ProjeQtOr free project management software - Problem with accents while installing Patch v6.3.3 to 6.3.5 - ProjeQtOr
31 Aug 2017 13:18 #1 by Foster
Since the release of the patchs v6.3.3 and upper versions, I've got a problem with text fields which contain accented letters. All the text of the field is hidden.
The current version of ProjeQtor installed on my server is the former release candidate v6.3.2.
Thank you for any help and hesitate to ask for further information.
Regards.
Frederic
01 Sep 2017 20:27 #2 by babynus
There should be no difference about accents from V6.3.2 to V6.3.3.
Patcch is only corrective without any matter with editor.
Possibly issue comes from migration process.
Export / Import of DB may lead to accent issues ;)
01 Sep 2017 23:25 #3 by Foster
Thank you for your reply and proposed solution. I implemented it but nothing changed. Please find attached flies which showed the problem that happens : as you can notice in the Database screenshot, everything is correct in the "Name" field of the "Project" Table ; all the words using accented letters are correctly dysplayed.
I think that the problem may be fixed up on the application side.
Foster
02 Sep 2017 13:32 #4 by babynus
I persiost and sign : it is not the migration that may have brought the issue.
It is the migration process that may have brough the issue : is you changed some parameters, you lay have issue.
For instance, check $enforceUTF8. It must be set to '1' for recent versions, but must not be set or set to '0' if first version is older (before V4.4)
02 Sep 2017 22:47 #5 by Foster
Thank you for your quick reply.
I can tell you that I didn't change anything and the pach installation was performed without any trouble. Furthermore, you can notice in the "Parameters.php" screenshot that the argument called "$enforceUTF8" is set to 1.
Thank you for again I will remain with the version v6.3.2, hoping tha one day I will be able to upgrade to the latest stable.
Regards.
Foster
04 Sep 2017 09:26 #6 by babynus
Can you explain excatly step by step how you ran migration ?
