ProjeQtOr free project management software - [SOLVED] Error while configuring - Page 2 - ProjeQtOr
27 Jan 2017 19:14 #7 by ripal
Replied by ripal on topic Error while configuring
It works with 5.4.0...
Any possibilities for upgrade.....?
Ripal Shah
28 Jan 2017 14:00 #8 by ripal
Error while installing V4.0.0
2017-01-28 13:56:56 ***** ERROR ***** Exception-[42S02] SQLSTATE[42S02]: Base table or view not found: 1146 Table 'projeqtor.parameter' doesn't exist
Ripal
28 Jan 2017 14:20 #9 by babynus
Replied by babynus on topic Error while configuring
I don't unserstant :
it works with V.5.40
but you've got error installing 4.0.0
Please explain what you do, I don't understand.
If install is correct on V5.4.0, thant install V5.5 over this one, ther V6.0...
28 Jan 2017 14:49 #10 by ripal
After installing 5.4 tried to install 6.0.
so again error started...
So I started from 4.0 and getting this error.
Ripal Shah
28 Jan 2017 17:36 #11 by babynus
If install is ok up to 5.4, don't revert to 4.0.
Install 5.4, then 6.0 and report log file here.
28 Jan 2017 19:34 #12 by ripal
Login accepted with below error.....:)
2017-01-28 19:27:17.278 ***** ERROR ***** Exception-[42S21] SQLSTATE[42S21]: Column already exists: 1060 Duplicate column name 'isRealWork'
2017-01-28 19:27:17.342 ***** ERROR ***** For query : ALTER TABLE `plannedworkbaseline` ADD `isRealWork` int(1) UNSIGNED DEFAULT 0;
2017-01-28 19:27:17.417 ***** ERROR ***** Strack trace :
2017-01-28 19:27:17.456 ***** ERROR ***** #0 Sql->query called at [G:\PleskVhosts\pm-logic.com\httpdocs\web\projeqtor\db\maintenanceFunctions.php:71]
2017-01-28 19:27:17.468 ***** ERROR ***** #1 runScript called at [G:\PleskVhosts\pm-logic.com\httpdocs\web\projeqtor\db\maintenance.php:101]
2017-01-28 19:27:17.480 ***** ERROR ***** #2 include called at [G:\PleskVhosts\pm-logic.com\httpdocs\web\projeqtor\tool\loginCheck.php:135]
2017-01-28 19:27:17.493 ===== TRACE =====
2017-01-28 19:27:17.505 ===== TRACE ===== Error # 1 => SQL error while executing maintenance query for version V6.0.6 (see above message)
2017-01-28 19:27:17.517 ===== TRACE =====
2017-01-28 19:27:17.528 ===== TRACE ===== *************************************************
2017-01-28 19:27:17.675 ===== TRACE =====
2017-01-28 19:27:17.687 ===== TRACE =====
2017-01-28 19:27:17.699 ===== TRACE ===== DATABASE UPDATED
2017-01-28 19:27:17.711 ===== TRACE ===== WITH 1 ERROR
2017-01-28 19:27:17.723 ===== TRACE =====
2017-01-28 19:27:19.201 ===== TRACE ===== =====================================
2017-01-28 19:27:19.217 ===== TRACE =====
2017-01-28 19:27:19.228 ===== TRACE ===== 3 ERRORS DURING UPDATE TO VERSION V6.0.7
2017-01-28 19:27:19.241 ===== TRACE =====
2017-01-28 19:27:19.253 ===== TRACE ===== =====================================
2017-01-28 19:27:19.265 ===== TRACE =====
2017-01-28 19:28:53.310 ===== TRACE ===== NEW CONNECTED USER 'admin'
