ProjeQtOr free project management software - [SOLVED] White screen - Unable to display application screen after succesful login - Page 2 - ProjeQtOr
29 Jun 2017 14:14 #7 by ldubost
No update on Bill. Only on Quotation (to remove the extra comma) and on Project with new fields.
To help you understand :
- on Projeqtor Production, we are actually using V6.1.3 and we can create Bills.
- on Projeqtor DEV, we are using V6.2.5 and we cab create bill, but no orders.
29 Jun 2017 20:38 - 29 Jun 2017 20:39 #8 by babynus
Can you post here content of your folder /model/custom
(I don't think it depends on version, but it may depend on customization)
Last edit: 29 Jun 2017 20:39 by babynus.
03 Jul 2017 16:32 #9 by ldubost
Custom folder attached.
It looks like, even with error message, some orders are created somewhere because I cannot delete custom order types whitch are used in existing orders.
03 Jul 2017 18:15 #10 by babynus
no attachment :(
04 Jul 2017 08:46 #11 by ldubost
07 Jul 2017 16:12 #12 by babynus
I just tested your custom files.
There does not seem to have errors.
Can you (to be sure) check that you have fields
- annee in table expense
- cdPrioProj, idchargeglobalse, idDirection in talbe project
