ProjeQtOr free project management software - problem of slowness - ProjeQtOr
problem of slowness
03 Oct 2017 15:06 - 03 Oct 2017 15:14 #1 by Durou C
problem of slowness was created by Durou C
database work slowly...
I'm on PHPMyadmin + Apache 2.4.7 on linuxmint config
what can I do to work faster ?
the linux kernel has a report?
Last edit: 03 Oct 2017 15:14 by Durou C.
03 Oct 2017 15:43 #2 by Durou C
Replied by Durou C on topic problem of slowness
complement: the slowness is during the recordings, such as imputations, backup of activities, change of status ...
03 Oct 2017 18:06 #3 by dale
Replied by dale on topic problem of slowness
I don't have an answer, but I am also a newb and also very interested in performance. I am getting adequate performance but that is with only one simultaneous user (me) and a practically empty database. Can you describe your system for comparison? What is your hardware spec? How "big" is your ProjeQtOr database? Has the system become slower over time? I.e. was it fast enough "before", and now it isn't?
My system is ProjeQtor 6.4.1 on older consumer-grade hardware:
  • Intel Core 2 Duo E6600 2.4GHz (4MB L2 cache, 1066MHz FSB) with 3G RAM
  • FreeBSD 10.3 (cli only)
  • Apache 2.4.27
  • MariaDb 10.0.32
  • PHP 5.6.31
  • Internet via DCSIS Cable modem (15 Mbs limit to internet)
I also found some relatively recent relevant posts:
Performance Issue on generating and deleting periodic meetings . It seems reasonable performance for the reported "Generating a periodic meetings with 200 entries takes on our server about 10 min. Deleting the complete periodic meeting took about 8 hours.". It's interesting that the same test was reportedly faster on the ProjeQtOr demo server (generating 2 min, deleting 1:30 hours), but it's not clear if this is understable due to faster hardware, or if other measures (e.g. caching are involved,
Hardware configuration . @babynus reported a "Good PC" with quad-core processor and 8 GB RAM (twice mine in both respects!) should be adequate for 400 projects and 3000 activities, and reports a successful site having "800 users, with 200-400 daily connections" (however, he also says "One issue has been reported on Gantt printing"). @babynus also says "think about clustering for high level platform".
Users and memory size . @babynus reported that "...display of Gantt of hundreds of lines in a browser may be much CPU and Memory consuming for your workstation." Chrome is suggested, but it is not clear if ProjeQtOr runs faster on Chrome for some technical reasons.
(sorry if I mixed up any of the links). I'm especially interested in whether there are any "rules of thumb" for size and system configuration? At what "size" does database clustering likely become necessary? What about clustering and load balancing apache http servers?
Thanks,
Dale
The following user(s) said Thank You: Durou C
03 Oct 2017 19:00 #4 by Durou C
Computer of ProjeQtor Database is only use for this application, it's a quad core with 16G Ram.
Data base is 150 projects, 1250 activities , 100 tickets, no periodic meeting...
I just have more delay for registration as usual...
04 Oct 2017 09:43 #5 by Durou C
Just for information:
When I create new activity, it's take around 45 seconds to record it.
when I change the status of activity, it's take 34 seconds
When I record the modification of RealWork sheet: around 40 seconds.
all of recording take more time...
04 Oct 2017 11:51 #6 by babynus
Replied by babynus on topic problem of slowness
More than 3s to save an activity is not normal.
First check lock file for errors.
I guess you have email issue.
Try and clear parameter "smtp server" in global parameters. Disconnect, reconnect and test again.
Tell us if it's better.
