ProjeQtOr free project management software - Kanban Plugin doesn't work - Page 2 - ProjeQtOr
23 Aug 2018 11:17 #7 by Yannobi
Replied by Yannobi on topic Kanban Plugin doesn't work
2018-08-23 11:04:49.148 ===== TRACE ===== New plugin found : kanban_V3.5.zip
2018-08-23 11:04:49.163 ===== TRACE ===== Plugin unzipped succefully
2018-08-23 11:04:49.168 ===== TRACE ===== Plugin descriptor information :
2018-08-23 11:04:49.168 ===== TRACE ===== => name : kanban
2018-08-23 11:04:49.168 ===== TRACE ===== => description : Kanban
2018-08-23 11:04:49.168 ===== TRACE ===== => version : 3.5
2018-08-23 11:04:49.168 ===== TRACE ===== => compatibility : V6.3.7
2018-08-23 11:04:49.168 ===== TRACE ===== =====================================
2018-08-23 11:04:49.169 ===== TRACE =====
2018-08-23 11:04:49.169 ===== TRACE ===== PLUGIN SQL FILE : ../plugin/kanban/kanban.sql
2018-08-23 11:04:49.169 ***** ERROR ***** [V6.5.2] Exception-[23000] SQLSTATE[23000]: Integrity constraint violation: 1062 Duplicate entry '100006001' for key 'PRIMARY'
2018-08-23 11:04:49.169 ***** ERROR ***** [V6.5.2] For query : INSERT INTO `menu` (`id`, `name`, `idMenu`, `type`, `sortOrder`, `level`, `idle`, `menuClass`) VALUES
(100006001, 'menuKanban', 0, 'item', 35, NULL, 0, 'Work Risk RequirementTest Financial Meeting ');
2018-08-23 11:04:49.169 ***** ERROR ***** [V6.5.2] Strack trace :
2018-08-23 11:04:49.169 ***** ERROR ***** [V6.5.2] #0 Sql->query called at [/var/www/html/projeqtor/db/maintenanceFunctions.php:71]
2018-08-23 11:04:49.169 ***** ERROR ***** [V6.5.2] #1 runScript called at [/var/www/html/projeqtor/model/Plugin.php:257]
2018-08-23 11:04:49.169 ***** ERROR ***** [V6.5.2] #2 Plugin->load called at [/var/www/html/projeqtor/plugin/loadPlugin.php:53]
2018-08-23 11:04:49.169 ===== TRACE ===== Error # 1 => SQL error while executing Plugin query in file ../plugin/kanban/kanban.sql (see above message)
2018-08-23 11:04:49.169 ===== TRACE ===== *************************************************
2018-08-23 11:04:49.170 ***** ERROR ***** [V6.5.2] Exception-[42000] SQLSTATE[42000]: Syntax error or access violation: 1142 CREATE command denied to user 'projeqtor_user'@'localhost' for table 'kanban'
2018-08-23 11:04:49.170 ***** ERROR ***** [V6.5.2] For query : CREATE TABLE `kanban` (
`idUser` int(12),
`isShared` int(1),
`name` varchar(64),
`type` varchar(64),
`param` varchar(10000),
PRIMARY KEY (`id`)
) ENGINE=InnoDB DEFAULT CHARSET=utf8 ;
2018-08-23 11:04:49.170 ***** ERROR ***** [V6.5.2] Strack trace :
2018-08-23 11:04:49.170 ***** ERROR ***** [V6.5.2] #0 Sql->query called at [/var/www/html/projeqtor/db/maintenanceFunctions.php:71]
2018-08-23 11:04:49.170 ***** ERROR ***** [V6.5.2] #1 runScript called at [/var/www/html/projeqtor/model/Plugin.php:257]
2018-08-23 11:04:49.170 ***** ERROR ***** [V6.5.2] #2 Plugin->load called at [/var/www/html/projeqtor/plugin/loadPlugin.php:53]
2018-08-23 11:04:49.170 ===== TRACE =====
2018-08-23 11:04:49.170 ===== TRACE ===== Error # 2 => SQL error while executing Plugin query in file ../plugin/kanban/kanban.sql (see above message)
2018-08-23 11:04:49.170 ===== TRACE ===== *************************************************
2018-08-23 11:04:49.170 ===== TRACE ===== DATABASE UPDATED
2018-08-23 11:04:49.170 ===== TRACE ===== WITH 2 ERRORS
2018-08-23 11:04:49.170 ===== TRACE ===== Plugin updated database with 2 errors from script ../plugin/kanban/kanban.sql
2018-08-23 11:04:49.648 ***** ERROR ***** [V6.5.2] Exception-[42S02] SQLSTATE[42S02]: Base table or view not found: 1146 Table 'projeqtor.kanban' doesn't exist
