ProjeQtOr free project management software - [SOLVED] The project is gone - No user right - Page 2 - ProjeQtOr
06 Feb 2019 16:23 - 06 Feb 2019 16:25 #7 by UnluckyDuck
Is there an history of modifications I done on the project ?
I can't find what I've done that broke project.
I send screenshots of every screen where my project is showed.
My project is called 'Congés' and i was Project Manager (i'm the project creator)
Last edit: 06 Feb 2019 16:25 by UnluckyDuck.
06 Feb 2019 16:35 #8 by babynus
Possibly you removed your own allocation to the project, or close allocation, or set start and/or end date so that today you're not taking part to the project.
06 Feb 2019 16:40 #9 by UnluckyDuck
How can i remove or modify my project if there isn't manager anymore ?
06 Feb 2019 16:41 #10 by babynus
Only admin can do this
The following user(s) said Thank You: UnluckyDuck
11 Feb 2019 14:01 #11 by UnluckyDuck
Hi Babynus
I found the solution thanks to you.
I did a silly thing when my user account was 'administrator' in changing my role in a project. I changed it from 'Project Manager' to 'Guest'.
Having no assigned task, I could not see the project anymore.
I had to use the "Super" administrator account to change my role in the project, so I could get visibility on my project.
Thank you for your help Babynus!
