ProjeQtOr free project management software - Kanban Plugin doesn't work - ProjeQtOr
22 Aug 2018 09:11 - 22 Aug 2018 09:12 #1 by Yannobi
We work with Projeqtor and just installed Kanban.
It's ok for the installation and we see the front page updated with this new fonctionnality. But it doesn't work.
When we want to create a new kanban for example, nothing appears (alert message or the new kanban)
Here are logs of the installation et the first attempt to create a column :
2018-08-22 09:01:55.335 ===== TRACE ===== New plugin found : kanban_V3.5.zip
2018-08-22 09:01:55.352 ===== TRACE ===== Plugin unzipped succefully
2018-08-22 09:01:55.357 ===== TRACE ===== Plugin descriptor information :
2018-08-22 09:01:55.357 ===== TRACE ===== => name : kanban
2018-08-22 09:01:55.357 ===== TRACE ===== => description : Kanban
2018-08-22 09:01:55.357 ===== TRACE ===== => version : 3.5
2018-08-22 09:01:55.357 ===== TRACE ===== => compatibility : V6.3.7
2018-08-22 09:01:56.066 ===== TRACE ===== Plugin kanban V3.5 completely deployed
2018-08-22 09:02:01.205 ===== TRACE ===== Cannot check Version at projeqtor.org/admin/getVersion.php
2018-08-22 09:02:01.205 ===== TRACE ===== Maybe allow_url_fopen is Off in php.ini...
2018-08-22 09:02:27.295 ***** ERROR ***** [V6.5.2] Exception-[42S02] SQLSTATE[42S02]: Base table or view not found: 1146 Table 'projeqtor.kanban' doesn't exist
2018-08-22 09:02:27.295 ***** ERROR ***** [V6.5.2] For query : select * from kanban where id=-1
2018-08-22 09:02:27.295 ***** ERROR ***** [V6.5.2] Strack trace :
2018-08-22 09:02:27.295 ***** ERROR ***** [V6.5.2] #0 Sql->query called at [/var/www/html/projeqtor/model/persistence/SqlElement.php:2694]
2018-08-22 09:02:27.295 ***** ERROR ***** [V6.5.2] #1 SqlElement->getSqlElement called at [/var/www/html/projeqtor/model/persistence/SqlElement.php:573]
2018-08-22 09:02:27.295 ***** ERROR ***** [V6.5.2] #2 SqlElement->__construct called at [/var/www/html/projeqtor/model/Kanban.php:50]
2018-08-22 09:02:27.295 ***** ERROR ***** [V6.5.2] #3 Kanban->__construct called at [/var/www/html/projeqtor/plugin/kanban/kanbanView.php:54]
2018-08-22 09:02:27.295 ***** ERROR ***** [V6.5.2] #4 include called at [/var/www/html/projeqtor/plugin/kanban/kanbanViewMain.php:27]
Last edit: 22 Aug 2018 09:12 by Yannobi.
22 Aug 2018 15:00 #2 by babynus
Replied by babynus on topic Kanban Plugin doesn't work
It seems table kanban was not created correctly.
Did you try and install plugin several times ?
Whare is your Database (postgres or mysql) ?
Can you check for table kanban in db ?
23 Aug 2018 09:24 - 23 Aug 2018 09:28 #3 by Yannobi
Replied by Yannobi on topic Kanban Plugin doesn't work
We try 3 times the install but with no sucess.
The DB is MariaDB and there is no table Kanban.
Last edit: 23 Aug 2018 09:28 by Yannobi.
23 Aug 2018 10:00 #4 by babynus
OK,
If plugin is considered installed, db updates are not replayed.
So : go to table plugin and remove all lines with name "kaban"
Then try again to install plugin.
23 Aug 2018 11:09 - 23 Aug 2018 11:11 #5 by Yannobi
Done !
CHECK PLUGINS INSTALLED
]MariaDB [projeqtor]> select * from plugin;
| 1 | Kanban | kanban | ../plugin/kanban_V3.5.zip | 2018-07-13 | 1 | V6.5.2 | V6.3.7 | 3.5
| 2 | Kanban | kanban | ../plugin/kanban_V3.5.zip | 2018-08-22 | 1 | V6.5.2 | V6.3.7 | 3.5
| 3 | Kanban | kanban | ../plugin/kanban_V3.5.zip | 2018-08-23 | 1 | V6.5.2 | V6.3.7 | 3.5
| 4 | Kanban | kanban | ../plugin/kanban_V3.5.zip | 2018-08-23 | 1 | V6.5.2 | V6.3.7 | 3.5
4 rows in set (0.00 sec)
DELETE THE PLUGIN
MariaDB [projeqtor]> delete from plugin where name ='Kanban';
Query OK, 4 rows affected (0.00 sec)
CHECK THE ACTION
Empty set (0.00 sec)
Then i tried to reload the plugin. Same problem : Plugin installed in the interface but there is no possibility to create some board.
| 5 | Kanban | kanban | ../plugin/kanban_V3.5.zip | 2018-08-23 | 1 | V6.5.2 | V6.3.7 | 3.5
1 row in set (0.00 sec)
Last edit: 23 Aug 2018 11:11 by Yannobi.
23 Aug 2018 11:14 #6 by babynus
Can you please post log file showing trace of install of plugin ?