2018-08-23 11:04:49.649 ***** ERROR ***** [V6.5.2] For query : insert into kanban ( idUser , name , type , param ) values ('1', 'Kanban', 'Status', '{\"column\":[{\"from\":\"1\",\"name\":\"Backlog\",\"cantDelete\":true},{\"from\":\"10\",\"name\":\"Pris en charge\"},{\"from\":\"4\",\"name\":\"Fait\"},{\"from\":\"7\",\"name\":\"Clos\"}],\"typeData\":\"Ticket\"}')
2018-08-23 11:04:49.649 ***** ERROR ***** [V6.5.2] Strack trace :
2018-08-23 11:04:49.649 ***** ERROR ***** [V6.5.2] #0 Sql->query called at [/var/www/html/projeqtor/model/persistence/SqlElement.php:1150]
2018-08-23 11:04:49.649 ***** ERROR ***** [V6.5.2] #1 SqlElement->insertSqlElement called at [/var/www/html/projeqtor/model/persistence/SqlElement.php:954]
2018-08-23 11:04:49.649 ***** ERROR ***** [V6.5.2] #2 SqlElement->saveSqlElement called at [/var/www/html/projeqtor/model/persistence/SqlElement.php:622]
2018-08-23 11:04:49.649 ***** ERROR ***** [V6.5.2] #3 SqlElement->save called at [/var/www/html/projeqtor/plugin/kanban/kanbanPostInstall.php:78]
2018-08-23 11:04:49.649 ***** ERROR ***** [V6.5.2] #4 include called at [/var/www/html/projeqtor/model/Plugin.php:265]
2018-08-23 11:04:49.649 ***** ERROR ***** [V6.5.2] #5 Plugin->load called at [/var/www/html/projeqtor/plugin/loadPlugin.php:53]
2018-08-23 11:04:49.658 ===== TRACE ===== Plugin kanban V3.5 completely deployed
2018-08-23 11:04:54.822 ===== TRACE ===== Cannot check Version at projeqtor.org/admin/getVersion.php
2018-08-23 11:04:54.822 ===== TRACE ===== Maybe allow_url_fopen is Off in php.ini...
2018-08-23 11:05:02.210 ***** ERROR ***** [V6.5.2] Exception-[42S02] SQLSTATE[42S02]: Base table or view not found: 1146 Table 'projeqtor.kanban' doesn't exist
2018-08-23 11:05:02.211 ***** ERROR ***** [V6.5.2] For query : select * from kanban where idUser=1
2018-08-23 11:05:02.211 ***** ERROR ***** [V6.5.2] Strack trace :
2018-08-23 11:05:02.211 ***** ERROR ***** [V6.5.2] #0 Sql->query called at [/var/www/html/projeqtor/model/persistence/SqlElement.php:2286]
2018-08-23 11:05:02.211 ***** ERROR ***** [V6.5.2] #1 SqlElement->getSqlElementsFromCriteria called at [/var/www/html/projeqtor/plugin/kanban/kanbanView.php:745]
2018-08-23 11:05:02.211 ***** ERROR ***** [V6.5.2] #2 plgKanbanListSelect called at [/var/www/html/projeqtor/plugin/kanban/kanbanView.php:85]
2018-08-23 11:05:02.211 ***** ERROR ***** [V6.5.2] #3 include called at [/var/www/html/projeqtor/plugin/kanban/kanbanViewMain.php:27]
2018-08-23 11:05:02.211 ***** ERROR ***** [V6.5.2] Exception-[42S02] SQLSTATE[42S02]: Base table or view not found: 1146 Table 'projeqtor.kanban' doesn't exist
2018-08-23 11:05:02.211 ***** ERROR ***** [V6.5.2] For query : select * from kanban where idUser!=1 AND isShared=1
2018-08-23 11:05:02.211 ***** ERROR ***** [V6.5.2] #1 SqlElement->getSqlElementsFromCriteria called at [/var/www/html/projeqtor/plugin/kanban/kanbanView.php:746]
2018-08-23 11:05:07.776 ***** ERROR ***** [V6.5.2] Exception-[42S02] SQLSTATE[42S02]: Base table or view not found: 1146 Table 'projeqtor.kanban' doesn't exist
2018-08-23 11:05:07.776 ***** ERROR ***** [V6.5.2] For query : insert into kanban ( idUser , name , type , param ) values ('1', 'rt', 'Status', '{\"column\":[{\"from\":\"1\",\"name\":\"Backlog\",\"cantDelete\":true}],\"typeData\":\"Activity\"}')
2018-08-23 11:05:07.776 ***** ERROR ***** [V6.5.2] Strack trace :
2018-08-23 11:05:07.776 ***** ERROR ***** [V6.5.2] #0 Sql->query called at [/var/www/html/projeqtor/model/persistence/SqlElement.php:1150]
