ProjeQtOr free project management software - Issue field size in Activities, Milestone, Projects, etc... screens - ProjeQtOr
07 Nov 2017 17:10 #1 by Albeud
We are facing what I call a "display issue" with some fields in Activities or Milestones screens for exemple..
Everytime I open an item, many fields are smaller than normal, and description textbox appears with some HTML code inside.
See picture below, I think it's self explanatory.
We didn't change anything before issue appeared, and since then we upgraded to 6.4.4, but pb remains the same.
I tried to run demo app from Projeqtor Website, to check whether it could a pb with my computer. But then display is OK.
So if anybody has an idea on the way to solve this issue, it would be great.
Thx
Alain
08 Nov 2017 09:44 #2 by babynus
It seems your instance does not recognize database fields format.
Did you change anything on database when issue occured ?
08 Nov 2017 09:49 #3 by Albeud
Nope :-|
We only restarted the DB, this was the first reboot since the install' we performed 1 month ago.
And I couldn't guarrantee that this issue occured just after this reboot.
08 Nov 2017 09:52 - 08 Nov 2017 09:54 #4 by babynus
please check that parameters.php refers to correct database format (mysql, psql)
Last edit: 08 Nov 2017 09:54 by babynus.
08 Nov 2017 09:55 #5 by babynus
also check for your db log file for any error.
Maybe some services did not restart correctly.
08 Nov 2017 09:56 #6 by Albeud
It seems ok :
$paramDbType='mysql';
