ProjeQtOr free project management software - Real cost doesn't reflect Real Work - ProjeQtOr
28 Oct 2018 09:49 - 28 Oct 2018 09:58 #1 by cnguyen
Hi all,
I'm using Projeqtor 6.3.7
I've just done the following operations on a project.
3 resources on my project. Everyone has entered real work up to 31 october 2018.
On one of the resource, i have just entered a cost (C EUR) on the expert profile (This profile is the one my resource is assigned with for the projet / activity)
There was no other cost in the system for the resource.
On the project before entering the cost, real work was X days and real cost was 0 EUR
I saved the cost for the function of my resource on the project (Expert)
Back to the activity, the real cost is still 0 EUR.
Then I enter 1 day on the real wok allocation screen
Real work is now X+1
And real cost is now C EUR, which is the cost I have just allocated for the function.
Seems like real cost has not change for the already existing work.
Any idea ?
Thanks in advance.
Cyril
Last edit: 28 Oct 2018 09:58 by cnguyen.
28 Oct 2018 15:35 #2 by babynus
It should, I think current code does.
Any idea ?
Migrate to latest stable (V7.2.6).
(there were some fixes on the subject on V6.5)
NB : we won't analyse issues on older versions our of Support Service
The following user(s) said Thank You: cnguyen
01 Nov 2018 14:59 #3 by cnguyen
Hi babynus,
Just upgraded to 7.2.6 and the issue remains the same.
Could you help ?
Thanks in advance
Best regards,
Cyril.
13 Nov 2018 08:35 #4 by cnguyen
Hi everyone,
@Babynus, we upgraded to 7.2.6 and real cost still doesn't reflect real work for already submitted "work".
We are a bit stuck with this and it's difficult to follow costs for these projects.
By the way : the upgrade to 7.2.6 has brought a lot of new functionalities for us that are really nice and helpful. Thanks for all the good work on Projeqtor :-)
Thanks in advance for your help.
Best regards
Cyril
13 Nov 2018 08:56 #5 by babynus
You need to have some resource cost change to update cost from work.
Try and delete cost for resource then recreate it.
13 Nov 2018 16:50 #6 by cnguyen
As there is some real work assigned with this function, I can't delete the cost
Error message I get when I want to delete the cost assigned to the function.
Impossible to delete this element because of existing dependent elements
- Assignment (10)
