ProjeQtOr free project management software - automatic planning calculation - Page 2 - ProjeQtOr
06 Sep 2018 16:23 #7 by Durou C
I know that I must change the define parameter. But when I open the define parameter, I choose minutes=0, hour=6, then I clock to Ok button. And the window close. But nothing are record, no parameter are change, and no activate button display.
06 Sep 2018 16:45 #8 by babynus
This may happen if you have duplicates in table cronexecution
(possibly due to double deployment of same version)
Try and remove duplicates.
06 Sep 2018 17:03 #9 by Durou C
how can I know if i have a double table? where i can find it ?
06 Sep 2018 17:11 #10 by babynus
in db, look for table cronexecution
serch for duplicate values in column functionName
06 Sep 2018 17:23 #11 by Durou C
see attached file, it is that ?
06 Sep 2018 17:26 #12 by babynus
Yes.
You may delete all lines for "cronPlanningComplete" and "cronPlanningDifferential" (no matter to keep one, it will be created where you define parameters)
