ProjeQtOr free project management software - problem of slowness - Page 5 - ProjeQtOr
problem of slowness
05 Oct 2017 09:04 #25 by Durou C
Replied by Durou C on topic problem of slowness
I found the mistake with the log files, I've not install the plugins...
now with plugin the new database is exactly the same as the old one. But exactly the same slowness ...... :dry:
I do not understand ? is it possible to slow database with customization plugin or other plugin ?
05 Oct 2017 11:00 #26 by babynus
Replied by babynus on topic problem of slowness
Standard plugins may not cause perf issue. But if you designed your own, it can be soyrce of bad perf.
First a good test would be to try with brand new database : is perf bad without data ?
If yes : your infrastructure is the issue.
If no : install all your plugins : is perf bad with plugins ?
If yes : your plugins is the issue.
If no : install backup of data : if perf is bad, your data is the issue.
05 Oct 2017 11:08 #27 by Durou C
thanks for your reply.
I did new install. perf good
i install plugin : perf good
I import data : perf bad !!!
i have issue on data ... But how can I fixed it ?
05 Oct 2017 11:30 #28 by Durou C
is it possible to send you my backup database to check the issues ?
11 Oct 2017 09:07 #29 by Durou C
I have restart the PC from Projeqtor install today.
when I'm logging to Projeqtor and check the log files, I found some errors:
2017-10-11 08:28:21.533 ***** ERROR ***** [V6.4.2] Exception-[70100] SQLSTATE[70100]: <>: 1317 Query execution was interrupted
2017-10-11 08:28:21.534 ***** ERROR ***** [V6.4.2] For query : select * from indicatorvalue where idle='0' and ( ( warningTargetDateTime<='2017-10-11 08:28:21' and (warningSent='0' or code = 'YEARLY')) or ( alertTargetDateTime<='2017-10-11 08:28:21' and (alertSent='0' or code = 'YEARLY')))
2017-10-11 08:28:21.534 ***** ERROR ***** [V6.4.2] Strack trace :
2017-10-11 08:28:21.534 ***** ERROR ***** [V6.4.2] #0 Sql->query called at [/var/www/projeqtor/model/persistence/SqlElement.php:2253]
2017-10-11 08:28:21.534 ***** ERROR ***** [V6.4.2] #1 SqlElement->getSqlElementsFromCriteria called at [/var/www/projeqtor/model/Cron.php:372]
2017-10-11 08:28:21.534 ***** ERROR ***** [V6.4.2] #2 Cron->checkDates called at [/var/www/projeqtor/model/Cron.php:312]
2017-10-11 08:28:21.534 ***** ERROR ***** [V6.4.2] #3 Cron->run called at [/var/www/projeqtor/model/Cron.php:270]
2017-10-11 08:28:21.534 ***** ERROR ***** [V6.4.2] #4 Cron->relaunch called at [/var/www/projeqtor/tool/cronRelaunch.php:30]
11 Oct 2017 23:15 #30 by babynus
Logged query does not seem to have issue.
Possibly it is due to stop of MySql.