2018-08-23 11:05:07.776 ***** ERROR ***** [V6.5.2] #1 SqlElement->insertSqlElement called at [/var/www/html/projeqtor/model/persistence/SqlElement.php:954]
2018-08-23 11:05:07.776 ***** ERROR ***** [V6.5.2] #2 SqlElement->saveSqlElement called at [/var/www/html/projeqtor/model/persistence/SqlElement.php:622]
2018-08-23 11:05:07.776 ***** ERROR ***** [V6.5.2] #3 SqlElement->save called at [/var/www/html/projeqtor/plugin/kanban/kanbanAdd.php:73]
2018-08-23 11:05:07.867 ***** ERROR ***** [V6.5.2] Exception-[42S02] SQLSTATE[42S02]: Base table or view not found: 1146 Table 'projeqtor.kanban' doesn't exist
2018-08-23 11:05:07.867 ***** ERROR ***** [V6.5.2] For query : select * from kanban where idUser=1
2018-08-23 11:05:07.867 ***** ERROR ***** [V6.5.2] Strack trace :
2018-08-23 11:05:07.867 ***** ERROR ***** [V6.5.2] #0 Sql->query called at [/var/www/html/projeqtor/model/persistence/SqlElement.php:2286]
2018-08-23 11:05:07.868 ***** ERROR ***** [V6.5.2] #1 SqlElement->getSqlElementsFromCriteria called at [/var/www/html/projeqtor/plugin/kanban/kanbanView.php:745]
2018-08-23 11:05:07.868 ***** ERROR ***** [V6.5.2] #2 plgKanbanListSelect called at [/var/www/html/projeqtor/plugin/kanban/kanbanView.php:85]
2018-08-23 11:05:07.868 ***** ERROR ***** [V6.5.2] Exception-[42S02] SQLSTATE[42S02]: Base table or view not found: 1146 Table 'projeqtor.kanban' doesn't exist
2018-08-23 11:05:07.868 ***** ERROR ***** [V6.5.2] For query : select * from kanban where idUser!=1 AND isShared=1
2018-08-23 11:05:07.868 ***** ERROR ***** [V6.5.2] Strack trace :
2018-08-23 11:05:07.868 ***** ERROR ***** [V6.5.2] #0 Sql->query called at [/var/www/html/projeqtor/model/persistence/SqlElement.php:2286]
2018-08-23 11:05:07.868 ***** ERROR ***** [V6.5.2] #1 SqlElement->getSqlElementsFromCriteria called at [/var/www/html/projeqtor/plugin/kanban/kanbanView.php:746]
23 Aug 2018 11:37 - 23 Aug 2018 11:37 #8 by babynus
Replied by babynus on topic Kanban Plugin doesn't work
OK.
Logs is explicit :
- insert into menu fails : normal, line already exists ;)
- create table kanaban : fails
Two possibilities for this error :
1) user does not have right to create table : check that the user projeqtor_user has grant to create tables on the db
2) syntax error : as the script succeeds on mySql, I think it is not the issue, but it is always possible to face a MariaDB specificity. Just try to directly execute script and if any error is reported, please post it here
`idUser` int(12),
`isShared` int(1),
`name` varchar(64),
`type` varchar(64),
PRIMARY KEY (`id`)
Last edit: 23 Aug 2018 11:37 by babynus.
23 Aug 2018 11:45 - 23 Aug 2018 11:47 #9 by Yannobi
For the first possibility :
MariaDB [projeqtor]> SHOW GRANTS FOR 'projeqtor_user'@'localhost';
| Grants for projeqtor_user@localhost |
| GRANT USAGE ON *.* TO 'projeqtor_user'@'localhost' IDENTIFIED BY PASSWORD '*54EE49F236953EC3BD59F4A9919315B4E92CFF80' |
| GRANT SELECT, INSERT, UPDATE, DELETE ON `projeqtor`.* TO 'projeqtor_user'@'localhost' |
| GRANT SELECT, INSERT, UPDATE, DELETE, CREATE, DROP, REFERENCES, INDEX, ALTER ON `projeqtor`.`projeqtor` TO 'projeqtor_user'@'localhost' |
3 rows in set (0.00 sec)
It seems to come from privileges on projeqtor_user who cannot CREATE
Last edit: 23 Aug 2018 11:47 by Yannobi.
23 Aug 2018 11:50 #10 by babynus
Yes, the create privilege is given only to projeqtor.projeqtor (means table projeqtor af db projeqtor)
I thing it should be given to projeqtor.* (like previous line)
Please change grant options and retry (don't forget to remove lines in table plugin)
The following user(s) said Thank You: Yannobi
