lx.php' not found or unable to stat
[Fri Mar 15 04:41:45.775986 2019] [:error] [pid 11421] [client 106.13.43.1:1768] script '/var/www/projeqtor/cn.php' not found or unable to stat
[Fri Mar 15 04:41:46.663897 2019] [:error] [pid 11421] [client 106.13.43.1:1768] script '/var/www/projeqtor/api.php' not found or unable to stat
[Fri Mar 15 04:41:48.061626 2019] [:error] [pid 11421] [client 106.13.43.1:1768] script '/var/www/projeqtor/index1.php' not found or unable to stat
[Fri Mar 15 04:41:49.347810 2019] [:error] [pid 11421] [client 106.13.43.1:1768] script '/var/www/projeqtor/info.php' not found or unable to stat
[Fri Mar 15 04:41:50.763438 2019] [:error] [pid 11630] [client 106.13.43.1:12602] script '/var/www/projeqtor/info1.php' not found or unable to stat
[Fri Mar 15 04:41:53.261958 2019] [:error] [pid 11630] [client 106.13.43.1:12602] script '/var/www/projeqtor/aaaaaa1.php' not found or unable to stat
[Fri Mar 15 04:41:53.857453 2019] [:error] [pid 11630] [client 106.13.43.1:12602] script '/var/www/projeqtor/up.php' not found or unable to stat
[Fri Mar 15 04:41:54.199673 2019] [:error] [pid 11630] [client 106.13.43.1:12602] script '/var/www/projeqtor/test123.php' not found or unable to stat
[Fri Mar 15 04:41:54.591569 2019] [:error] [pid 11630] [client 106.13.43.1:12602] script '/var/www/projeqtor/test123.php' not found or unable to stat
[Fri Mar 15 04:41:54.841321 2019] [:error] [pid 11630] [client 106.13.43.1:12602] script '/var/www/projeqtor/fb.php' not found or unable to stat
[Fri Mar 15 04:41:55.102507 2019] [:error] [pid 11630] [client 106.13.43.1:12602] script '/var/www/projeqtor/paylog.php' not found or unable to stat
[Fri Mar 15 04:41:55.375480 2019] [:error] [pid 11630] [client 106.13.43.1:12602] script '/var/www/projeqtor/paylog.php' not found or unable to stat
[Fri Mar 15 04:41:55.755979 2019] [:error] [pid 11630] [client 106.13.43.1:12602] script '/var/www/projeqtor/x.php' not found or unable to stat
[Fri Mar 15 04:41:56.113947 2019] [:error] [pid 11630] [client 106.13.43.1:12602] script '/var/www/projeqtor/cnm.php' not found or unable to stat
[Fri Mar 15 04:41:56.429855 2019] [:error] [pid 11630] [client 106.13.43.1:12602] script '/var/www/projeqtor/1ndex.php' not found or unable to stat
[Fri Mar 15 04:41:56.676571 2019] [:error] [pid 11630] [client 106.13.43.1:12602] script '/var/www/projeqtor/51.php' not found or unable to stat
[Fri Mar 15 04:41:56.919181 2019] [:error] [pid 11630] [client 106.13.43.1:12602] script '/var/www/projeqtor/cadre.php' not found or unable to stat
[Fri Mar 15 04:41:57.267837 2019] [:error] [pid 11630] [client 106.13.43.1:12602] script '/var/www/projeqtor/mm.php' not found or unable to stat
[Fri Mar 15 04:41:57.576598 2019] [:error] [pid 11630] [client 106.13.43.1:12602] script '/var/www/projeqtor/test.php' not found or unable to stat
[Fri Mar 15 04:42:00.486826 2019] [:error] [pid 11630] [client 106.13.43.1:12602] script '/var/www/projeqtor/1q.php' not found or unable to stat
[Fri Mar 15 04:42:01.005800 2019] [:error] [pid 11630] [client 106.13.43.1:12602] script '/var/www/projeqtor/1111.php' not found or unable to stat
[Fri Mar 15 04:42:01.801168 2019] [:error] [pid 11630] [client 106.13.43.1:12602] script '/var/www/projeqtor/errors.php' not found or unable to stat
[Fri Mar 15 04:42:02.796693 2019] [:error] [pid 11630] [client 106.13.43.1:12602] script '/var/www/projeqtor/q.php' not found or unable to stat
[Fri Mar 15 04:42:03.296838 2019] [:error] [pid 11630] [client 106.13.43.1:12602] script '/var/www/projeqtor/lanyecn.php' not found or unable to stat
[Fri Mar 15 04:42:05.198138 2019] [:error] [pid 11630] [client 106.13.43.1:12602] script '/var/www/projeqtor/mybestloves.php' not found or unable to stat
[Fri Mar 15 07:10:37.537165 2019] [mpm_prefork:notice] [pid 11417] AH00169: caught SIGTERM, shutting down
[Fri Mar 15 07:10:38.574468 2019] [mpm_prefork:notice] [pid 14384] AH00163: Apache/2.4.7 (Ubuntu) mod_wsgi/3.4 Python/2.7.6 configured -- resuming normal operations
[Fri Mar 15 07:10:38.574531 2019] [core:notice] [pid 14384] AH00094: Command line: '/usr/sbin/apache2'
15 Mar 2019 08:00 #18 by babynus
It seems your server is been attached by hackers.
Look at requests trying to get pages aa.php, data.php, log.php, mybestloves.php and all similar.
Protect your server againts these attacks, maybe it will solve your issues.
