ProjeQtOr free project management software - [SOLVED] The project is gone - No user right - ProjeQtOr
01 Feb 2019 15:30 #1 by UnluckyDuck
Hi community,
I'm having a problem with ProjeQtOr for the second time.
I created a project (i'm administrator), set some properties and add some ressource assignments for the team's project.
At the penultimate resource, an error appeared (not had time to read it).
The properties disappeared, but I still saw the project in the overall list of projects.
I tried to click on the project from the overall list to display it again, but an error told me that my user rights did not allow it.
By refreshing the list of projects this one has disappeared.
The only place where the project appears is now in the global list of projects filtering, at the very top of the interface.
I'm administrator and I couldn't do anything at all to get back my project.
Please help me
01 Feb 2019 15:55 - 01 Feb 2019 15:57 #2 by Envergus
if it is closed you can't see it.
Try to check the "show closed items" ("montrer les éléments clos")
Last edit: 01 Feb 2019 15:57 by Envergus.
01 Feb 2019 16:25 - 01 Feb 2019 16:26 #3 by UnluckyDuck
Project is not closed (I still checked in case).
I had just created the project for just 5 minutes, no one else could touch it during this time.
The project appears in the project list in the 'Allocations' screen, but i can't assign anyone to the project. When i try, a popup is showed
Invalid checks.
you do not have the right to create this element
Message is actualy translated because i'm in french version of ProjeQtOr
Last edit: 01 Feb 2019 16:26 by UnluckyDuck.
04 Feb 2019 09:31 #4 by babynus
Check orders of profiles.
If your profile on the project has order greater than the on,e you try and use on creation, it is rejected : profiles are ordered so that noone can allocated other resource with profile greater than his own
For ionstance, default order is
- Administrator
- Supervisor
- Project Leader
- Project Member
- External Project Leader
- External Project Member
- Guest
So, a Project Leader cannot allocate a resource with profile Administrator.
The following user(s) said Thank You: UnluckyDuck
05 Feb 2019 17:12 #5 by UnluckyDuck
Hello Babynus,
I tested with 3 accounts, 2 doesn't have access (no right) and the third can read content but is no able to change any property of the project.
I'm an administrator, can i delete the project even if i can't read project properties ?
I will start again from scratch if it's possible
06 Feb 2019 14:48 #6 by babynus
No.
Check the changes you made in access rights and profiles.
