ProjeQtOr free project management software - Problem with accents while installing Patch v6.3.3 to 6.3.5 - Page 2 - ProjeQtOr
04 Sep 2017 16:13 #7 by Foster
First step : database (Mysql v5.5) backup (just in case I would need to carry out a roll back
Second step : copy of the patch version files on the hosting provider server
Third step : filling of the installation form for the configuration of the server (create the "Parameters.php" files)
Fourth step : connexion to the application using the admin user account.
All these 4 steps have been realised succesfully
Foster
04 Sep 2017 17:21 #8 by babynus
Second step is the source of your problems : you must overwrite existing code, not create new folder (you can backup exiting code previously if you scare for issues)
You must NOT face configuration page (your third step) on migration process.
04 Sep 2017 18:35 #9 by Foster
Yeah !!!
Thank you so much for your last post. This time, it works perfectly.
Foster
12 Sep 2017 09:53 - 12 Sep 2017 10:00 #10 by glaubule
I also had this problem after migrating to another server and found a solution by adding a .htaccess in root Projqtor folder containing :
AddDefaultCharset UTF-8 # for accents issue
because content-type is not declared in php files
Last edit: 12 Sep 2017 10:00 by glaubule.
