ProjeQtOr free project management software - [SOLVED] Error while configuring - ProjeQtOr
25 Jan 2017 05:52 #1 by ripal
2017-01-23 13:01:07.657 ***** ERROR ***** Error on SqlElement to get 'dontReceiveTeamMails' for Class 'User' : field 'dontReceiveTeamMails' not found in Database.
2017-01-23 13:01:07.674 ***** ERROR ***** Error on SqlElement to get 'apiKey' for Class 'User' : field 'apiKey' not found in Database.
2017-01-23 13:01:09.411 ***** ERROR ***** Exception-[42S02] SQLSTATE[42S02]: Base table or view not found: 1146 Table 'projeqtor.user' doesn't exist
2017-01-23 13:01:09.426 ***** ERROR ***** For query : select * from user where user.name='admin' and user.isUser = '1'
2017-01-23 13:01:09.440 ***** ERROR ***** Strack trace :
2017-01-23 13:01:09.970 ***** ERROR ***** #0 Sql->query called at [G:\PleskVhosts\pm-logic.com\httpdocs\web\projeqtor\model\persistence\SqlElement.php:1803]
2017-01-23 13:01:09.982 ***** ERROR ***** #1 SqlElement->getSqlElementsFromCriteria called at [G:\PleskVhosts\pm-logic.com\httpdocs\web\projeqtor\tool\loginCheck.php:68]
2017-01-23 13:01:09.997 ===== TRACE ===== Login error for user 'admin'
2017-01-23 13:01:12.575 ***** ERROR ***** Error on SqlElement to get 'dontReceiveTeamMails' for Class 'User' : field 'dontReceiveTeamMails' not found in Database.
2017-01-23 13:01:12.588 ***** ERROR ***** Error on SqlElement to get 'apiKey' for Class 'User' : field 'apiKey' not found in Database.
2017-01-23 13:01:23.107 ***** ERROR ***** Error on SqlElement to get 'dontReceiveTeamMails' for Class 'User' : field 'dontReceiveTeamMails' not found in Database.
2017-01-23 13:01:23.625 ***** ERROR ***** Error on SqlElement to get 'apiKey' for Class 'User' : field 'apiKey' not found in Database.
2017-01-23 13:01:24.821 ***** ERROR ***** Exception-[42S02] SQLSTATE[42S02]: Base table or view not found: 1146 Table 'projeqtor.user' doesn't exist
2017-01-23 13:01:24.842 ***** ERROR ***** For query : select * from user where user.name='admin' and user.isUser = '1'
2017-01-23 13:01:24.856 ***** ERROR ***** Strack trace :
2017-01-23 13:01:24.868 ***** ERROR ***** #0 Sql->query called at [G:\PleskVhosts\pm-logic.com\httpdocs\web\projeqtor\model\persistence\SqlElement.php:1803]
2017-01-23 13:01:25.417 ***** ERROR ***** #1 SqlElement->getSqlElementsFromCriteria called at [G:\PleskVhosts\pm-logic.com\httpdocs\web\projeqtor\tool\loginCheck.php:68]
2017-01-23 13:01:25.430 ===== TRACE ===== Login error for user 'admin'
25 Jan 2017 21:43 #2 by babynus
Replied by babynus on topic Error while configuring
What is version of your database (table parameter, line with parameterCode='dbVersion')
and version of your code (version of ProjeQtOr installed) ?
26 Jan 2017 03:01 #3 by ripal
Replied by ripal on topic Error while configuring
1. dbVersion is showing V0.3.0
2. Where can I see version of ProjeQtOr ?
Ripal Shah
26 Jan 2017 08:05 #4 by babynus
It seems the upgrade phase did not end correctly.
Possibly you faced a timeout from php / apache.
Try and migrated step by step : to V1.0, then to V2.0, and so on.
26 Jan 2017 08:55 #5 by ripal
I am sorry but I am new to PHP.
Please elaborate procedure. suggested by You
Ripal Shah
26 Jan 2017 19:31 #6 by babynus
Do to dowload page and download V1.0.0, V2.0.0, V3.0.0, ....
Then install V1.0.0, V2.0.0, V3.0.0, .... up to V6.0.7
