ProjeQtOr free project management software - Project screen column order - Page 2 - ProjeQtOr
25 Jan 2019 15:42 #7 by lsigroup
nothing change by emptying cache
log is empty in projeqtior after trying to change column order...
2019-01-25 15:40:46.687 ===== TRACE ===== DISCONNECTED USER 'damienbila'
2019-01-25 15:40:49.060 ===== TRACE ===== NEW CONNECTED USER 'damienbila'
25 Jan 2019 17:48 #8 by babynus
Replied by babynus on topic Project screen column order
Please execute this :
- Open Browser Dev Tool (F12)
- Go to tab network
- Use button to clear content
- Use filter area to display only 'moveListColumn.php'
- Execute test
- You should have 1 new line in Network console : select it
- Go to tab response : copy content and paste it here.
25 Jan 2019 17:56 #9 by lsigroup
I DO NOT FIND TAB RESPONSE
BUT I GET THAT
cross.js:1 [Deprecation] Synchronous XMLHttpRequest on the main thread is deprecated because of its detrimental effects to the end user's experience. For more help, check xhr.spec.whatwg.org/.
cross.getExtensionInfo @ cross.js:1
(anonymous) @ commonFn.js:1
25 Jan 2019 18:06 #10 by babynus
This is the console.
The message is normal.
It is a message that is correct for a WebSite, but is not adapted for an application like projeqtor.
On the dev tool, you must have a tab Network.
Do you have it ?
25 Jan 2019 18:09 #11 by lsigroup
no
i have tabs called
elements
console
sources
network
performance
application
audits
memory
security
that's all
i'm running chrome
25 Jan 2019 18:40 #12 by babynus
First select tab "Network"
(you have it)
Then play the test.
You'll have lines in the network log.
Select the one that refers to request to 'moveListColumn.php'
You shoud have sub-tab on right part, on is "response". I need content of it
