ProjeQtOr free project management software - [SOLVED] White screen - Unable to display application screen after succesful login - ProjeQtOr
23 Jun 2017 11:45 #1 by ldubost
We have recently upgraded to Projeqtor 6.2.5. After few days of use, I was working on customizing screens (with plugin 'Personnalisation des écrans') when occurred the issue. We did some server reboots and services restart but we still have the issue.
Issue: We launch the application and submit login: "Connexion acceptée"; but the screen becomes all white and nothing else appends. The behavior is equal on Firefox, Chrome and IE.
23 Jun 2017 14:01 #2 by babynus
Try and rename all files under /model/custom (for instance add .old extension)
Test that all works fine.
Then rename correctly files one by one to find the one that generates the issue.
When identified, post it here ;)
23 Jun 2017 14:06 #3 by ldubost
We found out that the Quotation.php was in error, with an extra comma : in attachement
File Attachment:
File Name: quatation.php.docx
File Size:38 KB
23 Jun 2017 14:23 #4 by babynus
OK,
We fixed the issue that was source of the problem when customazing quotation screen.
I guess oyu already fixed issue on your side (remove exta comma)
26 Jun 2017 11:41 #5 by ldubost
Yes, now that problem has been solved but we still have an issue creating an order; and for taht one, I don't understand the log ....
[Mon Jun 26 11:32:50.574277 2017] [:error] [pid 2922] [client 172.28.4.35:60624] PHP Fatal error: Maximum execution time of 30 seconds exceeded in /DATA/projeqtor/tool/projeqtor.php on line 2405, referer: lnx107.cg91.fr/projeqtor/view/main.php
[Mon Jun 26 11:33:24.021279 2017] [:error] [pid 3082] [client 172.28.4.35:60628] PHP Fatal error: Maximum execution time of 30 seconds exceeded in /DATA/projeqtor/tool/projeqtor.php on line 524, referer: lnx107.cg91.fr/projeqtor/view/main.php
[Mon Jun 26 11:33:57.337301 2017] [:error] [pid 6084] [client 172.28.4.35:60929] PHP Fatal error: Maximum execution time of 30 seconds exceeded in /DATA/projeqtor/model/ProjectPlanningElementMain.php on line 378, referer: lnx107.cg91.fr/projeqtor/view/main.php
zend_mm_heap corrupted
[Mon Jun 26 11:34:30.488262 2017] [:error] [pid 3017] [client 172.28.4.35:60973] PHP Fatal error: Maximum execution time of 30 seconds exceeded in /DATA/projeqtor/tool/projeqtor.php on line 2447, referer: lnx107.cg91.fr/projeqtor/view/main.php
28 Jun 2017 00:22 #6 by babynus
Log says executiion is much too long.
This seems to highlight an issue that we cannot reproduce.
Do you have some customization on Bill ?
(file /model/custom/Bill.php should then exist)
If so, please post it here so that we may investigate.
