ProjeQtOr free project management software - Real cost doesn't reflect Real Work - Page 3 - ProjeQtOr
26 Nov 2018 23:04 #13 by babynus
I think it is due to old versions of ProjeQtOr storing null and not zero.
It was changed because of PHP 7.1 than could not sum null+not null.
So ever you can test with PHP 7.0 and it should work correctly,
or you need to update database
update work set cost=0 where cost=null;
(don't forget to backup database before executing SQL statement)
29 Nov 2018 16:12 #14 by cnguyen
We have executed the query (see attached file).
Real cost is still not what it should be (see attached file).
Best regards
Cyril
29 Nov 2018 19:10 #15 by babynus
Well, the upsate is not enough.
Now you have to change value for resource cost.
What would be best is to delete existing and create new one, but it won't be possible (you cannot delete resource cost if function is used on assignment)
What you can do is add new cost "far in the past" (for same function, with starty date before first day of real work)
30 Nov 2018 09:15 #16 by cnguyen
Add a cost far away in the past.
I understand this must be done with a SQL Query.
Can you provide us with the query
Best regards
Cyril
01 Dec 2018 17:21 #17 by babynus
We just identified issue : it seemsupdate cannot change cost of work on validated week.
Ticket recorded.
