ProjeQtOr free project management software - automatic planning calculation - ProjeQtOr
05 Sep 2018 14:15 #1 by Durou C
differential and complete calculation doesn't work.
when I choose the frequency on define parameters, nothing are recording.
I choose hour on 6, and when I click on "OK" button, nothing append.
06 Sep 2018 10:51 #2 by babynus
Hours on "6" means it will be triggered at 6AM
Attention, if you define minutes = *; calculation will be triggered every minute from 6:00 to 6:59
Also check that CRON is running (on admin page)
06 Sep 2018 11:59 #3 by Durou C
cron is running. But no possible to record the modification about hour or day or anything else.
06 Sep 2018 13:51 #4 by babynus
Plase show your configuration scrren for automatic planning calculation
06 Sep 2018 15:26 #5 by Durou C
see attached file
06 Sep 2018 15:48 #6 by babynus
It is clear whythis feature does not work : read the red messages ;)
You have to
1) define parameters : if you keep default it will trigger every hour
You must at least once opn parameters and save
This will display button to activate.
2) activate feature
