ProjeQtOr free project management software - Project screen column order - Page 3 - ProjeQtOr
25 Jan 2019 18:59 #13 by lsigroup
What do you mean by play the test ? i do CTRL+R
Is it that ?
If yes, i obtain many lines, but none of them contains the php information you are looking for
26 Jan 2019 10:58 #14 by babynus
Replied by babynus on topic Project screen column order
I mean exexute steps in the application that generates issue.
In your case, it means click OK on column selector pop-up
31 Jan 2019 15:40 #15 by lsigroup
I get that:
dojo.js?version=V7.3.3.0218:2 _4af {message: "Unable to load ../tool/moveListColumn.php?orderedL…17|318|319|320|321|322|323|324|325|326| status: 0", response: {…}, status: 0, responseText: "", xhr: XMLHttpRequest, …}message: "Unable to load ../tool/moveListColumn.php?orderedList=275|276|277|278|280|281|279|282|283|284|285|286|287|288|289|290|291|292|293|294|295|296|297|298|299|300|327|301|328|302|329|303|304|305|306|307|308|309|310|311|312|313|314|315|316|317|318|319|320|321|322|323|324|325|326| status: 0"response: {url: "../tool/moveListColumn.php?orderedList=275|276|277…|315|316|317|318|319|320|321|322|323|324|325|326|", options: TMP, getHeader: ƒ, xhr: XMLHttpRequest, transferType: "download", …}responseText: ""status: 0xhr: XMLHttpRequest {onreadystatechange: null, readyState: 4, timeout: 0, withCredentials: false, upload: XMLHttpRequestUpload, …}stack: "Error: Unable to load ../tool/moveListColumn.php?orderedList=275|276|277|278|280|281|279|282|283|284|285|286|287|288|289|290|291|292|293|294|295|296|297|298|299|300|327|301|328|302|329|303|304|305|306|307|308|309|310|311|312|313|314|315|316|317|318|319|320|321|322|323|324|325|326| status: 0↵ at new _4af (projeqtor.lsigroupe.com/external/dojo/do...V7.3.3.0218:2:127428)↵ at XMLHttpRequest._32b (projeqtor.lsigroupe.com/external/dojo/do...=V7.3.3.0218:2:86082)"__proto__: Error
31 Jan 2019 16:54 #16 by babynus
Which browser / version are you using ?
Did you try with another browser ?
31 Jan 2019 18:51 #17 by lsigroup
Chrome
Version 71.0.3578.98 (Build officiel) (64 bits)
31 Jan 2019 20:19 #18 by babynus
Once again, this is the console.
I need the response of the request, in network tab.
If it can help, in network tab, when you select on the left the request to "moveListColumn.php", you have on the right some tabs.
Post a screenshot of each tab (screenshot, not copy/paste).
