ProjeQtOr free project management software - Issue field size in Activities, Milestone, Projects, etc... screens - Page 2 - ProjeQtOr
08 Nov 2017 09:59 #7 by babynus
Just to be sure, did you try to disconnect and reconnect ?
08 Nov 2017 10:26 #8 by Albeud
So, we finally found, thanks to your previous message suggesting to check DB log file.
We got this kind of error many times in this file :
2017-11-08 10:03:19.476 ***** ERROR ***** [V6.4.4] Exception-[HY000] SQLSTATE[HY000]: General error: 1030 Got error 28 from storage engine
2017-11-08 10:03:19.476 ***** ERROR ***** [V6.4.4] For query : desc linkable
2017-11-08 10:03:19.476 ***** ERROR ***** [V6.4.4] Strack trace :
2017-11-08 10:03:19.476 ***** ERROR ***** [V6.4.4] #0 Sql->query called at [/var/www/html/projeqtor/model/persistence/SqlElement.php:3255]
2017-11-08 10:03:19.476 ***** ERROR ***** [V6.4.4] #1 SqlElement->getFormatList called at [/var/www/html/projeqtor/model/persistence/SqlElement.php:2836]
2017-11-08 10:03:19.476 ***** ERROR ***** [V6.4.4] #2 SqlElement->getDataType called at [/var/www/html/projeqtor/model/persistence/SqlElement.php:2218]
2017-11-08 10:03:19.476 ***** ERROR ***** [V6.4.4] #3 SqlElement->getSqlElementsFromCriteria called at [/var/www/html/projeqtor/model/persistence/SqlElement.php:2489]
2017-11-08 10:03:19.476 ***** ERROR ***** [V6.4.4] #4 SqlElement->getSingleSqlElementFromCriteria called at [/var/www/html/projeqtor/view/objectDetail.php:3447]
2017-11-08 10:03:19.476 ***** ERROR ***** [V6.4.4] #5 drawLinksFromObject called at [/var/www/html/projeqtor/view/objectDetail.php:848]
2017-11-08 10:03:19.476 ***** ERROR ***** [V6.4.4] #6 drawTableFromObject called at [/var/www/html/projeqtor/view/objectDetail.php:275]
We cleaned our filesystem cause there wasn't enough space remaining on it, and restarted Projeqtor.
Now situation is back to normal !
Thx for your help
